Compare any 2016 car side-by-side | FerrariChat
Discussion in 'F1' started by freshmeat, Mar 7, 2016.
  1. TheMayor
    106,086
    Vegas baby
    #2 TheMayor, Mar 8, 2016
  2. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,714
    ESP
    Bas
    Again. You're so wrong on this.
  3. TheMayor
    106,086
    Vegas baby
    Haas is Ferrari lite. Admit it.
  4. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    they all look the same......
  5. SDS
    SDS Karting
    51
    Toronto, Canada
    SDS
    That is what I'd call a loosing proposition....
  6. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    #7 4rePhill, Mar 8, 2016
  7. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,284
  8. TheMayor
    106,086
    Vegas baby
    Except Ferrari gave Haas the engine and chassis.
  9. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Not true.
    Dallara did their chassis.
    Engine & gearbox are from Ferrari.
    Cheers,
    Ian
  10. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Pretty much.
    That's the technical regulations & aero guys at work. There's not a lot else they can do within the regs these days.
    They're all striving for the 'Coke bottle' shape. They all want to blow the diffuser as best they can. They're all running pretty much the same tunnels & CFD programs, so it's hardly surprising they all arrive at the same 'solution'.
    Obviously another reason they're all so damn close together. Which is fine with me. ;)
    Cheers,
    Ian
  11. Jack-the-lad
    Jack-the-lad Seven Time F1 World Champ
    It's what makes them "relevant to the cars anybody can buy." :D
  12. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,476
    KL, Malaysia
    MC Cool Breeze
    I would agree.
  13. Bas
    Mar 24, 2008
    42,714
    ESP
    Bas
    but it isn't. Chassis and aero are completely different.
  14. 11506apollo
    11506apollo F1 Rookie
    2,699
    Tx Co Ca
    so it is down to 3 factors....pilot skills, tire strategy and horsepower......basically.
  15. classic308
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    So true. It's what's under the hood that counts....
  16. Jack-the-lad
    Take out tire strategy and you've got yourself a real racing series!;)
  17. classic308
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    it would be a real race series if they allowed testing/development......tokens are for games.
  18. LightGuy
    LightGuy Four Time F1 World Champ
    45,566
    Texas
    David
    They DO look very much like each other.
  19. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Yeah, but as that 'viewer' above shows, you can pair pretty much any of them with the same result.
    Cheers,
    Ian
  20. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    While I too would like to see more testing allowed, they're all very definitely constantly developing the things. The most obvious is the way the front wings evolve over time, but they'll try different floors and sidepod arrangements, particularly the turning vanes etc.
    "If you're not developing, you're going backwards."
    Cheers,
    Ian
  21. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    "Blown" front wheel nuts are the thing now! - Having the brake duct air exit through the centre of the front wheel nut in order to make a secondary use of the air by guiding it out and onto the rear floor section.
    Then there's the "S" duct in the front nose cone to create a negative pressure under the nose of the car to pull it onto the circuit for more grip.
    Mercedes are investigating serrated leading edges to break up the air particles to make better use of them.
    The way the designers of modern F1 cars guide and manipulate the air flow, not just over, under and around the car, but also the air that goes through the car, is quite mind blowing!
  22. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Bas,
    The bodies are so close to identical (like the difference between an Alfa 156v6 and 156 4cyl), so how can you say the aero is completely different?
    If I was Haas, I'd be happy to be Ferrari-lite cause that means you are getting support. It could be worse, could be McLaren-lite!!!
    No wonder F1 is stuffed, when we debate differences in bodywork that would be less than 1 degree. How can the non-OCD be remotely interested?
    Pete
  23. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1 Pretty cool stuff! As noted, we've got a little debate going in Av-chat on the topic right now - Some of the guys there are damn helpful.
    However, & I admit I got this wrong initially, they don't want to "guide air into the rear floor section" - They're trying to do the exact opposite IMO - They want to keep as much air *away* from the diffuser as they can - Hence the blown wheelnuts & all kinds of flow modifiers generating vortices down the outside of the car. I believe they're trying to stop as much "bleed" going underneath as they can. That way the air down there has to speed up, & as we know, hi speed air is low pressure air.
    +1
    Impressive stuff indeed.
    I can't find any pix now (got any?), but it was Merc's serrated leading edges that caused me to start the thread in Av-chat - I asked the guys there if they knew why they were doing it. Got a few "theories", and the thread's drifted along since.....
    Cheers,
    Ian
  24. Bas
    Mar 24, 2008
    42,714
    ESP
    Bas
    Ok, so the cars are almost identical. Why then is the Mercedes so utterly dominant? It has the same engine as the Williams, as with the Force india and previously Mclaren.
    I can tell the difference between the cars. Sure, paint them all white and it's not a 1-2-3 identification, but I'll be able point out the differences. The average person quite simply wouldn't, granted.
    If we go back 20 years in time It'd be a lot easier to paint all the cars white and point out which is which, even as they drive by...but the thing is, they've learned that one certain way is the fastest way the car is. Take away all the computers and guess, what, all the car will still look the same mostly, because they can't unlearn what they've learnt. It's simple evolution at it's finest.
    The haas is quite a bit fatter, and actually has a lot of influence of last years Ferrari, but with 2016 engine and suspension. Compared to this years Ferrari though...no it's definitely not the same as the Ferrari. If we're going by what you're saying, then what would be truthful is if Bob said ''that Haas looks the same as all the others!''
