Cold Start Valve Removel and Vacuum - HELP NEEDED | FerrariChat
Discussion in 'Mondial' started by Brian Marks, Nov 18, 2018.
  1. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    Image Unavailable, Please Login I’m going thru a restoration of my ‘82 Mondial 8 (2V) and decided to remove all smog equipment, catalytic convs and also the cold start valve - based on a process posted here by Birdman.
    I’m a bit unclear on the routing for vacuum hoses and the electrovalves (square valves with 3 vacuum ports).....is there a clear layout someone can help with ??
    Do these electro valves need to be plugged in or can I eliminate wiring and vacuum entirely from the setup ??
    Would very much appreciate your insight and help.
    Brian Marks
    Cincinnati OH
    513.262.0692
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I would avoid using those type of hose clips with the open ports, they tend to squeeze and damage the rubber hose surface, also they can be a pig to remove when they get a few years on them- have a look for some solid stainless types
  3. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    Thanks - not exactly the question I was posing.
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,678
    Argent/Brasil
    Guido
    Cold start valve : you can leave the valve in place, just disconnect the blue electric connector. Be shure that valve is not leaking even with the connector of !.
    Guido
  5. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    I’ve removed the ColdStart Valve entirely and plugged the hard pipes.....question now is can i eliminate the ElectroValves all the way around and just plug up the vacuum as needed ???
  6. Steve Magnusson
    26,839
    #6 Steve Magnusson, Nov 20, 2018
    If you've physically removed the cold start air valve and blocked the two large air conveyance ports in your photo = yes, you can remove the ElectroValve associated with it, and just plug the small vacuum line going to it (or cap off the vacuum source). However, your post says "ElectroValves" -- the other ElectroValves are associated with the EGR system and the Air Injection system (IIRC). If you have also physically removed all of the components associated with those systems = you can remove them, too, and plug their vacuum sources.
    The only issue you might have is the yellow "cold-running" warning light in the dash may not work correctly (my foggy recollection is that the cold start air valve ElectroValve coil wiring is involved in its operation). My guess would be that it would just never illuminate with the cold start air valve ElectroValve missing/unplugged; however, if it stays "on" all the time, give a shout and I'll see what might be done.
    PS I hope you leave the wiring harness intact and uncut so that future restoration is possible.
  7. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    Steve - yes thanks for the info. I actually removed all the US installed smog equipment, along with the air injection and test tubes…basically taking it back to a European 308 engine setup. I’ve kept the wiring loom intact along with installing the electrovalves in their respective locations and will just plug up vacuum source.
    See image below....
  8. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    I love how you pulled the motor! Did you do the red powder coating on the valve covers? How did you do the plugs over the exhaust test ports?
  9. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    JK - thanks, pretty easy with the subframe ~20 bolts and a few connections - it took about an hour to drop onto my table.
    Yes, had the valve covers and airbox powder coated in red crinkle-coat locally.
    Welded the exhaust air injection holes and used red plugs that I bought from a supplier in UK spec’d to match threads to plug. Clean look and eliminates a ton of the crap US Smog equipment - see pic.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just a small time filling job for a sunday afternoon then- best of luck
  11. jkstevens2
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    Beautiful!!!! I thought the test tubes came through the silver heat shield and not where the red head bolts are. You have silver round plugs (4) coming through....Keep the pictures and the examples coming. I am very interested to see how the engine performs. Right now my Mondial 3.2 is not running due to an unknown electrical / fuel injection problem. Scratching my head wondering if converting this over to a carb system would be the way to go.
  12. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    You’re correct - I realized just as soon as I posted that reply I had it backwards in my description. Exhaust test holes were welded shut and buffed clean......the other holds had the air injectors that were already corroded (common problem) and since Smog was removed these had to come out as well ! I thought that red bung plugs were a nice touch.
    I’m planning re-introduce the engine to the car sometime next week - stay tuned !
  13. jkstevens2
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    Red plugs are a nice touch! I am anxiously waiting to see the progress.
  14. jkstevens2
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    I dont have experience with solid stainless straps. My original Ferrari straps have a slot like I am seeing in the picture. I bought all new german made stainless steel with the rounded edge (as to not fillet the side of the hose) at belmetric.com
    I was looking at your earlier posts to see what year your Mondial was.....
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    They are just a better quality hose clip. I had to change the water pump on mine and it had those open style of hose clip which were fitted at its build, took for ever to remove as jammed solid and had to cut in situ to get them off.
