clutchless shifting??? | FerrariChat
Discussion in 'Technical Q&A' started by darthenzo, Jul 31, 2010.
  1. darthenzo
    darthenzo Formula Junior
    Dec 8, 2007
    488
    Glendale, Arizona
    James
    I learned how to shift without engaging the clutch from my Dad (Professional Semi Driver for 38 years driving a big brown truck since 1971). Obviously, the clutch is used at starts but not shifting, blipping the throttle for up and down shifting is possible. I did it in all my personal 3 pedal autos, both truck and cars, for over 100,000 and no clutch replacement. I was reminiscing about those days (only have auto trucks now) and wondered about if that could save the notoriously delicate (or so I have ascertained from many threads ...correct my if I'm wrong) clutch, or if it would damage the notoriously delicate (or so I have ascertained from many threads ...correct me if I'm wrong) tranny, just a thought!!
  2. glasser1
    glasser1 Formula Junior
    Sep 2, 2006
    510
    Oregon
    #2 glasser1, Jul 31, 2010
    I used to do this all the time in a '78 VW Rabbit. It went over 300,000 miles (all mine) on the original clutch and tranny. I gave it to the Salvation Army at 313,00 miles when the doors fell off - literally.
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    My clutch was changed at 60k due to spirited driving and not considered that premature. I have never heard a word about it being delicate. Are you hanging out with the sodium valve boys?
  4. darthenzo
    Dec 8, 2007
    488
    Glendale, Arizona
    James
    Napolis talked about having to replace his in the FXX at 800 miles, and not covered by warranty as it is a wear item. I guess I'm used to getting a lot of miles, 320000 on my truck (I know F250 is different than FXX) I've just read a lot of threads about delicate tranny, having to make sure it's warmed up etc. and made me believe that they were delicate compared to other makes
  5. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    The tranny warm up issue relates to shifting into 2nd gear and most of us have fixed that by simply changing to Redline oil. Supercars are made different than trucks but I've never felt I had to treat my 308 gingerly. But although I know how to, I sure wouldn't consider shifting my Ferrari without using the clutch, and not because I thought it was delicate. As a kid, I got fast at replacing cluster gears as I used to speed shift my 1950 Merc all the time, but I would consider it delicate, just misused.
  6. darthenzo
    Dec 8, 2007
    488
    Glendale, Arizona
    James
    I never meant to disparage the machines here. I love Ferrari, and I know that trucks and racecars are different but aren't the general principals at least similar?
  7. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Every so often I'll do a no-clutch shift just to keep me in practice. I did it all of the time in my early E-Type Jags.
  8. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    there is very little wear and tear on a clutch during routine shifting, why subject the transmission to potential damage, much cheaper to replace a clutch. driven properly it should last many 10s of thousands of miles. ask countach owners or carrera gt owners who let others drive their cars....
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    The trick to long clutch life is not to put any power through the clutch, but just use it to feather in and out the TQ from engine to the driveline. Thus, if you can hold your foot on the throttle, so that the engine takes on the RPMs of the post shift condition, you can use the clutch as designed and get a very long life from it indeed. Conversely, put power into the clutch and it might not last a weekeknd.
    One cannot say anything about the life of the clutch without knowning how the user modulates the throttle durring shifting.
  10. k wright
    k wright F1 Rookie
    2,541
    North East TN
    Kent Wright
    Clutches....much cheaper than synchronizers and other transmission parts.
    If you are wearing your clutch out by shifting you need to work on matching your revs and not on clutchless shifting. There should be zero slip when shifting while already moving.
  11. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    If a clutch isn't already slipping, the only time wear occurs is during shifting using the clutch.
  12. ClydeM
    ClydeM F1 World Champ
    11,863
    Wayne, NJ
    Clyde E. McMurdy
    #12 ClydeM, Aug 15, 2010
    I'm the second owner. I dont know how the PO shifted. But I've never worn a clutch on any car. I shift the car with clutch as I would my daily, but with a little more attention. I dont ride a clutch - ever. Precautionary, I replaced my clutch at the last major at 80K. The clutch that came off had lots of meat left on it. It didn't need to be replaced. But since I had one anyway...
  13. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    I have personally put over 1,000,000 miles on personal and company vehicles without burning up a clutch:
    120,000 ford ranger
    432,000 on a ford e-150
    115,000 on a ford f-150 4x4
    117,000 on my current s-10
    these are just my personal vehicles all have been driven in mud, deep sand and towing vehicles without a single clutch failure.
    all the time I used the clutch to shift
  14. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    We ignored the clutch often in motocross when up and down shifting. You had to back off the throttle a bit when upshifting. I've never considered it for a car. Interesting.
