clutch | FerrariChat
clutch
Discussion in 'Technical Q&A' started by davebdave, Jun 4, 2007.
  1. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    Hi, We just bought a used ferrari so I do not know what normal is. We have a mondial t with a hydraulic clutch, therefore no adjustment. If the clutch engages near the end of pedal travel (nearly released) does this mean the clutch is worn?
    No slipage and solid hook-up.
    Thanks, Dave
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,393
    Dumpster Fire #31
    SMG
    couple things,
    is there fluid on the ground near the bellhousing? if it's clear and looks oily it could be a leaky slave cylinder, or a leaky master cylinder up front. a worn clutch that bad would slip, but a leaky slave or master would produce the problem you have.
  3. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    My clutch was feeling very 'high' but with no slipping or other adverse effects. There were no leaks. I investigated as a precaution and found the plate to be worn almost to the rivets. A simple plate replacement and the clutch now bites 'low' and is much lighter to operate.
    An easy job (my 348 has the later single-plate Valeo clutch though).
  4. Schumi
    Schumi Formula Junior
    Jun 5, 2002
    868
    Missouri
    Daren
    How hard is it to change a Mondial t clutch yourself without a post lift? Parts?
  5. chrisx666
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    I have only done a 348 but the prodedure is the same AFAIK. It's the easiest clutch change I have ever done because you do not need to remove the gearbox. No lift required, you need to remove the exhaust though, which may or may not require removal of the bumper. There are threads on here explaining how do do it.
    The parts required can vary. I just put new plate in. There were no leaks from the clutch slave and the bearings were smooth - so I left them alone. The flywheel/pressure plate were not scored - so I left them alone. Everything is still OK a year later. New plates are about GB£200.
    But if everything in there is shot (possible I suppose) then the bill would obviously be a lot higher (maybe where the tales of 4k$ clutch changes come from).
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,393
    Dumpster Fire #31
    SMG
    chris, 'high' disengagement would indicate a worn clutch, 'low' disengagement is from the PP not releasing where it should due to a 'linkage' or hydraulic issue.
    dave, could you explain it a little more? is it that engagement occurs near the floor when releasing the pedal from the floor or that to get it to disengage you have to push the pedal all the way to the floor? hard to get into gears as well?
  7. chrisx666
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    Yep. I read "end of pedal travel (nearly released)" to mean that the car moves off when the pedal was, well, nearly released.
  8. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    It's confusing the way he worded it. Basically we need to know if he's talking about the bottom of the travel, or the top.
  9. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    Thanks everyone, it sounds like the plate(s) may be worn. There is no fluid dripping from underneath.
    The clutch disengages after very little pedal travel and re-engages just prior to taking my foot off of the pedal. I think on the t it is an easy job. Jack the car, pull the exhaust, disassemble the clutch, replace the plates, junk exhaust, replace with tubi or similar. . . wish I could afford to do that.
