Cold Start Problem-no fast idle | FerrariChat
Discussion in 'Technical Q&A' started by spiderseeker, Nov 30, 2005.
  1. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #1 spiderseeker, Nov 30, 2005
    I have an 85' 308qv (US Ver) that won't go to fast idle after startup(starts fine- runs at 1000rpm).
    I think the Electrovalve is bad- see photo attached. I measure an open circuit across the electrovalve coil terminals- what should the resistance be across the coil terminals? Where is the best place to get a new one?
    p.s.- the AAV and cold start switch in the overflow tank are ok.
    Steve
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,459
    Dumpster Fire #31
    SMG
    the electorvalve is just a solinoid (sp?) anyway when voltage is applied it moves so i would assume an open circut unless voltage is supplied. can you check with the car running after a cold start within the first 5 mins? before it gets to hot? i know alot of those circuts can only be checked with a cold engine, then once its warms you have to wait hours before a re-check.
    if the valve isn't opening it could be a bimetalic strip in the WUR or the thermal gauge. most of the earlier systems ran reduntant cold start valves, not sure of the 85' Qv though, i'll look in the WSM.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,459
    Dumpster Fire #31
    SMG
    #3 smg2, Nov 30, 2005
  4. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    Im not familiar with the component but any solenoid should have continuity (no open circut). If you have "out of limits" on your digital multimeter then it is fubared provided it is indeed a solenoid.
  5. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    With the 2 wires removed, the coil shows "infinite" resistance across it's terminals, an open circuit, with voltage applied nothing can happen if the coil is open. (assuming I understand this correctly)
    What should the resistance across the coil be? (I would think maybe 200 ohms or so) certainly NOT infinite.
    Steve
  6. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Steve.. I too have a dog in this fight, my 86 328 isn't going into cold start warm up (fast idle). So if anyone has any ideas I'm open for suggestions and sources for parts.
    Thus far I've been told to check the Aux Air Valve (the one under the expansion tank), I haven't checked it yet but I'm gonna start there.
    I had a 308 2V & spoke to someone at Norwoods who recommended I replace the vlave you show on your photo. I think I obtained one from Brian Keegan...
  7. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Steve, you should have some value, its really unimportant what the spec is at this point because yours is garbage either way.
  8. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Mike- yes, the AAV is one of the major causes of stuck "low" or stuck "high" cold (and warm) idle problems- just remove it and spray it thoroughly(from inlet and outlets) with carb cleaner until the metal round shaped disk moves freely(use a screwdriver to push it gently sideways). Then spray with wd-40 to further improve the free motion, shake out the fluids before these next tests. The test for it is to put it in your freezer for 15-30 min or so and you should be able to see "Most" of the opening between the inlet-outlet tubes- then put it in the oven at 200 degrees for 15-30 min and it should completely close (simulating warmed up conditions-cutting off extra air flow and slowing idle.) Sounds like your valve could be stuck closed or mostly closed.
    Another thing to check is the coolent temp switch on the lower portion of the auxillary overflow tank-(small tank where the radiator cap is)- it should read shorted when cold(84-85qv anyway)- my terminology maybe incorrect, but I found these tips searching this board. (still a rookie at this)
    I've only had the car 4 mos and in the Summer it was no problem but the temp in Colorado is dropping to the 20-30's and now it IS an issue. I am determined to understand exactly how this clod start system is supposed to work. Maybe together we can figure it out- unless someone already has.
    Steve
    "Steve.. I too have a dog in this fight, my 86 328 isn't going into cold start warm up (fast idle). So if anyone has any ideas I'm open for suggestions and sources for parts.
    I had a 308 2V & spoke to someone at Norwoods who recommended I replace the vlave you show on your photo. I think I obtained one from Brian Keegan..."
  9. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Steve you have a PM..
  10. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
  11. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,459
    Dumpster Fire #31
    SMG
    okay i brain farted that one. the ohm resistance should be around 11-12 ohms. the silenoid is an electromagnet you should show a resitance equal to the iductance. i think i got that right. but i did just check mine and it read 12 ohms. mines new and works fine.
  13. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    My BBi has two of every damn thing and I have no fast idle when cold. Im familiar with the air valve and the freezer test as well but can these things be opened to be unstuck if thats the case? Also, has anyone here taken apart the warm up regulators to clean them?
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,459
    Dumpster Fire #31
    SMG
    as for the idle up during cold start. the WUR recieves a signal from the thermal switch on the top of the block. but there is also a cold start bypass valve that recives a signal from the switch mounted in the expansion tank. so why two? from what i have heard the bypass valve was to insure fast hot running to get the cats up to temp to pass emmisions, however that high rpm cold start starts to wear on you rings and and bearings. personally i removed the bypass system and now only run the WUR set-up. still idles up when cold and runs fine. i no longer have to check reduntant parts. to each his own on that though.
  15. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,459
    Dumpster Fire #31
    SMG
    it's a bi-metalic strip connected to a spring and "gate" you can at best clean the opening to insure free unstuck movement. i don't think though that the regulator can be opened itself. R&R on that one.
  16. Steve Magnusson
    26,932
    #16 Steve Magnusson, Nov 30, 2005
    Steve -- I'm not hopeful that fixing your "bad" electrovalve will also affect the cold idle speed (since it controls whether or not your pulse air injection system is running -- not how much air is entering the engine intake tract), but stranger things have happened, and you can simulate a working electrovalve without even buying a new one yet just to see what happens (However, long-term it's best to have a working pulse air injection system in any case).
    Your guesstimate at the electrovalve coil resistance is about right or maybe a little high -- if you measure one "cold" (with a low-current multimeter) it might be 40~50 ohms, but the wire is thin and long enough that the resistance will go up when the real current is actually flowing (but as you've already surmised, it's a 100~250mA kind of current and not a 1A current).
    The jpeg shows an electrovalve where I've numbered the ports 1, 2, and 3 so we can communicate more easily (it's not your exact electrovalve application so the hose connections are different in the jpeg). Port 3 is the "metal" port.
    For your '85QV:
    Cold start-up = electrovalve energized = the vacuum source line on port 1 is connected to the line on port 2 that goes over to the Cut-off Valve "A". This opens Cut-off Valve "A", and the pulse air injection system is active. Port 3 (going to the atmosphere) is blocked closed.
    Warm-running = electrovalve not energized = the vacuum source line on port 1 is blocked closed and the line on port 2 from the Cut-off Valve "A" is vented to the atmosphere via port 3. This closes Cut-off Valve "A", and the pulse air injection system is not active.
    If you want to simulate a "working" electrovalve during cold start-up, just remove the lines from port 1 and port 2 and connect them together with an appropriate little tube, but make sure you label them so you get the right line back onto the right port later. It is also important that you don't do this during warm-running since this "forces" the air injection system to always run and the extra air in the exhaust will drive the Lambda system crazy.
    Good hunting...
  17. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    91TR- looks like port1 is vented and not used- is your diagram labeled correctly?
    Steve
  18. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    91tr- nevermind- I read where port 1 and 3 are reversed in the diagram- sorry.
    Steve
  19. Steve Magnusson
    26,932
    #19 Steve Magnusson, Nov 30, 2005
    I removed the hoses from the earlier jpeg of the electrovalve to try to make things a little less confusing, and this jpeg shows your electrovalve with the corresponding port numbers labeled:
  20. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    91tr- I connected the two hoses and no change, I guess I was on a wild goose chase with that valve. (like you thought)
    I know the AAV is good (and its heating element is 22 ohms, so it's ok) the cold start switch in the coolent tank is ok too- (closed when cold)
    As I understand it, the thermal time switch activates the cold start injector but only for a few seconds (acts like priming the engine). So that shouldn't be it. (starts fine)
    So that leaves me with the warm up regulator, I haven't ordered my Bosch test gauges yet, is there any way to test it without gauges? I've checked and cleaned the connections. I have 11.5v at the warm up regulator and while unplugged it seemed to run smoother. 22 ohms on the WUR terminals.
    Steve
  21. Steve Magnusson
    26,932
    Well, I'm sort of glad that that didn't fix your problem ;)
    It's still a good idea to have a working air injection system so do replace that electrovalve if you measure its coil as "open".
    If you've already confirmed that the AAV is opening when cold and closing when warm then you've got to look elsewhere.
    One problem with K-Jet with Lambda systems is that, if something goes wrong on the electrical/Lambda side, it will still sort of run OK-ish when warm like a dumb K-Jet if the A/F mixture has been retweaked when warm -- so let me ask some background questions:
    1. Was it working correctly before and this is a recent new problem, or has it never been right?
    2. Have you confirmed that the Frequency (Lambda) Valve is always "buzzing" (working) when the engine is running? On K-Jet with Lambda systems, if the "protection" relay goes bad (i.e., no +12V to run the injection system) and someone retweaks the AF mixture (with a dead Frequency Valve), it will sort of work OK when warm as a dumb K-Jet, but it's not the right fix.
    3. Have you tried measuring the O2 sensor voltage output (the single O2 sensor wire relative to ground with everything still plugged in) during warm idle to see if it is really running closed-loop? If it is running closed-loop, this voltage should be varying between 0 to +1V in a quasi-sinusoidal way every couple of seconds.
    Your checking the Warm-up regulator control pressure cold and warm is a good idea too. Since you tweak the thing up when warm, the Warm-up regualtor could be totally wacky, and warm-running would be OKish, but cold-running would be poor.
    And has often come up before, it never hurts to make sure that the injection system electronics located in the trunk is dry and to check/reseat the connections.
  22. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I just bought the car last August and was told that the mixture was tweaked to the lean side in Texas to pass emissions. (I haven't re-set it, it runs so well here in Denver but I need to have it checked or check it myself when I get an EGA) ).
    It seemed to work ok during the hot summer, never really fast idle but more like 1500-2000 rpm.
    Frequency valve always buzzes.
    Haven't checked O2 voltage yet- will do that tomorrow. (no tap for it in the engine compartment is there?)- How do I connect a voltmeter to it with the wire still connected to the O2 sensor ? (is there an adapter for doing that?)
    I REALLY appreciate your help, by the way.
    Steve
  23. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Honestly, if the only issue here is the cold start high-idle device, I would leave it not working. I disconnected mine on purpose. All it does is race the engine when cold and not well lubricated in order to heat the cats faster. This was done to make the feds happy, not the car happy. Our '83 Mondial starts right up in 10 degree weather and idles fine with no high idle device. It made me wince to start it in cold weather and have the engine run immediately right up to 2500 or so RPM. UGH!
    Birdman
  24. Steve Magnusson
    26,932
    That's good -- confirms the +12V power is OK/present.
    Just follow the single wire from the O2 sensor (the dual wire from the O2 sensor is just for the internal heater) -- it will have a male/female spade connection where you can attach the voltmeter lead while leaving the connection connected.
    Glad to lend some minor assistance. If you do confirm that it runs closed-loop when at warm idle, I'd have to guess that the Warm-up regulator has "aged" or broken, but the control pressure measurements will confirm/deny that. Keep chewing ;)
  25. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Birdman- the idle degrades for the 1st 10 minutes or so of drivng- will stall at the 1st few stop signs- till warm, then runs perfectly smooth at 1000rpm. I guess I should have mentioned that but lack of fast idle was responsible for that I thought.
    Steve
