Column Stalk Rubber Loose | FerrariChat
Discussion in '456/550/575' started by Akula, Oct 27, 2014.
  1. Akula
    Akula Rookie
    Dec 7, 2009
    28
    Hi guys, the rubber grip on the column stalk of my 575 is loose, so in order to turn on the lights, I have to reach past the rubber part to turn the plastic part. I just want to check if anyone else has had this problem, and how you dealt with it. Appreciate any advice on this!
  2. masinari
    masinari Karting
    Jun 30, 2005
    155
    Manhattan; California; Italy; Shanghai
    Matthew Asinari DSM
    Yes. I have same exact problem. I think best way is to put a drop of cyanocrylate glue on a needle and go in between the rubber and the stalk to glue it. I am thinking of also using contact cement as a better option because it can be removed/cleaned better than crazy glue-- which is difficult to handle/very damaging if it drips.
    I never bothered fixing b/c I usually grip it tight on the rubber and it turns. This low quality issue goes with the engine bay stickers that peel off on their own, sticky instrument/interior
    panel controls, etc. and all the annoying Ferrari minutia that does not work.
    Let me know if you also figure out an easy solution. Thank you.
  3. 308 GTB
    308 GTB F1 World Champ
    11,718
    New Jersey
    Barry Wolinsky
    Mine does the same thing. I have to grip the rubber tight to turn the switch also. Maybe it's like that on purpose to ensure we consciously turn the lights on properly.
    Another innovative first by Ferrari! :D
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Inject a high quality superglue (BSI (Bob Smith Industries) Bob Smith Industries | Adhesives
    Supergold, available at good hobby stores) between the rubber and plastic portion and it will fix the problem.
