Clutch replacement on a '91 TR | FerrariChat
Discussion in 'Technical Q&A' started by GrandSportC3, Nov 29, 2005.
  1. GrandSportC3
    GrandSportC3 Karting
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    My clutch still feels fine, but it has over 15k miles on it and I'd assume that it'll start slipping soon.... so I wonder how difficult it would be to change my own clutch? I'm very technical and do all the work (including swapping engines, transmissions and everything else) on my '68 Corvette Drag Race car.. The clutch seems to be easily accessible and I wonder how much work it is to change the clutch? Any tech articles out there about it?
    Thanks in advance!
  2. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    There are some threads on it, with helpful pics. Do a search. The main thing is you need an alignment tool, and you can use a Chevy tool that costs about $5 from local Napa store. I suggest you also replace the fluid in the gearbox while you are at it since the plug is a lot easier to reach when the bell housing is off. You can shop around for clutch kits, but check Ferrari UK first, then see if T. Rutlands or Ricambi will match their price and save some shipping. Good luck. Jim
    PS-I don't think mileage is so much a factor as how it was driven, so my advice is to wait until it slips to replace it. You might be able to get another 15K out of it.
  3. Rifledriver
    37,105
    I have seen TR clutches go many times 15K. Wait until the friction point gets very high but before it starts slipping, then refer to the shop manual about the shimming calculation and take it apart and do that. Then you can get about another 50% out of it.
  4. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    hardest bit on doing a clutch is gettin exhaust of the rest is easy but you will need a clutch alinment tool and change the fluid
  5. GrandSportC3
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    I'll definetely wait until it slips.. Tried to do a search but couldn't find any threads with pics etc.. I wonder if there are any maintenance manuals out there that have instructions and pics?
  6. Rifledriver
    37,105
    If you wait until it slips you will ruin it. The geometry of the clutch assy does not allow fully using the clutch lining material unless you reshim it prior to slippage.
  7. GrandSportC3
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    ok - then I'll need instructions on re-shimming too :D
  8. Rifledriver
    37,105
    If your are planning to do maint yourself just get the shop manual and electrical manual from one of the usual sources.( F-UK, ferraribooks.com etc).
  9. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
  10. GrandSportC3
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    Thanks!! Gonna order the manual!!
  11. GrandSportC3
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    Thanks for the links! I'm not gonna do the shimming quite yet.. I just want to have all the information when I decide to do it..
  12. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    DON'T wait 'till it slips unless you want to resurface or replace your flywheel.
    Don't wait 'till your brakes squeel due to metal to metal contact either....
    Rgds,
    Vince
