Cold Start Issue - M2.7 (1995) - SURVEY | Page 2 | FerrariChat
Discussion in '348/355' started by FourthAlfa, Mar 15, 2017.
  1. DaisyCutter
    DaisyCutter Formula Junior
    Jul 15, 2014
    255
    Sweden
    Dayan
    Mine is a late '95 build. Started it for the first time in 4 months and it fired after 4-5 cranks. Seemed a little tardy compared to when it is regularly driven, but that could also be down to a potentially slightly less than fully charged battery.
    I usually set the ignition to on for 5 seconds or so before I turn it over. Old habits.
  2. ClydeM
    ClydeM F1 World Champ
    12,308
    Wayne, NJ
    Clyde E. McMurdy
    I have a 95 here in NNJ. the garage is about 65 degrees. If I follow the above procedure, She fires right up & I also get the added benefit that the ABS & Brake lights don't stay lit or go on as frequently.
    She's always on a battery tender when parked for > 3 weeks
    If I rush & crank her right away, I may have a starting issue.
  3. ClydeM
    12,308
    Wayne, NJ
    Clyde E. McMurdy
    Ok, I admit it, I cried at that picture above. It's almost like looking at a best friend in front of you with their stomach cut and their guts splayed and falling from their hands. They are staring at you eye-to-eye and you both know - there is no hope.
    I suppose the picture is appropriate for "The ides of March", but still....et tu Brute?
  4. cuneo
    cuneo Formula 3
    2,489
    Wow, that's insane! gives me anxiety looking at that.
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    Whats really strange this is what I do to relax, like folks do crossword puzzles
    ADD can be fun fun fun :)
  6. FourthAlfa
    FourthAlfa Karting
    May 15, 2015
    184
    Paris, France
    Andrew Love
    #31 FourthAlfa, Mar 16, 2017
    Thanks for the great feedback so far. Initial feedback seems that the Europeans are a bit less affected that the US guys, will be interested to get a few more data points.
    Thanks also for the suggestions, I should specify what I have done so far to troubleshoot, in order to shed some light on some of the ideas of what the pumps are doing in the ignition position etc.
    Background : I’ve replaced the fuel filters and I’ve taken the injectors out and had them cleaned. Although they were “dripping”, the cleaning did not help the cold restart problem (did noticeably improved top end performance though!)
    I’ve monitored the fuel pressure at the filters (pre-regulator) during the entire start sequence. I’ll upload the video of the whole sequence, in the meantime let me explain the sequence:
    (Pressures measured at the 2 x Schraeder valves on top of filter)
    1. Car off for >2 weeks: P(left)=0, P(right)=0 (might have been discharged by connecting pressure gauge)
    2. Ignition on: P(left)=10psi , P(right)=10psi (quick rise and very stable, like a valve was just opened, pumps do not appear to be on)
    3. Engine Cranking : P(left)=58psi , P(right)=58psi (both rise to 58 immediately as cranking starts, needle on pressure gauge jiggles, pumps obviously on)
    4. Fires, but quits, key still in RUN position : P(left)=54psi , P(right)=53psi (needle stable suggesting pumps now off)
    5. Ignition OFF then ON : P(left)=54psi , P(right)=53psi (pressure does not drop)
    6. Cranking : P(left)=58psi , P(right)=58psi (same as step 3)
    7. Engine starts : P(left)=56psi , P(right)=56psi
    Regarding the pressure leakdown, I measured if for about 18hours after shutting the car off. Nothing strange, both side leakdown at the same rate, suggesting that nothing is wrong (graph below). Hopefully this clarifies
    I'm intrigued by the comment from Bobzdar about resetting the computer (again a specific thing to a '95 I think, letting it run for 10 min after battery disconnect…). Easy enough to try so I'll give this a shot too.
  7. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,995
    Northeast U.S.
    Jim
    Early 1995. Build date Sept 94. Starts after the second round of starter cranking. This is if the car has sat for a period. After the car has been run it starts normally.
  8. FourthAlfa
    FourthAlfa Karting
    May 15, 2015
    184
    Paris, France
    Andrew Love
    @jjtjr and @yassa, what region are you guys in?
  9. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    764
    Vermont
    john truskowski
    new england
  10. andyw355
    andyw355 Karting
    Jul 5, 2011
    72
    Australia
    Andy
    Exact same thing. 1995 355B in Australia.
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    Mine is the same too. 1995 GTS
  12. FourthAlfa
    FourthAlfa Karting
    May 15, 2015
    184
    Paris, France
    Andrew Love
    @andyw355 and @MAD828, I presume no ethananol in your fuel?
  13. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    I use 98 octane fuel - normally Shell V Power. Most fuels will contains % of ethanol not sure how much this would have but 98 octane is the most expensive and readily available pump fuel we have in Australia.
  14. FourthAlfa
    FourthAlfa Karting
    May 15, 2015
    184
    Paris, France
    Andrew Love
    Well I tried the battery disconnect / re-connect, this time letting the car idle for 10 min or so afterwards until the fans came on. Lo and behold, my car starts first time now. I have to admit I never let the car idle till the fans came on before (after reconnecting the battery), but it certainly appears that this has some impact.
    Does anyone know what map / trims the ECUs are adjusting during this re-learning process?
    Has anyone done the 10 min idle (after ECU RESET) and still have the problem persist?
  15. F355Bob
    F355Bob Formula 3
    I have done the reset many times and still have the issue. In my car it is air temp related. If air temp above about. 70 degrees, starts first time, if below 70 starts second time, so I think it has to do with the cold start fuel trims.
  16. DouglasNg
    DouglasNg Formula 3
    Jun 6, 2004
    1,041
    SG
    Douglas
    95 GTB in Singapore too. Starts perfect 2nd time.
    Any conclusive data here so far?
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Do you usually wait for the transmission light to go off because if you do then you are giving the fuel system the time it needs to pressurise.
  18. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Same here. Mine is also a September 1994 build.
  19. brendon0
    brendon0 Formula Junior
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    95 - owned it 10 years - starts on first crank every time.
  20. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    Just recently took my 95 out of storage. So far, starts first crank every time.
  21. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    I was told that this was common behavior for dual-fuel pump F355s.
  22. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    I dont have the starting issue. Mine has a single fuel filter so not sure om number of
    Pumps.
    When I energize thr car, fuel pump comes on and stays on until i shut if off, fyi.
  23. andyw355
    andyw355 Karting
    Jul 5, 2011
    72
    Australia
    Andy
    Same.
  24. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    There is your answer :)
  25. andyw355
    andyw355 Karting
    Jul 5, 2011
    72
    Australia
    Andy
    Single fuel pump and filter. Suspect leaking FPR's. but sometimes it does start first crank attempt (takes 3 or 4 seconds and doesn't start strongly unlike a warm start which is immediate).
