Coilover Spring Adjustment. How to Loosen/Adjust? | FerrariChat
Discussion in '348/355' started by foxnick348, Nov 16, 2009.
  1. foxnick348
    foxnick348 Karting
    Nov 22, 2007
    56
    Racine, Wisconsin
    Nick Fox
    Hey Guys,
    I've decided to lower the ride height on my 1992 348 a bit based on some posts I found here.
    I have the correct spanner wrenches from Ricambi. One to unlock the spring (Smaller Wrench) and one to adjust the ride height (Larger Wrench).
    Question is, which way do you turn the threaded collars to loosen and then adjust the ride height?
    I sprayed the threads and collars overnight with Liquid Wrench and WD40, but these babies will not loosen and I think maybe I am not turning them the correct way to unlock.
    Please explain which way to turn the threaded collars.
    Thanks,
    Nick
  2. BrandSB
    BrandSB Karting
    Jun 11, 2008
    236
    Canton, Michigan
    Steve
    Nick,
    I recently did the coilovers on my 355 and, assuming their the same, loosen the smaller lock nut by turning it to the left to break it free from the spring retainer nut. Sounds like you've got a knuckle buster going so gloves might help...good luck!
    Steve
  3. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    Looking up from the bottom of the assembly, counter-clockwise. (Make sure you've taken all the weight off the wheels also when doing this). In theory the lock ring should just be snug+ against the height adjusting one.
