Clutch Wear Question | FerrariChat
Discussion in '360/430' started by mark5scuba, Mar 3, 2014.
  1. mark5scuba
    mark5scuba Formula Junior
    Nov 27, 2012
    266
    Vero Beach
    Mark Ross
    For 2007 F430 with 7973 miles with 32% clutch wear...
    Is this an unusual amount, should I be concerned, examine driving habits, etc.
    Opinions needed.
  2. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,518
    Honolulu
    Kevin
    Seems real good to me. 8K miles traveled and used 1/3 of the clutch.
  3. spourreza
    spourreza Formula Junior
    Dec 28, 2013
    596
    Mount Olive Twp, NJ
    S.Pourreza
    My 08 F1 has 4400 miles with 30% wear
  4. Gofast430
    Gofast430 Karting
    Jun 2, 2013
    205
    Overland Park, KS
    Don Dearmore
    My 2007 with 20,775 miles has 22% wear. Just got back from annual service.
    Keep it in RACE all the time.
  5. mountainman3520
    mountainman3520 Karting
    Nov 11, 2013
    202
    Silicon Valley, Cali
    Dan Gilley
    Make sure you are counting your wear correctly. When my Ferrari dealership installed a new clutch in my 430 they logged and reported the clutch measurement to me at 99.5%, obviously remaining, not amount worn. I was surprised since I thought people usually talked about the clutch %worn, when Ferrari talks about the %remaining.
    So if Ferrari tells you that your clutch is at 30% then its probably 30% remaining / 70% consumed.
    I've heard inconsistent info on whether they generally work perfectly down to 0%, start having issues prior to 0%, or last longer than 0%.
    -Dan
  6. PVEferrari
    PVEferrari Formula Junior
    One should always specify, % consumed or % remaining to avoid any confusion.
  7. Elsi
    Elsi Formula 3
    1,648
    Zürich (Switzerland)
    Markus
    Mark – Clutch-wear mostly happens at take off. Here the clutch has to slip until it fully engages. This is the critical point in the life of a clutch.
    If you have to drive off on a steep hill this is really hard for the clutch because slippage is longer and harder due to the higher revs the engine needs to start off. Even worse is when you have to start off on a steep hill in reverse because reverse gear is longer than first giving the clutch an even harder life.
    There is no issue when shifting gears at high revs with full throttle because slippage of the clutch is marginal to nonexistent. So it’s all about driving off.
    If the PIS (point of initial slippage) is wrong or the clutch position sensor has a problem the clutch will slip more than needed and this will wear out the clutch as well.
    Markus
  8. Gofast430
    Gofast430 Karting
    Jun 2, 2013
    205
    Overland Park, KS
    Don Dearmore
    The F Dealers I have dealt with report clutch percentage as a percent of WEAR and not
    REMANING CLUTCH. My last 3 readings have been 2011-14.45%, 2012-19.65% and 3
    weeks ago 22.1%. Each reading was done during an annual service. 1 was done by Boardwalk
    Ferrari and 2 were done by Ferrari of Denver.
    If it was CLUTCH REMAINING the percentage would be descending and not increasing.
