Sold - Collection of TR Parts -- New and Used -- $400 for all | FerrariChat
Sold Collection of TR Parts -- New and Used -- $400 for all
Discussion in 'Ferrari Parts & Collectibles' started by Steve Magnusson, May 25, 2024.
  1. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,839
    Some useful (IMO) TR stuff leftover from my TR ownership including other TR stuff that some prior TR Owners graciously donated to me after they sold their TRs. I need the room as I now seem to be acquiring Mustang stuff ;). Sold as a lot for $400 (and I’ll pay for the ground shipping to the continental US).
    Word file attached (for easier printout).
    New TR parts
    1 each 140567 Distributor Cap Center Brush
    1 each 10300240 Thermostat Drain Plug
    1 each 173999 512tr linkage ball joint
    2 each 154985 Exhaust Pipe Donut Gasket
    1 each 121788 4-position spark plug wire clip
    2 each 121789 3-position spark plug wire clip
    1 each 61490200 pininfarina badge (stick-on type, no studs, BlackBarts?)
    3 each 150191 Rod Bolt Access Cover Gaskets
    1 each 131181 Harness Cable Clip (for injection ECUs large harness)
    7 each 129544 Harness Cable Clip (for harness running on top of engine)
    1 each 102947 Rubber Vibration Mount
    4 each 111182 Anti-tamper caps (for throttle plate adjustment screws)
    4 each 10519377 Washer (for door strakes)
    4 each 14051849 Acorn Nut (for door strakes)
    Used TR parts (useable)
    11 each 1124792 Spark Plug Extenders
    12 each 113975 Steel Bosch CIS Injectors (Bosch 0437502010)
    1 each 121748 Differential Pressure Switch
    1 each 61766300 Air Pump Relay “B” (Bosch 0280230012)
    1 each 119409 Distributor Cap Gasket
    1 each 125136 Fuel Pressure Regulator (Bosch 0438161001)
    1 each 106950 Brake Pedal Pad
    1 each 106949 Clutch Pedal Pad
    1 each 61538100 Footrest Dead Pedal (poor condition)
    1 each 124581 Distributor Cap
    1 each 126139 Distributor Rotor
    1 each 123383 Steering Column Tie Rod
    1 each 131472 RH Window Switch
    Used TR parts (not useable, but still have some potentially useful components)
    1 each 116987 Speedometer Sensor
    2 each 136592 Fuel Tank Strainers
    1 each 127014 Power Transistor Assembly
    Other Misc Parts
    2 each (116750) Hill Engineering Timing Belt Tensioner Bearings (new)
    (somehow “rejected” by the guy who gave them to me, but they look pretty good to me)
    1 each (63011800) Engraved chrome-plated Steel hood/trunk cable release lever (new)
    1 each (124961) SRI 16mm Heater Hose Coupling and Clamps (new)
    2 each (121166?) SRI 32mm Coolant Hose Couplings (new)
    1 each OGRacing 25mm Steering Wheel Extension w/ Screws (86mm OD)
    1 each About 90% of the SRI Gold Connetor Kit for a TR – many connectors and tools and instructions
  2. Auraraptor
    Auraraptor F1 World Champ Lifetime Rossa Owner
    Sep 25, 2002
    13,991
    MO
    Omar
    I will take it; busy at work right now so will reach out later tonight
  3. Steve Magnusson
    26,839
    Very good -- will await to hear from you.
