Clutch vs. brake on down grades. | FerrariChat
Discussion in 'Technical Q&A' started by fga4, Jul 23, 2018.
  1. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    Some say put a bias on braking going downhill. Others say put the bias on the clutch and downshift. I have for years balanced both on manual tranny cars and motorcycles but I sure like using the F1 paddles on the 430 going downhill. Best practices anyone??
  2. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    I would always be in the right gear for accelerating/control, but work on the basis that pads are far cheaper than clutches.
    TheDiffuser and thorn like this.
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Brakes are designed to slow the car's momentum. The clutch is not.
    TheDiffuser and StuR like this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    All true. Brakes are cheaper than clutches most of the times. But..., when going into a long down hill stretch, I put the car in low gear with rev matching.
  5. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    On a slightly related note, I was just in Vietnam going from Da Lat to Nha Trang in a car. There is a 100km section of down hill road where the official very large highway signs every few kilometers across the road that say… "Long Down Hill Road, Go Rear"
    They meant to say Low Gear... Don't they even use Google Translate?
  6. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Sound like they did!!!
    In the UK, engine breaking was a formal technique used by driving instructors. Low gear (signs) and techniques still in force for major inclines.
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,727
    The above is true, but if you can downshift to a gear which will allow the engine to absorb the energy of going downhill, you wear neither the brakes not the clutch.
  8. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Came here to post exactly this, left happy.
  9. ago car nut
    ago car nut F1 Veteran
    5,497
    Madison Ohio
    David A.
    Engine braking lubricates the cylinder walls!
    TheDiffuser likes this.
