Cold Heat soldering iron | FerrariChat
Discussion in 'Other Off Topic Forum' started by MrScarface, Mar 5, 2006.
  1. MrScarface
    MrScarface Formula 3
    1,093
    Austin
    Adam
    Anyone tried or have one of these? They are in my face constantly. I have yet to buy one (don't need it anyway) Common sense tells me it's a load of BS. But I'm still curious. I just want to hear what real world users think of them.
  2. MalkaJB
    MalkaJB Karting
    Jul 22, 2005
    74
    La Jolla
    I don't own one, but I've used one before. They are fine for small jobs, but if you want to do some serious soldering, they are kind of a pain in the ass to work with. They don't get hot enough to do anything other than small simple solders, and keeping the tip hot is also a pain. There are two little prongs on the end and placing solder between them completes the circuit. Trying to keep the solder in between the two prongs can be challenging when working in tight spaces. In the end, it's nothing really more than a toy. Give me an old fashion soldering iron any day.
  3. Buzz48317
    Buzz48317 F1 Rookie
    Dec 5, 2005
    2,862
    Shelby Twp., MI
    Michael
    I do own one and I agree...if you are going to do much more than solder small jobs then go for the plug in model. The cold heat does take a little practice but to do small jobs around the house it works great...I used mine in building the theater in my basement, and for some small jobs around the business such as replacing microphone jacks because the contractors used reall crappy ones when they built the building...but I digress...another thing that I noticed is that if you are working in a confined space forget the cold heat it's sorta cumbersome because the unit holds the batteries. The light is nice on the end when working in a partially finished basement. More than a toy, but not really a tool either. It does work as advertised though except the tip does not cool down as fast as it does on the infomercial...fast, but I would not go from computer circuit board to the palm of my hand without at least a 15 second gap. Try one out they are only like 20 bucks.
  4. PeterS
    PeterS Five Time F1 World Champ
    52,672
    Goodyear, AZ
    PeterS
    I knew there was something wrong with this product, as I have not seen it in the major hardware chains. The infomercials I reviewed did not say to buy it at Home Depot, Lowes, etc.
  5. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    They are in Walmart and in Home Depot here but rebranded as something other than "Cold Heat". They can't really work due to the batteries - they simply cannot produce enough current to provide much heat. Even if they can crank 1000mA out of the batteries at 3 volts, that's only 3 watts. Even the smallest soldering irons out there are 15 watts which would require 10 AA batteries.
  6. PeterS
    52,672
    Goodyear, AZ
    PeterS
    That's BAD for the manufacturer, as if the chain stores get a lot of returns, the manufacturer will have to 'eat' the returns and pay for the return shipping (As per most one-sided contracts with large chains!) PLUS what the manufacturer may have put out big bucks to have inventory on hand to meet anticipated orders.... A scenario I would stay far away from unless I knew my product would work as advertised (or how it led the consumer to believe how it works).
  7. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    DEPENDS ON THE BATTERIES
    RECHARGABLE BATTERIES ( NI-CAD, NICKEL-MED) ARE 1.2 VOLTS
    ALKALINES ARE 1.5 VOLTS, EVEN WITH THE ALKALAINES, BETTER TO BUY A CHEAP WELLER PLUG IN.............
  8. Dr C
    Dr C Formula Junior
    Dec 1, 2002
    480
    Kansas City
    Ed
    I have one that I got from Radio Shack. It's very useful for small soldering jobs - primarily because you don't have to plug it in and wait for it to heat up and it does cool down much faster than a regular soldering iron. I don't use it for sweating joints in copper pipes because it wasn't made for that.
    Just one of the many tools that come in handy occasionally. And, as someone already pointed out, it only costs about $20.
  9. SRT Mike
    Oct 31, 2003
    23,343
    Taxachusetts
    I was being generous. There are also different current draw ratings for various batteries and lithium is not the same as NiCD is not the same as alkaline, etc. Best case it's going to be able to produce 3 watts and gradually ramp down over about an hour of use to about 60% of that before it dies.
  10. BWS550
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    BOTTOM LINE....WITH 3 WATTS OR 2.4 WATTS, YOU CANT REALLY DO JACK, AGREE????
  11. dm_n_stuff
    Dec 10, 2003
    43,895
    26.806311,-81.755805
    Dave M.
    Had one.
    Tried to use it on a couple of simple jobs and it was for ****, so I tossed it.
    Back to the old fashioned iron.
    DM
  12. SRT Mike
    Oct 31, 2003
    23,343
    Taxachusetts
    Right on!
  13. Buzz48317
    Buzz48317 F1 Rookie
    Dec 5, 2005
    2,862
    Shelby Twp., MI
    Michael
    If you use light flux you can solder with it...it works well for quick simple soldering jobs. Does take a little practice, but you can solder with it.
  14. carless
    carless Formula Junior
    May 20, 2005
    272
    So. Ca.
    Paul
    Burn $20.00 and save your self the time aggravation! I never use it, just sits in my toolbox.
  15. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    #15 enjoythemusic, Mar 6, 2006
  16. C. Losito
    C. Losito Formula Junior
    Dec 12, 2003
    922
    Metro St. Louis
    Chris Losito
    Best tool ever made for the creation of cold solder joints. If you need portability get yourself a butane iron and fill it with something other than Ronson.
