430 - Complete F1 kit | FerrariChat
430 Complete F1 kit
Discussion in '360/430' started by smggms, Mar 8, 2019.
  1. smggms
    smggms Formula Junior
    Apr 29, 2018
    252
    Matt Godwin
    does this mean the gear box replaced? are these comnon problem in 430 ,,
    i always thought thEy are bullet proof cars .. least maintenance JUST YEARLY fluid service..
    im looking at this car with 32k miles..this service done @ 26k miles
    can this happen again .
    2005 f430
  2. tazandjan
    39,020
    Looks like maintenance overkill to me, but you never can tell.
    whatheheck likes this.
  3. smggms
    Apr 29, 2018
    252
    Matt Godwin
  4. tres55
    tres55 F1 Rookie
    3,553
    Canada
    "F1 kit needs replacement" does that mean they replaced the actuator, power head, accumulator, pump, etc.?
    Sounds like the previous owner may have got hosed by someone too lazy or incompetent to correctly identify the cause of the problem.
  5. 24000rpm
    24000rpm F1 Rookie
    i heard all dealers treat f1 problems this way.
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    No difference than when I asked a dealer about my Spider roof, if it malfunctions, components fail or fabric tears - they said we dont repair those, we just replace the entire roof. I said how much is that? They said "about $12K+.
  7. tres55
    tres55 F1 Rookie
    3,553
    Canada
    For what it's worth, there are shops that can rebuild your entire F1 system for a fraction of that replacement cost, to factory or better condition. I believe they were even able to improve shift times on the 360 CS F1 system, but don't quote me on that. Company is called GTE Engineering. Originally based in Florida but I believe they moved to the North East....NJ perhaps?
  8. Motob
    Motob Formula 3
    Nov 11, 2003
    2,343
    Frederick, Maryland
    Brian Brown
    When the F1 actuator/system has a major malfunction that the dealership cannot repair, they will just sell an F1 kit. It consists of the F1 actuator, hoses, pump, and shift solenoid/pressure sensor block. It comes full of oil and pre-bled. All you have to do is install it and bleed the clutch and E-diff. It is plug and play, very easy for the dealership to install.
  9. 3pedal360
    3pedal360 Rookie
    Jan 11, 2013
    23
    Sounds like it was just the E diff solenoid with an “erratic diff after start up” it’s a very common problem and those are replaced left and right but as everyone has already said more than likely the owner just got taken advantage of.
