Cold engine problem | FerrariChat
Cold engine problem
Discussion in '308/328' started by BYE208, Oct 5, 2013.
  1. BYE208
    BYE208 Rookie
    Mar 27, 2013
    20
    Stefan
    My 1980 208 GTB works perfectly with a warm engine, however for the first 10 minutes or so it runs horribly. It seems that when the engine is cold it struggles to get fuel into the system resulting in a rough ride until the engine warms up.
    Can anyone offer suggestions where the problem might lie?
  2. tepps
    tepps Karting
    Oct 15, 2010
    103
    Buffalo NY
    Tom Tepas
    Warm up regulator? possibly stuck and not changing differential pressure. You must hook up a fuel pressure gauge and monitor pressure.
  3. Steve Magnusson
    26,822
    Is it a carbed 208? If so, the extra air cam has probably been disabled (or is misadjusted), and unless you use the choke (and you shouldn't), sort of quasi-normal behavior (i.e., you need to use the acc. pedal a bit during slow cold-running).
  4. BYE208
    BYE208 Rookie
    Mar 27, 2013
    20
    Stefan
    It's injection not carburetor
  5. BYE208
    BYE208 Rookie
    Mar 27, 2013
    20
    Stefan
    Thanks for the tip Tepps. I'm sure that it is fuel related so I will check it out.
  6. BYE208
    BYE208 Rookie
    Mar 27, 2013
    20
    Stefan
    Checked the fuel pressure. All good
  7. Steve Magnusson
    26,822
    Please elaborate -- did you check the regulated supply pressure, the cold control pressure, and the warm control pressure?
  8. BYE208
    BYE208 Rookie
    Mar 27, 2013
    20
    Stefan
    Spoke to my mechanic who told me that he checked the fuel pressure. Cannot elaborate on what he tested
  9. tepps
    tepps Karting
    Oct 15, 2010
    103
    Buffalo NY
    Tom Tepas
    the fuel pressure is not static. It should change from about 30 psi to around 50. Don't quote me on that as I don't have a spec book in front of me.Sometimes people will adjust the CO to overcompensate for vacuum leaks , lean mixture , richness etc, etc,Then everything gets out of whack.If your mechanic does not know what is wrong, try and get someone else who is more familiar with the operating systems.
