Clutch servicing tools | FerrariChat
Discussion in '348/355' started by Robb, Jun 7, 2016.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,409
    Robb
    So what is everyone using to remove the pumpkin and plates - and the big question - DaveRocks, will you be making some tools that we can purchase to assist this work and make it easy? :D
    Pardon my mechanical Renaissance.
    Robb
  2. k17har
    k17har Karting
    Sep 3, 2009
    144
    london, uk
    kayer
    #2 k17har, Jun 7, 2016
    I used 1 of these to take pumpkin off and a socket extension to align the clutch and a strong set of legs to push the pumpkin back in. It was a pain to align the the pumpkin with the prop shaft, but on my previous DIY it was pretty easy.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Robb,
    The clutch cover comes off as an assembly with the clutch. There is a bearning in the cover (and special screw). If you remove the screw, the clutch can be pressed out of the bearing in the cover. Given the cast cover, I don't love that.
    I did make a simple tool (jack screw / plate) to remove the clutch from the cover bearing.
    Not sure if we will offer these or not.
  4. Robb
    Robb Moderator
    Feb 28, 2004
    14,409
    Robb
    I am ready to buy one to go in the garage with my lift.
    Robb
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #5 Dave rocks, Jun 7, 2016
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    very nice tool
  7. fatbillybob
    Aug 10, 2002
    29,188
    socal
    Gee no tool is needed for that. Too many needless fancy tools will get you kicked out of the stooges.
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    I made a mister to bring on track days made of an old 2 gallon sprayer, works great :)
  9. fatbillybob
    Aug 10, 2002
    29,188
    socal
    I just don't race when it is hot...
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    "Kicked out?" I'm not a member. Have no interest of being a "stooge" :)
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    for a 355 clutch job. You don't need any special tool at all. If you want to change the flywheel or repack the grease, you need a blind bearing puller, a press, and a Ribe bit. There is no tool required to pull the cover. A little prying and a little grunting is all it takes.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Sure, you can certainly press the clutch assembly out of the cover bearing but as I mentioned, I'm not a fan of pressing against the casting. Also, this requires a large press (size, not force). As cheap as they are, many don't have them. So, this simple jack plate works very nice to push the clutch out of the bearing and the load is on the studs.
    Is it needed? Nope. Is it helpfull?, yes.
    I try to do things with care and finesse. I don't use screw drivers as chisels and I don't use my sockets as press tools.
    I'm sure many use a hammer and punch and tap the clutch out, but that's not for me.
    Technology = Tools and know how. It's a great thing :)
  13. LorenzoR
    LorenzoR F1 Rookie
    I agree with Dave here, when I was working in the utilities field we used to make jacking plates for this reason and it made life so much easier. I may look into one. Not sure why he used a allen bolt. I think I would have used a regular bolt head
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thanks, Larry. Regarding the allen key, I really don't recall - probably a force of habit as in machine design, that's what is used. Also, it might have been what I had handy in the shop that had the right size and length of threads. Many bolts (allen or hex head), only have threads a certain length and not the full length of the bolt. The end of the set screw in this application was also surface ground flat.
    I had my master toolmarker knock this out - I think it took him a whopping 30 minutes :)
    I do need to remember to design my tools with metric hardware ;)
  15. m.stojanovic
    m.stojanovic F1 Rookie
    3,289
    Serbia - Niš
    Miroljub Stojanovic
    #15 m.stojanovic, Jun 9, 2016
    Are you interested in buying my patent for pumpkin alignment/installation tool kit (all metric)?
    ShineKen likes this.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Patent? :)
    Great post - shows another member being innovative and making tools to help the job go smoother!
    Great job!
  17. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    +1
  18. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    I was going to patent my software that all you have to do is look at a jpeg on the page and I get all your passwords. But the feds got to me first :(
    They did not get the other 3 heheheheh
  19. fatbillybob
    Aug 10, 2002
    29,188
    socal
    I give you props for designing a good looking tool. However, diy guys really need to think and learn about how a system works. Anyone can make a tool. Apes have done it since the beginning. But did you know for example that this tool used improperly could really mess you up? Real pros see these things and read these threads and laugh. We look dumb to them. Don't get me wrong. This tool can help but at the same time can cause damage or prevent proper function. How you may ask? Well the parts just slide together with very little friction fit. People who have had problems putting the pumpkin on simply don't have it aligned right. There are 2 schools of though with pumpkin work. I'm of the leave the bumper on school. Others take the bumper off. The bumper off guys have an easier time aligning and sliding the pumpkin on. Doing this engine out is really simple. You can use a tool as pictured to help drive your pumpkin home and bind up misaligned parts. Then I get a call because the clutch doesn't work. Now disassembly and inspection are required and the newbie didn't know what got messed up in the 1st place and any damage he is totally clueless about. So he reassembles and prays. I'm not against tools. I make them all the time. I love help a tool can provide. I love simplicity like ernie's rubber band to hold bearings in a race. But it is super important to really think about what we are doing and why things work the way they do. It is also important to not introduce other sources of failure. Sometimes things that sound like a good idea just aren't. In medicine they call that being "evidence based."
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bumper on? In most cases, the bumper needs to come off to remove the muffler. Doing a clutch job without bumper removal / muffler removal makes the same sense as doing an in car major :)
    And, Tools are now other sources of failure? This just keeps getting better and better :)
  21. fatbillybob
    Aug 10, 2002
    29,188
    socal
    I hope my comments are constructive. I hope to save other diy'ers some pain. I'm not selling anything and I'm not arguing with dave.
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have posted no tools for sale in this thread. The tool show here was made for my own needs and not for profit. ;)
  23. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    1,154
    Sarasota, Florida
    OC
    I did not use any tools when I did mine except to get of the JESUS nut.
    I have RIBE bits as well, but never used them as I replaced the ENTIRE dual mass crap with a MD clutches setup that is FANTASTIC (sprung clutch like 360, no dual mass)
  24. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    All great points, Carl. A tool in the hands of a tool who isn't aware of possible unintended consequences is never a good thing. Thanks for sharing...
  25. LorenzoR
    LorenzoR F1 Rookie
    FBB Correct me if im wrong. Your last sentence states this "You can use a tool like this to drive your pumpkin home"...Isnt this tool for pushing the clutch assembly away from the bell housing and removing it?
