Compatibility ECU Ferrari 360 and Alfa | Page 2 | FerrariChat
Discussion in '360/430' started by 3s-ge, Sep 9, 2022.
  1. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    @360trev - Do you think it would be possible to emulate the OEM ECU with a modern microprocessor?
    one4torque likes this.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,252
    Gibraltar
    360trev
    It is possible but its not easy or cheap. There are several approaches which I believe will be highly beneficial to 360 owners, the first is exercising prevention of failure in the first instance. Lets stop the ecu's failing by removing the root causes of failure...
    ECU Relocation Kit
    We all need to copy what Ferrari did on the F430 and relocate the ecu's out of the environment of the hot engine bay with all its heat soak, noise, vibration and harshness, and put them into the cabin behind the seats. This will without doubt prolong the lifespan of the ecu's delicate electronics. A wiring ecu relocation harness therefore would be a good place to start...
    I'm looking into the feasibility of getting a wiring harness adapter produced and brackets to allow them to fit into the same space as on the F430, just behind the seats.
  3. 24000rpm
    24000rpm F1 Rookie
    trev, have you been able to figure out which elements are responsible for the clicking throttle?
    I have one Chinese superman here that claimed he got one repaired and charged US$1000 for the labor. And he said, I quote, "there's one capacitor and one transistor need to be replaced". Whatever that "transistor" means.
  4. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,252
    Gibraltar
    360trev
    #29 360trev, Sep 28, 2022
    Of course...
    The vast majority of the "ticking throttle body" failures aren't actually due to the component failing but detaching! Indeed they used a Bosch rebranded 6A H-Bridge IC (CJ220 which as far as I can deduce was actually from Motorola originally and based off a 5A rated 33886) and it more than capable of dealing with power requirements and components are rated for the amps drawn so spec wise the ECU power supply circuitry was designed correctly.
    ...However...
    The issue actually comes from ECU engine bay environment heat soak reaching a "critical mass" and with vibration (from say a factory or aftermarket sports exhaust not helping a single bit). During manufacture, the tiny SMD component are machine placed onto "micro" spot solder points before solder is melted. These points imho are the actual design flaws. The amount and size of the solder points which is designed to hold the orange capacitors in place (see pictures) isn't doing its job well enough and they end up de-attaching from the PCB when the case gets toasty. Infact it's really the only thing you can "*easily" repair on the whole board...
    Thus is why you get 'intermittent' working on the ecu based on temperature...Never had to replace any transistors but I did see 2 of the 3 main ceramic smd capacitors on one ecu where loose just suspended in the jelly goop!
    See pictures.. enjoy !
    * easy is a bit of a joke.. Its actually a pita of a job with no guarantee of success. If you have experience and necessary tools to do it you have a good chance but regular DIY is pretty much out of the question...
    modificator, duck.co.za and mwstewart like this.
  5. 24000rpm
    24000rpm F1 Rookie
    I have a cell phone repairer nearby who uses microscopes to fix cell phone pcbs all the time, so I guess he's got a good shot.
    so, let me confirm, the 3 blue circled components maybe detached from the PCB, correct?
    And they are 2x capacitors and 1x transistor, right?
  6. wbt
    wbt Karting
    Nov 28, 2014
    231
    New Zealand
    Wayne
    Those tantalum capacitors are known to fail on the Alfa and Fiat versions of these ECUs too. Looks like vibration + thermal cycling + time causing the issue... Solve one of those inputs and the ECU life should extend somewhat. I would suggest some rubber mounting grommets on the ECU to reduce the vibration shock load and a nice earth lead to ground the ECU alloy case to chassis would do the trick.
    I have my car opened up right now in the process of fitting an EAG gated kit so I may drop some rubber mounts on my ECUs when I pull them out to program them.
    brogenville likes this.
  7. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Hey @360trev..off topic i know but, can you fix the 355 TRW airbag modules?
    hessank likes this.
  8. craze
    craze Formula 3
    Mar 5, 2021
    1,038
    Melbourne
    Michael
    I wonder why they didnt opt to use glue dots behind and suprised the conformal coating didnt provide further vibration resistance
    Mimmo Blue and one4torque like this.
  9. DARIES
    DARIES Karting
    Aug 16, 2011
    113
    well I send them mine, which couldn't be repaired, they dowloaded all the data from mine and reprogramed a new one for me. They send me back the new one along with the original I had sent. so far no problem, works perfect. just sharing my personal experience.
  10. 24000rpm
    24000rpm F1 Rookie
    bad news
    during the opening of the black plastic
    I accidentally damaged the gell, inside of which lies the tiny wires , which I damaged too
  11. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,310
    San Jose
    dc
  12. brogenville
    brogenville Formula 3
    2,020
    Robin
