The bead blasted carb looks really nice. when i was rebuilding mine, i decided to experiment on one of my spare carb bodies, and I ball polished it. In the end, it looked too "blingy" for me, and i opted for the natural "yellowish" finish. Your dont look too blingy, but I suspect after a few months of heat cycles they will dull up to the natural finish Image Unavailable, Please Login Image Unavailable, Please Login
When I did mine, I just soaked them in carb cleaner and 3 turned out brighter, one was dull. I thought about it, left it alone, and installed them back in the car. After a few miles, I stopped caring what they look like because 1) they always were covered by the air box, and 2) there was always a bit of carburetor gunk after a few miles and they were no longer able to look like new. They did run really nice...
I totally agree; but the picture shows a little bit too much of gloss. Either because of the flashlight I used, or because I sprayed the carbs with a small amount of WD-40 to protect them till further assembly. Directly out of the blasting cabinet they have a nice satin like, more matte finish. I simply enjoy creating a set of carburettors looking like new. Next step will be fresh plating of the steel parts. But the company, which will do this for me, is closed till 2nd January. In the meantime I will go on cleaning parts - still a lot to do - and checking small parts. So far I have discovered different slow running jets ( 45, 40, 50 ). More surprises to come. I hope not too many Best Regards from Germany Martin
The 'new' look certainly is rewarding once done. I found it a pain reinstalling the butterfly plates to the shaft and getting them to seal as they did before. I got them and and they worked fine but they just don't seem to be as tightly sealed to the bores as before when closed. I checked this by closing the butterflies and shining a bright LED flashlight under to see any light/leaks through any cracks on the sides. Also, as an added bonus you could shave down the tops off the throttle plate screws so they do not protrude through the throttle shaft when fully seated. This frees up a few Cfm.
a great idea really, but I don't know whether I will dare this Do you mean the slotted screw heads - I think so, because you say 'tops' - or the other ends which have to be punched ? At the moment I cannot proceed like I would like to, because noone works this week and I need some small parts. In the meantime I have discovered, that the seat of the throttle shaft bearings is different. One side is a tight fit, the other a loose fit. Identical on each carburettor. And there is absolutely no visible wear. As opposed to many, who think this is a fault and put Loctite onto the loose bearing I think this is correct, because on basically every bearing design one side has to be a fixed, the other side a floating bearing. Due to temperature expansion. One shouldn't jam this expansion gluing solid the floating race. The inner races are fixed on the shaft, so at least one outer race must be able to float a little bit in axial direction. At least this is a basic mechanical engineering doctrine. Does anyone have a different opinion ? Best Regards from Germany Martin
Hello from Germany, to prevent my thread from getting buried ; today I got my freshly plated parts. Pump covers with levers already assembled. Best Regards Martin Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Hello from Germany, I don' t want to miss showing the final result here. Best Regards Martin Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
great work Martin, if I should ever have a carb car, I will gladly send the whole stuff to you for rebuild
