355 - Coilovers aftermarket - need help | FerrariChat
355 Coilovers aftermarket - need help
Discussion in '348/355' started by Senshi458, Jul 8, 2023.
  1. Senshi458
    Senshi458 Formula Junior
    Sponsor Owner Rossa Subscribed
    Oct 17, 2015
    864
    Norway
    Reza
    Need some help, I consider "upgrade" to aftermarket coil overs. I know there is a lot to choose from, but what is the BEST!
    From my understanding there is:
    Quantum
    Moton
    MCS
    Öhlins
    Intrax
    I drive most hard on streets, from before my car have FHP with ECU suspension. Is it just better keep as-is? Or will the aftermarket coil overs be BIG upgrade. I run Öhlins on my 911 and are happy with the ride, on my Mini I have KW and very happy.
  2. Senshi458
    Oct 17, 2015
    864
    Norway
    Reza
    Ok I changed my mind will keep my current set-up. I had zero issues with push the car on twisty roads with F8 Spider + 296 GTS in front of me both of those cars tried really hard to push away. But I was right behind them. So this thread can be up for those after upgrade, but for me Im very happy with the FHP set up
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,690
    F355s come from the factory with coil-overs, and easily adjustable ones at that.
    You can raise, lower, tilt, and corner weight the car as it comes from the factory.
  4. Redlyne_mr2
    Redlyne_mr2 Formula Junior
    Aug 5, 2009
    466
    Calgary, Alberta
    Ryan D
    Are there any coilovers out there that work with the factory electronic suspension adjustments?
  5. radback
    radback Formula Junior
    746
    France
    No, but with some parts (mainly top shock mounts), you can adapt different springs on the OEM active suspension.
    That's what I'm planning to do.
