Cold startup: Enzo and F40 | Page 2 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Bill S, Jun 4, 2010.
  1. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    IMO the straight pipe setup is the best sound possible. Mine is stainless, but all the LM pipes I've seen were Inconel. Whatever the case, driving around town off boost is fairly quiet and sounds like a real muscle car. At WOT its INSANE! The only downside as I see it, is its a major cop magnet as they can hear you 1/4 mile away. It also scares the **** out of people when you pass them on the highway. Its also pretty obvious you don't have cats. Other than that, OMG.
    Performance wise you can tune the car via cam timing to deal with the loss of backpressure. I don't think it adds any HP, if anything you might lose a few pounds of torque, but I didn't notice any seat-of-the-pants change either way. But it will probably show up on a dyno.
  2. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #27 joe sackey, Jun 7, 2010
    Bill, I will dig up some more. Note the unfinished pipes, welds and the bracket attachments. Made by Tubi. Remember Tubi work closely with Ferrari and supply units for their F1 cars. They made me a set of straight pipes in inconel for my street F40.
  3. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Now that is an exhaust! And it goes to show you if the GT/LM/GTE had the straight pipes, you know what is the best. Tuned properly of course!
    Joe what is the advantage of inconel? I know it is very pricey.
  4. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    I think it dissipates heat better and has better tensile strength. I think its lighter too. But I DO know it is pricey!
  5. Alex1015
    Alex1015 Formula Junior
    Sep 1, 2005
    949
    The increase in tensile strength isn't terribly useful in exhaust. Instead the inconel forms a protective oxide layer when it is thermal cycled. Additionally, its properties are very stable regardless of temperature.
    It's supposed to be difficult to weld, but I have no experience there. But then again tubi likely has the facilities and experience to negate that point.
  6. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Most people think that removing the exhaust system or mufflers will automatically increase BHP. This is rarely the case, especially in a Ferrari. The exhaust systems are finely tuned to maximize BHP. There is a thing called scavenging that uses back pressure to tune the system to actually PULL exhaust gases out from the exhaust valve ports.
    I would venture to guess that there is nothing you can do to increase the BHP of a Ferrari by doing anything to the exhaust. And that anything you do will almost certainly decrease HP.
    Now if it is the sound you want and not the HP, then it just does not matter.
    aehaas
  7. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Can't agree with you there. Yes, they need to be tuned but I have SEEN Ferraris gain power with exhaust work. My friend gained some 18 RWHP on the dyno on his 355 with his upgrades....
  8. nthfinity
    nthfinity F1 Veteran
    Mar 21, 2005
    7,467
    South East MI
    Isaac not Issac
    Probably more to do with removing two or more of the cats than with the exhaust shape. Most if not all aftermarket headers I've seen are almost exactly the same shape as the factory headers.
  9. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Pretty sure he just did headers and a Capristo, kept the cats if I recall, as he lives in Cali. But to make a statement like Ferraris can't gain power with aftermarket exhaust is outlandish and incorrect. Especially if tuning is done, there is a reason race cars use little or no mufflers. It makes (or doesn't lose) power.
  10. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #35 Bill S, Jun 7, 2010
  11. nthfinity
    Mar 21, 2005
    7,467
    South East MI
    Isaac not Issac
    There are performance cats that will pass CARB... every set of 355 headers I've seen are the same shape as the factory sets, so how can performance be gained?
  12. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    Cats on the F40 are a fire hazard IMO
  13. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Shape isn't the only thing that can gain power you know. Size of the tubes, how smooth the tubes are, material, if they have less emissions bungs, there are many factors....
  14. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Why is that? I mean yes, the car will run better without, but if they are maintained that should not be the case.
  15. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    The F40 motronic ignition system is pretty antiquated by modern standards (discalimer - please note I am not a mechanic but this is bits and pieces I have put together from private conversations by experienced mechanics, so take it for what you paid for it). The system runs the car rich until WOT (or somewhere abouts), which is better for the car as a lean air/fuel mixture is suicide for a turbo car. This can be seen by looking at the tailpipes of most F40s are black, and even some with burnt bumpers. This rich air/fuel mixture loads up in the cats, and when you finally open it up, this either burns the cats (over time) or starts a nuclear meltdown if the cats are already burnt. The all-to-familiar slow down condition will occur, if the car has working o2 sensors. This is one of the reasons many F40s have burnt to the ground, and the reason I have a fire system in my car.
    Now I suppose if a car was properly tuned, driven regularly (ie miles :eek:) so the injectors weren't gummed up and dumping raw fuel into the cylinders, and the owner went through the proper warm-up sequence each time, well this condition would not occur. But sadly this is not the norm.
    I apologize in advance if i got any of this wrong, but it mirrors my personal experience.
    IMO the cats are to save the environment. For the number of miles I put on my car per day, in comparison I'm a bigger threat smoking my daily cigar..
  16. ibesuc
    ibesuc Formula Junior
    Jun 16, 2009
    489
    NY
    Steve
    Nice video Bill!
    As a CS, Enzo, and F40 owner you could probably answer something I've always wondered:
    I'm sure the ownership of these three cars is second to none, but do you ever long for a more luxurious Ferrari, maybe a ragtop, like a 430 or a 599? Or do you find that when driving the Enzo for example all your "Ferrari needs" are filled?
    Steve
  17. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    The Enzo, F40, CGT, CS, GT3RS and Ruf are all very diiferent. No one ever gets boring, that's for sure! But if I don't take the Enzo out that day, I usually feel I need to take it out the next day. The Enzo is very special and it always satisfies.
    We could get a 599, 430, 997TT or even a Veyron, but then it's confusing. When would I drive them? On a long trip? Taking friends, family or clients out to dinner? Select one for a spirited drive over all the others? Probably no to all. So our choice was the Mercedes E63 for that type of stuff. It doesn't try to be too sporty. It's high performance without sacrificing luxury. You can take the parents out to dinner, or take the nieces and nephews for a spirited drive to the mountains. You can't do that with the 599 and 430.
    In summary, for me and my wife it's fun to be able to pick from several very thrilling rides... or the E63.
  18. amenasce
    34,398
    Joe Mansion
    Have you driven the Veyron? Did you like it?
  19. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #44 Bill S, Jun 18, 2010
    I have driven a Veyron. When you're not accelerating, it feels like a sporty Mercedes AMG sedan, but arguably not as refined or luxurious. I suspect it handles noticeably better, but I couldn't test that. It did feel rather light and responsive for its weight. Kind of like a Nissan GT-R.
    When you floor it, it accelerates extremely strong with no drama at all (no wheel spin, no loud exhaust sounds, etc). I saw 150 when I thought I was only doing 120. Shifting is instant.
    In summary, the Veyron is exciting when you floor it. But you're not going to do that too often on the street in that car. Acceleration will always be a thrill and cars will continue to get faster, but there needs to be something else to keep the thrill alive. Nearly all Ferraris and some Porsche cars like the GT3 RS have that something else. And the sound at cold start up and idle, which this thread is about, it just one of those little things that adds to the thrill of owning a Ferrari.
  20. ibesuc
    Jun 16, 2009
    489
    NY
    Steve
    I see. That works!
    The E63 is a great car. Do you think you'll ever pick the new one? I recently test drove one and it was great. You feel like you driving a race car when you put it to the boards, but then you look back and see a full size back seat. Though the new 6.2 is less torquey then the old 5.5, I like how it is much more free revving. As far as the new E, I like the back of yours better, and the front of the new one is so much more aggressive to the more refined classier front on yours. I can't decide which front I'd rather have. Regardless, the best part about the new E63 is the tranny. That would be a huge buying factor for me.
    Steve
  21. ibesuc
    Jun 16, 2009
    489
    NY
    Steve
    A place where I think the M5 lacks.
  22. Steve
    Steve Formula Junior
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    I have three exhausts for my F40:
    -Stock
    -Tubi (sport)
    -X-ost (straight pipe)
    I also have three things to put in the "cat" spot:
    -Stock cats
    -Tubi sport cats
    -X-ost straight pipes
    After running different configs with all of the parts, my favorite is the straight pipes. I've had the car tuned to run optimially with that exhaust setup, and I love it.
    Plus, pulling out pictures of my exhausts on my iPhone got me impromtu tours of both Tubi and X-ost when I was in Maranello last year. :)
  23. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    I was thinking of doing the same thing with the LM exhaust system that Joe posted.
    Can you tell us what tuning was perfomed and who did it?
  24. Steve
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    Hey, Bill. I'd really give the guys at X-ost a look. Build quality is idential to Tubi (I've got Tubis on my other Ferraris and my Maserati QP), their shops are within spitting distance of each other (and the factory), and they were really easy to work with - and about 1/2 the price of Tubi. :) http://www.x-ost.com/
    I had a local mechanic here in the Seattle area (Carlo @ Alfa of Tacoma) do the initial tuning on it after the new exhaust was on (mostly timing-related), and then I tweaked the wastegate spring tension settings myself while at the dyno (I recommend very slight changes here if any).
  25. Steve
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
