Codes/CELs | FerrariChat
Codes/CELs
Discussion in '348/355' started by st4rk, Oct 27, 2015.
How often do you have CELs?
  1. Rarely
  2. Sometimes, I just clear it and move on
  3. Frequently
  4. All the time, I ignore it now
Multiple votes are allowed.
Results are only viewable after voting.
  1. st4rk
    st4rk Formula Junior BANNED
    Dec 7, 2011
    447
    My car seems to generate a random number of codes. At one point it had 6 codes, yet ran perfectly fine.
    I have a CEL from the bypass being wired open. Out of curiosity, I pulled the "codes" the other day and to my elation found only 1 code - p1448. Months ago it had 5 codes for random stuff like cat efficiency (bull****).
    Really weird, but not surprising considering we're talking about a f355 here...I didn't expect the codes to just clear up by themselves.
  2. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    Ha, the record is 14 cel codes.
  3. st4rk
    Dec 7, 2011
    447
    A record I will strive to beat!
  4. TrojanFan
    TrojanFan F1 Veteran Owner Silver Subscribed
    Nov 17, 2008
    5,169
    So. CA & NV
    Peter
    Was that Ketel's?
  5. ssnowball
    ssnowball Formula Junior Silver Subscribed
    Oct 28, 2013
    295
    Scot
    Been lucky so far, in 2 years of ownership no CEL's; once had to deal with an intermittent SDL, but upgraded the original "black" cat control ECU's and problem was solved.
    Car is stock with the exception of hyper flow cats and tubi. Just passed smog here in CA (star station - which for those of you that do not have the pleasure of being in CA, is designed to meet higher performance standards - thankfully they did not challenge the presence of hyper flows) with no problems and very low readings.
    I hope my streak continues.
  6. tres55
    tres55 F1 Rookie Rossa Subscribed
    Sep 18, 2012
    3,572
    Canada
    P1448 is the only code I've had...and that's only when I leave the valve open for 10 minutes or longer before it comes on.
    As soon as the CEL comes on, I just close the valve and clear the code.
    Need to get test pipes.
  7. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    In 3 years I have had two cells. One was for a bad O2 sensor. Replaced sensor and the code never came back. The other was for Lambda control adaptive value which came on right after I did a smoke test of the exhaust headers. Took the car out for a good run and the light when off by itself and never came back. I'm guessing the O2 sensors were contaminated by the smoke test and once the contaminant burned off all was good. The car is a 2.7, stock except for Nuvolari cats.
  8. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
  9. Eric C
    Eric C F1 World Champ Silver Subscribed
    Mar 20, 2009
    11,074
    St. Louis, MO
    Eric
    I've never had a CEL pop up.
  10. tres55
    Sep 18, 2012
    3,572
    Canada
    Even with your current exhaust setup?
  11. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    23,689
    WI
    O M F G
    I literally laughed so loud out here in the garage my wife came out to see if I was OK.
    Might be the post of the year Tim. Well played....
  12. WATSON
    Sep 9, 2010
    23,689
    WI
    I had about 12 various codes shortly after I got my car home. The previous owner said "it would through an exhaust code from time-to-time" Uh yea...
    It took me a year, but I tracked and corrected each & every one. Great learning experience and nary a code since. It was a "bonding experience" :)
  13. johnk...
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    Tim, the resemblance between that picture and one I recently saw of you with a mutual friend is uncanny. :)
  14. Eric C
    Mar 20, 2009
    11,074
    St. Louis, MO
    Eric
    I've had the SDL pop on twice for a few seconds but it turned right off. The check engine light has never triggered.
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    If you have a code(s) there is an issue.
    During the last decade I had to replace one exhaust thermocouple (failed) & the spark plug wires (3 wires had intermittent continuity) and this addressed the cel issues.
    These cars actually run very well when issues are correctly diagnosed/repaired.
    The only other recommendation I would have is to periodically clean the wire contacts with electrical contact cleaner.
  16. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    thats funny :)
  17. johnk...
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    My code were real. The Ghosts only come out on Halloween. Woooooo. Spooky. Gold eyes!
  18. SoCal1
    Jun 14, 2011
    8,630
    Tim Dee
    Thats my daughter in that pic LOL
  19. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I would check your cel bulb.
  20. st4rk
    Dec 7, 2011
    447
    For the 9 people that rarely get codes, would be nice to know what their average mileage a year is.
  21. Bertil
    Bertil Karting Owner
    Sep 8, 2012
    199
    Stockholm Sweden
    Bertil Palmblad
    For me, more than 6500 miles/year.
    Bertil
  22. johnk...
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    I've put 5k miles on my car in 3 years. As I said, I had two real CELs, not ghosts. To reiterate, the fist CEL came a couple of weeks after I got the car, maybe 500 miles. Bad O2 sensor. Replace it and that CEL never returned. Second CEL came about 2k miles ago. Lambda control. Cleared itself, and never came back. I suspect it was contamination of the O2 sensors with mineral oil after smoking the exhaust system. When I stated the car after smoking, the CEL on both the 1-4 and 5-8 banks (2.7 car) were going crazy, coming on, going off... and the car ran like crap. The exhaust would burn your eyes. Very rich. A blast down the highway cleared things up. Car's been perfect before and since.
    Frankly I don't really consider these CELs since they were related to actually issues, not intermittent ghosts.
  23. WATSON
    Sep 9, 2010
    23,689
    WI
    I drive 3500 miles each summer for the past three years.
    Prior to that this was a CEL machine! :)
  24. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,767
    Lake Villa IL
    No cel, have only had it for less than a year. I think less than 1500 miles, I will have to check.
  25. drbob101
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    If you never get codes, have ever looked at an OBD readout on your car?
