Cold engine oil check 348. | FerrariChat
Discussion in '348/355' started by carwhisperer, Jan 9, 2015.
  1. carwhisperer
    carwhisperer Formula Junior
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    Is there any way to check oil without running the engine first? Should it at least register on the dipstick?
  2. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    No. The motor must be run to full operating temperature before you check the level. Its a dry sump motor.
  3. Bertil
    Bertil Karting
    Sep 8, 2012
    199
    Stockholm Sweden
    Bertil Palmblad
    No.
    You have to run the engine and use the dip stick. Or if you have drained the system, fill her up with 11 liters of oil, then you know it's at right level.
    Bertil
  4. fdekeu
    fdekeu Formula Junior
    633
    Belzium
    Frank
    The reservoir is empty when cold, so nothing on the dipstick
    You could purge the engine and measure what is coming out :)
  5. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    As noted in another thread, you could pour in 3 quarts when cold and it will be "filled". Then you will be posting about all the SMOKE and the advice will be along the line of ..... Did you overfill it ? Reading the manual on occasion helped me, yes it is written "funny" but there is a lot of info in it.
  6. carwhisperer
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
