Cold Start Problem-no fast idle | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by spiderseeker, Nov 30, 2005.
  1. Steve Magnusson
    26,932
    Your '83 is a K-Jet without Lambda (with the Cold Start Air Valve in addition to the AAV) -- on the K/KE-Jet with Lambda systems the cold RPM isn't so high.
  2. Rifledriver
    37,288
    The high idle device you speak of is only on 80-83 models and is not on his 85. The cold running equipment his car has that is not working is still intact on your car. Without that system working the car prob will not idle on its own until warm and very probably is also affecting systems that are supposed to function a particular way hot or cold.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,457
    Dumpster Fire #31
    SMG
    any ideas why the dropped the redundent bypass? doesn't seem that anyone kept it working.
  4. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Originally Posted by spiderseeker
    ...Frequency valve always buzzes...
    Is the frequency valve "buzz" that noticiable? I checked the connection on mine cleaned the contacts but really didn't notice the "buzz" .
    How obvious is it suppose to be?...
  5. Rifledriver
    37,288
    They had trouble with the cold start phase of the emission test. A higher idle will be cleaner and heat up the cat faster.
  6. Rifledriver
    37,288
    Depends on your hearing I guess. Put your hand on it, it should feel like it is vibrating. Also disconnect it while running, the motor should stumble and falter and maybe die.
  7. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #32 spiderseeker, Dec 3, 2005
    Finally took readings from the O2 sensor- on my 85qv, I couldn't find a place to "tap" off of to get the readings, so I had to check it at the ECU located under a plate (under the antenna on the rear pass side- for newbees.)
    I first used a digital meter and the readings were jumping from 0 to .7vdc or so. (0 to approx 1 are normal)- I suspected that the digital meter was just too slow to display the upper voltage, so I decided to break out my 20 year old Tektronix 475 scope and "see" the voltage displayed. Each increment is .5v. You can see 2 increment spikes showing approx 1v from top to bottom. Has anyone else here put a "scope" on the O2 sensor? (getting a similar trace I hope)
    So assuming the O2 sensor is working(along with AAV and coolent temp sensor-also good) now I suspect the WUR (warm up regulator) may be bad, fuel pressures need to be measured to confirm it -I don't have the gauges yet.(on my Xmas list)-
    So I may just "take a shot and change it". It seems that the "bad cold start idle" must be a common problem since this thread has been viewed buy more than 300 so far. I WILL let everyone know what solved my problem.
    Steve
  8. Steve Magnusson
    26,932
    Although the p-p amplitude may be about right, that isn't the type of O2 sensor output waveform that I'm familiar with for KE-Jet closed-loop operation. IME on the KE-Jet with Lambda it's a near sine wave shape (not a quick pulse). I wouldn't expect a K-Jet with Lambda to have a significantly faster mixture response time than a KE-Jet with Lambda so I wouldn't yet say "healthy" for that part of the system (but confirming/denying the control pressure behavior of the warm-up regulator vs temperature would be your next step anyway).
    Unfortunately, we're in a cold snap for a few days here in CO so I wasn't planning on running my TR for a while, but when I next do I'll take some similar shots of the O2 sensor outputs on the oscilloscope. And if anyone's got a similiar scope shot of their K-Jet with Lambda running closed-loop at idle, please post (doesn't have to be an F -- any make using K-Jet with Lambda would be OK).
  9. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Since 91tr did not approve of my O2 output wave on the scope, I changed the O2 sensor yesterday and will put it back on the scope this weekend (it's bitter cold here in Denver (-2 as I write this). It didn't change the cold start problem, but it looked original and was due for replacement anyway.
    Steve
  10. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #35 spiderseeker, Dec 12, 2005
    I'm tracking down this cold idle (too low) problem and need readings off of a correctly working 308QV.
    The readings that I need are the FV duty cycle when at cold idle and when at warm idle with the O2 sensor "unplugged" just to get some comparison. I also measured the voltages from chassis ground to each terminal. With the engine off, the brown -blk stripe wire is grounded, but with the engine on it's 13.5v which I think is wrong. I read 12.3v on the other terminal. I suspect both are wrong but I need to know what they should be to track it down. Attached is a view of the FV(Frequency valve-also called metering valve)
    Steve
  11. Steve Magnusson
    26,932
    #36 Steve Magnusson, Dec 18, 2005
    Here are some shots of the type of voltage signal coming from one of the O2 sensor on my KE-Jet US TR when at warm idle running closed-loop (the amplitude is 500 mV/div and the timebase is 200 ms/div). These transistion from lean-to-rich and rich-to-lean (which take about a second total) occur anywhere from right after one another to several seconds apart (i.e., the system doesn't do a "correction" until the O2 signal strikes one of the boundaries). I sketched in the faint areas of the traces with the dashed white line by hand just to show the slowish "S" shape better:
  12. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #37 spiderseeker, Dec 27, 2005
    We'll I finally have my fuel pressure test kit, so I ran the tests today using Carl Roses' excellent procedure. These are my results:
    cold control press 1.8bar (23 psi)
    after about 3 min- 3.0 bar (44psi)
    after about 5 min- 3.5 bar (50 psi)
    System press 5 bar (72psi)
    Engine off, check after 20 minutes, pressure still at 40 psi (35psi after an hour- so no leaky accumulator or injectors) - the numbers look close to me, I still don't understand why no fast idle but I won't give up!
    Steve
  13. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Steve I too look forward to your answer
  14. Steve Magnusson
    26,932
    Steve -- Well, at least it's good to know that your WUR is quasi-OKish (if the WUR temperature for your "cold" test was in the mid-50~mid-60 deg F range). Have you been able to confirm that the system does run closed-loop at warm idle -- i.e., do you see similar lean-to-rich and rich-to-lean oscilloscope transitions on the O2 sensor output at warm idle? For example, although you've reported (privately) that the duty cycle of the electrical signal going into the FV coil is present, and does seem to be different for different modes, it doesn't gaurentee that the FV is actually affecting the fuel pressure as it should (not saying that this is the problem, just pointing out that you've quasi-verified an "input" and not the actual "output" from the injectors -- which takes a piece of gear so rare and complicated that I'm starting to doubt if it even exists ;)). If it does run closed-loop at warm idle, I'd take that as a good sign that the FV is OKish. I also like Brian's prior suggestion for a quick and easy way to see if the FV is working -- at warm idle, is there a bad reaction or no reaction if you unplug the FV?
    One other thing you might try is doing some more in-situ testing/confirming of the AAV. For example, if you remove the air hose that goes to the AAV at the air box end -- does it really suck in extra air at cold start-up and not suck in extra air when warm? Or similarly, if you "pinch" that air line closed does it affect the cold-idle and not affect the warm-idle?
  15. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    The WUR temp was about 50 yesterday when I tested it, I had thought that much colder temps is where it needs to be tested, since no cold fast idle is the problem. Maybe 23 psi is the lowest pressure coming out of the WUR- I think that would be bad. I will try unplugging the FV and see what happens also. I did notice something that might be a clue though, when I close the valve on the pressure gauge (bypassing the WUR), the cold idle went from 700-800rpm and chugging to about 1300 rpm and much smoother.
  16. tbakowsky
    Sep 18, 2002
    20,037
    The Cold North
    Tom
    Try this out.. With the engine running using a pair of needle nose pliers, squeeze the main air hose which comes out of the aiflow meter too the AAV, note any change in the engine RPM. If it does not produce any change in engine RPM..you AAV is stuck CLOSED.
    Check for 12V at the AAV connection. There should be constant power here with the engine running or key on engine off. If you have power and ground(very important to check ground also)..remove the AAV and try to clean it out..this sometimes works, but not all the time. On some of the valves there is a set screw on the side. Sometimes you can tweek this guy for a bit more air to enter the engine. Measure resistance of the AAV with an Ohm meter. If it comes up open circuit..you have found your problem.
    You can also do an on car test. Stick the valve in the freezer for about 10 minutes. It should FULLY open. Now take it back to the car and plug it in, don't hook up the hoses. Turn the key on. Watch the valve inside. With in about 5-10 minutes it should close up gradually. If not replace the AAV.
  17. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    tbakowsky: I can see through the AAV, so I know it's open. The 12v at the connector , heats the temperature sensitive valve that CLOSES it when hot,(actually fights the open condition). The AAV "shouldn't be the problem but I have to verify that the hoses to the AAV are unrestricted.
    Steve
  18. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    stepping back to the theory for a second, I understand that the AAV creates an airway around the throttle plate. So, more air into the engine. Since the air is coming from the metering box, you get more fuel too. It has exactly the same effect as holding down the accelerator pedal a little.
    The WUR, frequency valve/O2 sensor, and cold start injector all mess with the fuel mixture by either fiddling with the fuel pressure (so the injectors squirt more or less fuel), or in the case of the cold start injector, you have another injector dumping fuel into the intake plenum.
    In the case of the WUR, it's enriching the mixure when it's cold, and on some cars under acceleration if the WUR has a vacuum sensor.
    So how would making the mixture richer/leaner effect the idle speed?
    The other puzzle piece is the throttle position microswitch (on a 328, anyway). I assume the computer is looking at it and messing with the frequency valve. While the switch unit is capable of detecting closed throttle and wide-open throttle (WOT), the WOT switch is not used...only the closed switch. If the switch is bad, what happens?
    p.s. the right-angle hose exiting the AAV has a tendency to kink at the bend if the main air hose is pushed too far rearward, so check that when everything is assembled.
  19. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #44 spiderseeker, Dec 28, 2005
    Ok, just to confirm AAV, when I disconnect the hose end at the air intake when cold, the idle rises to 1100 rpm, when connected it's about 1000 rpm, so that's about right, as the engine warms up it struggles at about 700-800 rpm as the AAV valve closes. When it finally reaches warm idle it clears up and idles fairly well.
    I also unplugged the FV (frequency valve) at warm idle and it does cause some chugging but keeps running, so it appears to have an effect.
    Also attached a scope reading of the FV closed loop at warm idle
    Steve
  20. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    if I understand this stuff right, when the car is warm, it runs closed loop and the frequency valve is mucked with by the computer/O2 sensor output to adjust the fuel mixture to hit the emissions target.
    when the car is cold, it runs open loop, the frequency valve runs at a default
    50% (I think) duty cycle, and the air/fuel mixture is determined by the AAV and WUR responding to engine termperature and time, along with the base fuel mixture setting in the metering head.
    when you yanked the hose to the AAV, what did you do to the open hose end and the open barb it connected to? Plug one and/or both?
    The scope output looks bad to me...I'd expect a square wave something close to a 50% duty cycle (+/- 5%). What you have implies the base fuel mixture is off.
    When the car is warm enough to run closed loop, the frequency valve is compensating, but in open loop you're pretty far off. 'course, that assumes that an incorrect mixure would cause the rpm's to drop...hence the question I was asking about the relationship between rich/lean and idle speed. I would guess that too lean would cause rpm's to drop, but too rich is ok assuming the plugs aren't fouling...hopefully someone knows.
    if you unplug the frequency valve, the duty cycle is zero, which I think would max lean out the engine.
    You can use the frequency valve waveform to adjust the mixture. Assuming the thing is running closed loop at the correct idle speed and the O2 sensor is ok, tweak the mixture to get a 50% duty cycle. At that point, you could theoretically unplug the O2 sensor and you'd see no difference in the emissions measured with an exhaust gas analyzer.
    With the base mixture correct, the WUR and AAV should produce the right mix in open loop.
    Did the car have to go through emissions? Maybe someone fiddled with the base mixture to get it to pass, and therefore hide a different issue.
    Time to grab a scotch and wait for people to tell me how I screwed all this up :)
  21. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Wolftalk- you seem to have a much better understanding of CIS than I do. (I'm an old carb guy) I'm still trying to understand how all this works(bought Probst and Aird's books). If I understand it, I can fix it and hopefully help many others on this board with the same problem. I need to know everything involvd with fast idle. The startup injector is not involved after startup as I understand it. AAV and WUR are but what else? I "think" the WUR is ok but still not sure. (I'd like to test it at 20 degrees.) My dwell readings are high on the FV about 35-40 closed loop.Should be 22.5(45 degrees) for 50% duty cycle.
    When I removed the hose from the WUR, I sealed up the air intake end. There was plenty of suction coming from the WUR end , so I know the WUR was open.(till warmup started)
    It's funny that you mentioned emissions. It passed emissions in Nov BUT the PO said that it was set lean to pass tough Texas emissions and that I should leave it that way till it passes Denver's too, which it did. Remember, emissions is ONLY done on a warm engine and it runs well after the warmup period. I was surprised to hear they tuned it lean , since I keep hearing that 308qv's usually have no problem passing emissions, when set to the normal mixture. I have a gas analyzer coming soon, so I can take CO readings to further track down the problem.(no fast idle at startup)
    I also have vacuum pump now, so I can test any vacuum valves involved as well.
    Steve
  22. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    I apparently don't understand it either...if you pulled off the AAV hose and let extra air suck into the plenum, that would lean out the mixture since that air is not being measured by the metering plate (which would add more fuel to compensate). But you said the rpm's went up, and then when reattaching the hose the rpm's went down. I suppose more air gets in with the open hose, and if there is enough fuel being dumped in already the rpm's would increase.
    Anyway, my understanding is that it's only the AAV that is responsible for fast idle (QV's and 328's), and it does it by adding more air, and indirectly more fuel, to the engine.
    When an engine is cold, the fuel will tend to condense on inconvenient places like the cylinder walls, so extra fuel is dumped in to make sure there is enough hydrocarbons floating around to blow up effectively. That's what the cold start injector does, and to a lesser extent the WUR. The cold start injector is pretty much out of the picture in a few seconds, so the WUR does the remaining enrichment until the engine is warm. Then the WUR does nothing until you stomp on the gas, at which time its vacuum sensor adds more fuel.
    If the cold start injector is bad, you would have a hard time starting because you wouldn't get the extra fuel squirted in for a few seconds during cranking and initial start.
    The thermo-time switch could fail in two ways. If it never closes the ground side of the circuit for the cold start injector, you'd have the same hard start problem. If it is always grounding the cold start injector, you'd have lots of extra fuel dumping in all the time. You can test the second case by pulling off the plug on the cold start injector and making sure you don't get 12V measuring across the two pins after the engine is started (or when the coolant is hot and the ignition is on).
    If you do have a bad thermo-time switch and someone leaned out the mixture to offset the extra fuel getting dumped in, I don't know how that would effect idle.
    Another thing I don't understand is what effect the fuel ratio has on idle speed. If the air into the plenum was constant, but you mess with the amount of fuel, what happens to the rpm's?
    Yet another thing I don't get is: you see an initial idle speed of around 1K, and then it drops as the AAV closes. That's what's supposed to happen...but then the idle for some reason pops back up to 1K again...does that happen when going into closed loop? If you yank out the O2 sensor output plug to force open loop (the single wire, not the two wire O2 heater plug), does the idle drop again?
    Check the throttle microswitch on the side of the throttle body. When mine got cruddy, the idle tended to pop up a couple hundred rpm...why, I never got around to figuring out....it's something the computer was doing. If your switch is bad, and someone misadjusted the main idle to offset, you'd get the symptoms you are seeing. The true idle is low at 800 rpm, and it hits 1000 during fast idle and at closed loop with a bad microswitch, but is low when open loop with a closing/closed AAV.
    When the system is running right, it has no problems getting past california emissions.
    Between the gas analyzer, the scope, and the fuel pressure gauges, you can
    test everything except the injectors themselves. If the O2 sensor is good, the gas analyzer is redundant. One of the FI books talks about using a dwell meter to set the base mixture on cars with lambda, but the scope is better.
    I guess at this point I'd check the thermo-time switch, then make sure the base mixture is right, then see what happens. If you do mess around with the base mixture, I'd love to hear what the effect is on the idle as you lean/enrich the mixture. Remember that you need to remove the allen wrench and cover the hole with your finger before paying attention to the reading, and don't rev the engine with the allen wrench in the adjust screw...you can bend stuff inside the metering head.
    I think that's everything I understand and misunderstand about CIS...now I'm hoping someone will fix the mistakes and make it coherent :)
  23. tbakowsky
    Sep 18, 2002
    20,037
    The Cold North
    Tom
    Basicly the fast idle system on the 308 is a controled vacuum leak. It is controled by restriction and the AAV provides this restriction. If you have no restriction and the AAV is working correctly, the idle has no choice but to go up. Maybe it time to look at the mechanical side of things..like pinched or blocked hoses etc.
    Going by what you have tested..everything in the system seems to be operating as it should. All fuel pressures appear to be ok..you have power in all the right places, and you have tested the AAV for propper function..which by all accounts has passed. All thats left is a mechanical issue really.
  24. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    On cold idle, I expect idle speed to be about 2500 rpm(fast idle) , like I said, I only get 1000 rpm and that begins to drop almost immediately as the AAV heater warms up and closes off the extra air.
    I'm going to try and adjust the mixture tomorrow and do a vacuum leak test on the WUR.
    I removed the airbox today, so I could access the WUR vacuum line for testing. (I'm going to stencil the airbox now that it's off, looks bad in my pictures).
    I'll try to test the throttle switch as well.
    **Thanks for all the great comments and suggestions, please keep them coming!
    Hopefully get this resolved soon, I know several 328 guys with the same problem too.
    Steve
  25. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    on my 328, fast idle is more like 1500-1800rpm. 2500 would be the cars that used the on/off vacuum operated valve bypass path around the throttle plate (like the '80 gtsi), rather than the progressively decreasing idle/AAV approach.
