458 - Coil over bottom mount nut stuck | FerrariChat
458 Coil over bottom mount nut stuck
Discussion in '458 Italia/488/F8' started by hardhattg, Nov 14, 2019.
  1. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    Lowering 458 . Passenger side was no problem did it in car. Drivers side had to pull the coil assembly out of car. Threads are clean and have been soaking for couple days but bottom mount nut unscrewed just a little and then froze up. Now won’t move either way ?
    Any advice on this
  2. fatbillybob
    Aug 10, 2002
    26,420
    socal
    Take spring pressure off
  3. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    Yes have done that , two spring compressors , no pressure at all. Something caused nut to bind and tried to back it up right away and could not it just froze instantly. Have been trying the usual methods to get nut to move but it seems to be welded in place. Just wondering if anyone has any experience freeing something like this.
  4. fatbillybob
    Aug 10, 2002
    26,420
    socal
    Can you post a picture? I think I know what you are talking about but would like to see it before I say more.
  5. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    Just took the ring compressors off as in process of adjusting the one I had down 15 mm back up , so they will be even unless someone knows how to unweld this nut. The lock nut below it moves freely and there was no pressure on the bottom seat . Possibly dirt or filings got into those treads and now it is locked right.
  6. fatbillybob
    Aug 10, 2002
    26,420
    socal
    Sometimes you can apply a little heat to the ring NOT the shock body with just a propane torch
  7. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    You might have inadvertently friction welded the aluminum threads together. This can occur with stainless against stainless threads also sometimes. I had a case once, where I was making a welding cart and I was using a stainless steel nut with a stainless steel bolt to hold a little wheel on. I went to test fit the wheel on and the heat from welding nearby caused the stainless nut and bolt to start to seize up. When I added more pressure to remove things, it seized up worse and then the friction from trying to get the bolt out welded the threads together. I tried everything in the book to get that bolt out, but nothing worked. I ended up having to cut the frame out and re-weld a new leg into the cart and start over.
    I've been very careful with stainless to stainless threads ever since.
    If you attempted to unthread the seat perch with any sort of pressure on the threads, then you either galled the aluminum (which will mechanically bind the threads - lubrication or not) and/or some level of friction welding took place. Either way, usually the outcome is not a good one.
    Adding heat to the situation (especially with aluminum threads) usually is a bad idea. There is a special product for threading aluminum - it's all alum-a-thread or maybe Safety tap; I use it here in my shop when threading or turning aluminum on the lathe. It's pretty slippery stuff. You might try putting some of that into the threads to see if it helps.
    If all seems lost, you might want to try using an air hammer on low and see if you can free the nut like that. Sometimes the small repeated blows will break things loose. The other thing is put everything into the freezer for a while, then hit the collar with a tiny bit of heat. Sometimes that will help free things up. When I press on wheel bearings or chainsaw bearings, I usually freeze one side and heat the other to about 175 degrees.
    Anyway, good luck over there. Worst case, you'll be shopping for a spare strut on eBay :)
    Ray
  8. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    Go on YouTube and search "friction welding" - just for fun :)
    Ray
  9. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    Thanks for the advice. I believe we will need some new parts on that one side to get the car lowered. Very sensitive stuff this aluminum. I went ahead and put car back together already . Also put a set of titanium sport wheels on at this time. Had the silver wheels. Like them both.
    I am in the market for a good deal on a strut body or the whole assembly if anyone has one to sell or comes across one. The passenger side went back up very easily just like it came down but the drivers side sure made things interesting.
    The front is about 1/4” lower ( the amount I was able to lower the drivers side before it seized up ). and convincing myself that it’s noticeable and looks better , lol
  10. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    There are always damaged ones for sale on eBay and/or you can contact a couple of the Ferrari parts recyclers directly.
    You should be able to find a damaged shock assembly for around $300 to $500. Then just salvage the lower collar and you'll be back in business.
    Ray
  11. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    I am carefully checking this thread and the others about lowering the car on OEM springs, as I am considering doing it myself, so I am trying to learn as much as I can, and gather all the available information and advice in advance.
    I would summarize that, in order to prevent nut jamming, the following helps:
    · Clean the threads the best possible.
    · Soak the ring nuts with the best anti-lock product available (note: the beloved WD40 isn’t particularly aimed at this) and let it sit.
    · Lubricate the exposed (lower) portion of the thread, where the nuts will have to go once lowered.
    · Release the spring tension with spring compressors before doing the job.
    · Rotate the nuts very slowly and make frequent pauses, so that there will be no heat build up; immediately stop and try something else (more lube, backing it up...) if they feel getting harder to move.
    Once the nuts are jammed, the “usual” things can be tried:
    · Heat on the nuts.
    · Freezing the assembly + heat on the nuts.
    · Your best unlocking product in liberal amount.
    · Longer sitting time once soaked in your best unlocking product in liberal amount.
    · Hammer (yes, in the end you will try that, once replacing the shock is the only option left).
    When all is lost, before replacing the complete strut, we can also consider to have new collars fabricated, maybe not ajustable (basically a portion of correctly sized pipe): this is still a viable and cheap solution, that will deliver with some luck and some adjustment (shimming/trimming of the fixed collars, adjustment of the working ones). Unfortunately this of course requires removing the shock from the car, but it still saves the strut.
    An even luckyer backup solution is having just one nut locked in a position that is at least close to what we wanted: in this case I would consider leaving it as it is, adjusting the others accordingly, and trying to forget about the whole story.
    All of this said, I also have to say I am sorry for you, Tim, I share your disappointment, and your experience makes me think twice about proceeding.
    Last thing I feel to say is that there must be something wrong with this shocks, as most of the preload-adjustable high-end shocks have aluminum preload rings threaded on aluminum bodies, and they are frequently operated without even releasing the spring tension, and with no issue whatsoever. Take Öhlins as a reference, and check the user’s manual of any of their coilovers…
    All of this extreme precautions and extra care we have to take on our cars are undoubtedly due to some defect in the collars/nuts manufacturing: surface treatment? Threads cut? circular tolerance of the collar?...
  12. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    Now that I have been through this . I would say that your summary here is very accurate and probably the most important item is making sure every bit of pressure is off is off the collar. I didn’t think there was really any pressure on collar but while using only one spring compressor ( couldn’t fit two ) obviously one side of the coil was compressed more then the other but the whole spring was off the collar even on the less compressed side. All thought I still feel having just the one compressor in place contributed to the nut locking up suddenly.
    Compressing the springs with two spring compressors as is needed is very difficult when assembly is still in the car . There’s simply not much room especially on the drivers side . We had pretty slim spring compressors and also cut them down as small as possible and still could not really get two of them on while coil over was on the car. I sprayed the threads for a couple days before starting project and constantly while trying to adjust collars to keep threads clean and cool . The passenger side went very easily but not the drivers side. If i did this again I would definitely pull the strut out of the car. Although it seems like more work and initially it is. It’s not difficult and will increase odds of success exponentially. Personally i did lower the car 1/4-1/2 inch perfectly even on both sides and it looks ok to me. So I think i am done with lesson learned and shared. Image Unavailable, Please Login Image Unavailable, Please Login
  13. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Tim,
    after all of this hassle and pain your car looks beautiful, and sure it handles well. Happy about it.
    If I will do that, I won't go any lower than that (I am in EU, so my metric plan is 10-15mm!).
    Question: did you make a suspension alignment after lowering? I believe the camber change for such a small lowering could be acceptable, if not even an improvement... I think we are talking about a few tenths of degree here...
  14. ingegnere
    ingegnere F1 Veteran
    5,264
    Montreal
  15. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    I have not as yet but car is due for annual fluids change and will have Ferrari check alignment then. As far as driving the car It drives perfectly and straight as an arrow 80 mph .
  16. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Thanks Tim, this is what I thought.
    I think the camber change can be hardly noticed (if not better), and it has a negligible effect on tires wear...
    Enjoy in good health, in the meantime I will order the smallest spring compressors possible (I have the one with two hooks at the ends, I will look for single hooks) and then maybe try...
  17. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    I had the single hooks as you can see and cut down the bolts quite a bit but there Just isn’t much room to access two sides of coil while it is installed. All though these hooks are pretty beefy if you can find a
    Compressor with smaller hooks that would help a lot . Personally I would still recommend taking them out of car . see attached pic once I had it out of vehicle. Image Unavailable, Please Login
  18. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Thanks, I will consider that.
    What what did you do, in the end, with the locked nut?
  19. hardhattg
    hardhattg Karting
    Jan 19, 2019
    66
    timothy gould
    Wasn’t much to do. It’s locked. So it had moved about 1/4” or so before freezing up . So after giving up on moving that nut ( tried heat ) I decided to just set passenger side to match and put everything back together.
  20. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Ah, OK, got it, thanks.
  21. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    This job is very simple if approached correctly:
    1. Remove the strut
    2. Clean threads
    3. Fully compress spring
    4. Loosen jam nut
    Once you do that, you should be able to adjust the seat perch with nothing more than your fingers. The only time you need the leverage of spanners is for breaking the jam nut free and also for holding everything in place while snugging the jam nut back into place. Otherwise, everything should turn relatively easily and freely. Cleaning the threads out with compressed air and/or a little used toothbrush works great. There really isn't a lot of need to soak the threads or use a lot of lubricants. A tiny bit of WD40 works great. Even just a drop or two of sewing machine oil works plenty well.
    The big pitfall is thinking you can somehow safely do this job while the struts are on the car. I initially thought I could do it using this approach also. But it quickly becomes apparent that this method is full of problems (mostly access and clearance problems). Removing the strut is a bit of a hassle, as you have to remove the fender liner and also the liner up top (as I remember). You also have to loosen part of the windshield wiper motor & arm stuff and push it out of the way. However, in the big scheme of things, it's not all that bad. Once you have room to work, the strut comes off the car with only 3 bolts - it's actually a bit shocking how easy it is to pop off the car. Once it's off, working on the bench, while holding the strut in a bench vise, is relatively straightforward.
    If someone out there is able to fully compress the springs while on the car, then great. Personally, I would like to see what spring compressor is being used, as I wasn't able to accomplish it myself. It's been a while since I did this job, but as I remember it, there is so much in the way, it's nearly impossible to clamp onto enough coils to remove all the tension from the spring - and as this thread illustrates, even a very small amount of load from the spring can result in damage to the relatively delicate aluminum threads.
    Anyway, I'll say this: I bet Tim Gould Sr. will be a pro at doing this job in the future :)
    Ray
  22. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    I have seen it happen numerous times. Usually happens when someone tries to adjust the spring perch with the spring not compressed, but also sometimes with the spring compressed. The aluminum spring perch galls on the threaded aluminum sleeve installed on the shock body. Once this happens you are done, there is no moving the perch, as it is basically welded to the sleeve.
    I do everything that Ray Johns recommends (though I use a new brass or stainless steel brush to clean the threads), but I also recommend using a good penetrating lubricant (not WD40) like Wurth HHS plus or K on the threads.
    Not a very good design, as instead of cutting the threads into the shock body, Boge used a threaded sleeve that spins on the the shock body. You can't replace the sleeve unless you remove the top of the shock, which may or may not be possible.
    The only fix is to replace the shock.
    Brian Brown
    San Francisco Motorsports
    RayJohns likes this.
  23. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Brian,
    I think the sleeve is sustained by a clip (that stands the spring load), so I believe that, once the spring is packed by the compressors, you can move the sleeve just a bit up, so to free the clip and snap it out of its groove, and then pull the sleeve out of the shock from the bottom. In case the lower end eye is too big to slide the collar over it, you can trim the end eye just a bit to make the collar slide, if it's not a big deal...
    Or, you still have a couple of chances: you can slide the sleeve down as much as possible onto the end eye and cut a ring out of it to shorten it from the bottom, so that the spring nut will take the axial position you wanted to reach by "un-doing" it onto the sleeve (once it and the clip are replaced in their original position), or even you could split it into 2 halves with a grinder (but you have to be VERY careful not to damage the shock body), and fabricate a new fixed collar made by cutting in 2 a piece of pipe, and then keep it in place by an adequate number of steel clamps, or by welding a couple of eyes where fixing bolts will go and keep the 2 halves together.
    What do you think?
  24. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    edit: you don't even need to do that, you could just slide it as low as possible onto the lower end eye, and progressively cut away rings of it until it's all done.
  25. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    I think you are dreaming :)
    You know when I was much younger, I used to try to repair dents in my Datsun with Bondo and sanding and all that. I used to think that the guy who do this for a living must get really good at it - having to perfectly follow all the contours of the body lines, etc.
    My next door neighbor owned a body shop for many years, which repaired all sorts of exotic cars. One day I was hanging out with him and I asked him about doing Bondo work and how the heck do they get it so perfect when the cars have so many angles and all. You know what he said? He said, "No, no, we don't mess around with body filler; usually we just order a brand new body panel from the factory and install it, then spray it". He continued, "If we had to spend countless hours sanding body filler by hand on every car, we'd probably end up going out of business."
    Wait.. what? My whole life has been a life...
    Same deal here. Just get a new shock and bolt it on.
    Ray
