355 - Code P1448 Every 50 Miles | Page 2 | FerrariChat
355 Code P1448 Every 50 Miles
Discussion in '348/355' started by sgtpeper, Jul 19, 2020.
  1. sgtpeper
    sgtpeper Formula Junior
    May 4, 2004
    428
    Denver
    Jeff
    We sure had fun today! No check engine light in nearly 60 miles this time. We'll see what happens, ha.
  2. f355spider
    f355spider F1 World Champ
    18,059
    Anything you did different, or just some good luck? ;)
  3. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    Haven't done anything yet. I'm sure the code will come back on soon.
  4. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Swap your CAT ECU's around and see if the code changes. It may also throw a SDL light if it's the ECU being bad after swapping. I was able to identify the bad ECU on mine this way. All 3 are the same so you can move them around to see if the problem moves with it. The bypass and passenger side CAT ECU are behind the passenger rear wheel next to each other. You can simply swap all the plugs from under the car on the ground (mark them to keep track first). If you need to replace the ECU a 2nd set of hands makes it a pain to a breeze to get the bolts.
    Qavion, f355spider and sgtpeper like this.
  5. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    Ok, after about 90 miles the code came back. I'm not sure if I didn't notice it last time or if I'm just getting more codes... No slow down light but this time I showed:
    P0160
    P0140
    P0154
    P0134
    P1448
    P1121
    P1117
    P1119
    P1115
    I have no idea what any of these codes are. Should I be concerned? Time for a trip to the shop?
    Thanks,
  6. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    Most of those are O2 sensor related. Enough codes that something major is off. Like a major harness is disconnected. Did you unplug anything while it was running? Or forget to plug something back in while poking around?
  7. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,368
    Southern New Jersey Shore
    Phil
    Easy enough to google them - they are O2, evap and engine temp related. Is one of your wire harness unplugged?
  8. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    Some of those i would think would show right away. How is it running? I'd clear them all and see if they immediately return. Is there a chance they were stored codes from some troubleshooting prior and the 1448 just popped back up finally? Were they full codes or pending?
  9. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    How do I tell if they were full codes or pending?
    I haven't really poked around so I don't think anything is unplugged? I took it on a hard drive through the canyons. I could check to see if something is unplugged.
    Engine temp related? My gauge does show a low temp on the highway - is that connected?
    I did clear everything. Should I take it to the shop before driving it much more?
    Thanks,
  10. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    Oh - I have noticed that when the car is hot and I re-start the car it runs a little rough for a second - tonight it even stalled when I started it after a 30 miles drive. It did start right back up though and seemed alright.
  11. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    I'd have it looked at. Something isn't right.
  12. Qavion
    Qavion F1 World Champ
    14,619
    Ian Riddell
    #37 Qavion, Jul 24, 2020
    As mentioned elsewhere, no one has F355 5.2 diagnostic codes, but using F360 codes
    P0160 Left downstream catalyst O2 (no activity detected)
    P0140 Right downstream cat O2 (no activity detected)
    P0154 Left upstream cat O2 (no activity detected)
    P0134 Right upstream cat O2 (no activity detected)
    P1448 Exhaust bypass circuit
    P1121 Left downstream O2 sensor heater (short to ground)
    P1117 Right downstream O2 Sensor heater (short to ground)
    P1119 Left upstream O2 sensor heater (short to ground)
    P1115 Right upstream O2 sensor heater (short to ground)
    Oddly, P1121 is the RPM Sensor on the 2.7 car.
    Fuse 22 in the footwell provides power for the O2 heaters. I would check fuse 22, maybe a short has blown the fuse.
    The ECU provides power for the O2 sensor elements. I don't know if the "no activity detected" is related to unheated O2 sensors (during warm up). Activity may or may not be monitored during warmup (for messaging purposes). The ECU turns on the heaters. I don't know what tells the ECU to turn on the heaters. Water temperature?
    Code P1448 (Exhaust bypass circuit) is probably your old problem.
    Sorry, more questions than answers
    f355spider likes this.
  13. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    I know this will sound dumb, where is the footwell fuse panel? I have the diagram on which fuse is which but I only know where the panel is in the front trunk.
  14. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  15. Qavion
    14,619
    Ian Riddell
    #40 Qavion, Jul 24, 2020
    https://www.ferrarichat.com/forum/posts/141359922/
    hinges at the bottom, two fasteners at the top.
    There are a few other goodies in there... Bilstein suspension unit, doorlock module, fuel level damper, etc...
  16. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    Interesting! That fuse was like hanging on for life - it had just a little edge that was still connected. There was a spare 10amp in there so I replace it. We shall see if the codes come back!
    f355spider and Qavion like this.
  17. Qavion
    14,619
    Ian Riddell
    I would keep an eye on the fuse. You may have an intermittent short in the engine harness. Sometimes there is improper routing of the O2 sensor wiring and it touches hot engine parts. The insulation may have burnt through.
  18. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    I also have O2 extenders on my race cats. Could that have caused the short? Could this have been tied to the original code as well though?
  19. f355spider
    18,059
    No, extenders would not cause those codes
  20. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
    I'll hunt around a bit more for some loose or singed wiring.
  21. Qavion
    14,619
    Ian Riddell
    Not directly, but maybe the guy who fitted the extenders didn't route the wiring for them properly?
  22. sgtpeper
    May 4, 2004
    428
    Denver
    Jeff
  23. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    The 2 white wires are the heater wires. You can unplug the sensors one at a time and check the resistance between the 2 white wire to check the heater. It should be between 5 and 10 ohm or so. If zero or very high, the heaters are shot and the sensors need to be replaced.
  24. f355spider
    18,059
    I've always found if the heaters are not working you will get a CE light. I've had P codes for failed O2 sensor heaters on both my 355 as well as my BMW. In other words, the Bosch Motronic monitors this for you, so testing shouldn't be required.
  25. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    I suggested testing the heater resistance because of the abundance of O2 codes which may indicate the problem is elsewhere and the codes may be spurious.
    All 4 are reporting short to ground. The heaters need to be measured to determine if the short is internal or in the external wiring somewhere.
