Comparison of '13 & '14 car dimensions? | FerrariChat
Discussion in 'F1' started by Fast_ian, Aug 7, 2013.
  1. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Hey,
    All this talk of a 'shake up' and the much vaunted new specs having a big effect on packaging etc got me wondering..... Has anyone got (a link to?) a side-by-side or overlay style CAD drawing comparing the two?
    Personally, I reckon the status quo pretty much remains, unless one of the powertrain suppliers gets it really wrong.
    And neither do I think they're gonna look much different to today's things either. IIRC, I did read something about Pirelli asking for wider rears to be allowed in order to handle the extra torque though........
    Cheers,
    Ian
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,845
    Atlanta
    John!
    #2 Ferraripilot, Aug 7, 2013
    I'm expecting a revised sidepod treatment to be the biggest visual change other than the lower noses and 15 cm narrower front wings. The sidepods I expect will be shockingly small.
    My reasoning behind the sidepod treatment is I believe something clever will be done with the intercooler(s?) packaging, and the exhaust tubing will indeed be much tighter because all pipes will feed straight into the turbo thus freeing up gobs of room in that rear sidepod area which is currently reserved for EBD bits.
    BBC reporting Pirelli are wanting wider tires due to more power out of the new powertrains and more downforce.
    Crazy times if they can get rid of EBD, use 1.6L engines, shorten the front wing, ditch the beam wing, yet still be either as fast or faster with the only benefit from 2014 regs being that they will probably be able to have smaller sidepods and engines with perhaps a touch more power.
  3. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    They're still gonna suck. ;)
    Interesting comments, cheers!.... Haven't read the rules in a while, but IIRC, the turbo positioning is more or less fixed. And we know turbos generate some serious heat. I guess they'll all want as tight a package as possible (don't we all! ;)), but "similar" power is going to generate "similar" cooling requirements, so we'll see how small they can go. "The more things change, the more they stay the same."
    OK, thanks for confirmation.
    Indeed. They'll still suck though! :D
    Cheers,
    Ian
  4. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Um, I think with the Turbos they are going to blow...
    Just sayin'. ;)
  5. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Before we get all cocky, let's wait for the cars to actually come out. IMO, they're going to be 2+ seconds slower, aka lightyears. 4+ seconds slower than the V10s.
    The sound...eh we'll see. From what we've heard so far GP2 will sound better.
  6. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    I have confidence that 2014 cars will be within half a second of where they were at the beginning of 2013. The smaller sidepod treatment will bring great opportunity in other areas. I suspect the integrated driveshaft/a-arm covers will be played with for more downforce to take place of losing the beam wing.
    2014 cars will be beautiful if nothing else.
  7. kylec
    kylec F1 Rookie
    3,670
    Orlando
    Bold statement.
  8. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    The front wing will still be huge, but lessening the snowplow look will be a good start.
  9. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    My guess is we will see complex multi-element front wings with endplates circa 2004 and prior which were more of an air dam with no side exits.
  10. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    #10 Ferraripilot, Aug 9, 2013
    found this.
    additionally, many designers are going on about cooling needs for the electronics and the little turbo motor as a challenge.
  11. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    I'm not quite sure where you're coming up with this. If anything, they are going to need additional cooling for all these new recovery systems. Plus they have an intercooler now which they didn't before.
  12. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    That rear wing will never look right. They seriously need to widen it quite a ways to give the card some appearance of balance.
    Mark
  13. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    09+ F1 cars are the ugliest ever by a long shot. The proportions are all wrong.
  14. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    My conjecture is based on 2 major components being much small and routed differently for 2014. 1) the exhaust manifolds can be made very small and tucked into the engine, piping will be routed directly to the turbo as opposed to the wide elbowed manifolds existing now purely for the benefit of EBD blowing, 2) EBD and bodywork designed specifically for assisting EBD extraction will not longer be present
    The only additional component the new powertrains bring to the table which are somewhat a challenge to mount are intercoolers, and there seems to be a great deal of conjecture that one sidepod will be used to cool the engine coolant, and one sidepod will be dedicated to an intercooler while ballast will obviously placed on the intercooled side to balance it to the coolant filled radiator on the opposite side. That is certainly what make most sense to me at this point anyway. Where else would they stick a large intercooler?
  15. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Could they run twin intercoolers?
  16. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Gadzooks!
    Its a platypus.
  17. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    they could, if they piggy-backed the intercooler to the radiators on each side. I don't see much sense in it though. perhaps.
  18. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    It would be really cool if they figured out some way to make the intercooler and aerodynamic component though. An intercooler is technically not bodywork so it doesn't fit into the rules of where bodywork can and cannot be placed.
  19. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    Hasn't that been tried before?
  20. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    Ian would know......
  21. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    OK
    But you wake him.
  22. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :) watching the cricket.....
    I honestly don't recall inter coolers being used as 'aero aids', but guess its doable. IIRC, back in the day they were (mostly?) water/water rather than water/air. Big ass radiators.
    Cheers,
    Ian
  23. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    I assumed that's what put you to sleep.
    There were experiments with surface mounted cooling devices. As far as I remember they all failed.
    Happy Friday.
  24. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :) Never!..... Shame for the Aussies that we've already retained the Ashes (won 2, drawn 1 in a 5 match series. As the holders, we get to keep 'em. Very nice!)
    Back at ya. I suspect at least some of 'em will play with 'bizarre' solutions. Technology's come a long way since the last iteration.......
    Cheers,
    Ian
  25. Ferraripilot
    May 10, 2006
    17,845
    Atlanta
    John!
    I have to wonder if teams are going to attempt integerating water radiators with intercoolers. So, it will be a radiator with 2 inlets and 2 exits, one for turbo air, one for water. Makes sense
