Comprehensive Differences 360MC vs Road cars | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by 360trev, Apr 2, 2011.
  1. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    360 Modena Challenge (2001)
    I'm interested to know the complete list of differences between a 360 Modena and the 360MC (Modena Challenge) as the factory called it.
    Here's my list so far. I'd love some help to make this more comprehensive...
    Removal of sound system, stereo head unit, door 6.5" speakers, door tweeters, power amps, gps reciever, cd changer, wiring looms.
    Removal of sound-deadening materials, interior trim panels and chassis coated sound deading.
    Removal of airbags (driver, passenger), airbag ecu, airbag wiring looms
    Removal of inertia reel seat belts, seat belt pre-tensioners, wiring looms
    Removal of hand brake, cables, hand brake calipers, pads, bolts.
    Removal of standard alloys wheels, tyres and wheel bolts
    Removal of standard brake discs, calipers, caliper bolts, bosch abs
    Removal of standard suspension springs, dampers, wishbone bushes, front & rear anti-roll bars
    Removal of air conditioning system, compressor, gas, fluids, etc, air con control panel.
    Removal of door panel (leather outer door panel, handle)
    Removal of door interior parts (locks and central locking solenoids, electric windows, crash bars, opening lighting).
    Removal of door glass side windows
    Removal of tracking system and immobilizer, alarm, alarm siren, horns, wiring looms (re-programmed ignition computers)
    Removal of clock & courtesy lighting
    Removal of glovebox, glovebox damper, etc.
    Removal of sun blinds and trim
    Removal of leather seats, sliding rails
    Removal of carpets, carpet insulation
    Removal of headlining, roof lining spong & sound deadening
    Removal of brushed aluminum consoles, central and dash
    Removal of green instruments dashboard.
    Removal of 26 piece interior trim panels
    Removal of engine lid glass & rear heating element
    Removal of front compartment trim, tyre foam, manuals, leather straps, courtesy lighting, etc.
    Removal of front water washer bottle
    Removal of exhaust backbox, tips and valve system
    Removal of remote acuators for front bonnet opening, fuel filler cap
    Removal of standard lead-acid battery
    Removal of standard steel battery drip tray
    Removal of standard clutch & flywheel
    Removal of standard air filters
    Removal of standard steering rack
    Removal of electric exterior mirror internal motors
    They are replaced by;
    Engine fully blueprinted & microfinished to a +/- 1% tolerance
    Uprated Engine mounts
    Carbon gearbox paddles
    Carbon Inner Door Panels
    Challenge Vented Grille
    RTM manufactured front and rear bumpers & side skirts
    Upgraded TCU without finnessed upshifting (faster)
    Race calibrated Bosch ASR (anti-lock and traction control) system
    Fixed Lexan side window panels with F40-style slide openings.
    Carbon Brake Ducts/air coolers
    Carbon (FIA approved) fuel tanks (26.4 gallons), dual
    Carbon (FIA approved) single fitted (1 spare) 5kg OMP fixed bucket racing seat
    6-point racing harness (FIA approved)
    Engine cover with Lexan with air scoop.
    Upgraded Underbody floor with NACA air ducting
    Matt Black sprayed interior panels, floor, roof, etc.
    Uprated Racing Clutch with lightened flywheel
    OMP three-spoke racing wheel
    OMP bolt in (FIA approved) roll cage (modified dash and rear steps to fit)
    OMP fire extinguisher bottle & fire suppression system
    Magneti Marelli LCD instrument panel wired with onboard telemetry.
    Relocated Race spec two filler pipes for fast fuelling
    Relocated gearbox oil cooler
    Engine kill switch
    Engine lid & front compartment lids, removal of catches and motorised opening, racing pin openings.
    K&N air filters
    Plastic bag for screen washer fluid
    Racing 'open' exhaust system
    Racing gel battery
    Upgraded suspension (uprated Single Rate Boge dampers replacing AF Sach variable electric dampers)
    Upgraded springs (uprated, different ratings)
    Upgraded rollbars (front & rear uprated, different ratings)
    Upgraded flanblocks (all uprated)
    BBS 18" Challenge Wheels (lightweight)
    Titanium wheel bolts (lightweight)
    Brembo Racing brakes
    Pirelli P-Zero Slicks (sticky)
    Uprated Steering Rack (? more details anyone?)
    Unique Chassis number
    Official Performance figures:
    Power (SAE net) : 410 bhp @ 8500 rpm
    Torque (SAE net) : 286 lb-ft @ 4750 rpm
    0-100km (0-62 mph) : 3.9 sec
    Top speed (limited) : 185 mph
    Kerb Weight : 1,250kg (2755 lbs)
    Dry Weight : 1,169kg (2577 lbs)
    Q. Anyone else know any more differences?
    Thanks...
    360trev
  2. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    #2 m5guy, Apr 2, 2011
    I am almost certain that Road & Track magazine here in the U.S. did a test of a standard 360 Modena vs. 360 Challenge vs. ALMS car. Unfortunately I have archived all my old magazines into boxes in my garage. Again, working from memory I think either Sam Mitani or Patrick Hong wrote the story, and race driver Cort Wagner assisted in the testing. You might try using Google to see if that article is available as a digital reprint. Good luck!
