Compression and leak down test results | FerrariChat
Discussion in '348/355' started by Buzzl, Oct 27, 2018.
  1. Buzzl
    Buzzl Formula Junior
    Test were performed and 7 cylinders were at 240 psi and 15% or less leak down. Cylinder #2 compression was at 140 psi and 70% leak down through the intake. Is it odd for just one cylinder to have these results? Car has 17,500+ miles. Sat for 3 years only driven 300 miles. I was told to run some GM top end cleaner through the intake and do some spirited driving for several hundred miles and see if the number improves. Car has hesitation at low rpm and heavy load. Any thoughts? Thanks
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Actually I think number 2 being low is normal but I forget why.
    Sorry
    Maybe someone can chime in about 1 cylinder being low??
  3. fatbillybob
    Aug 10, 2002
    29,184
    socal
    70% leak is no where near normal. These cars driven little with poor mixture control certainly can foul. I have seen caked intake valves often. GM topend , seafoam, and techtron used in higher concentration on a nice long drive or even a trackday is not going to hurt anything if damage has already been done. But if you don't get a significant improvement its time for doing the heads, inspecting the headers, and ensuring proper mixture control.
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    You missinderstood normal.
    I meant there is a failure which oftain occurs but I can not remember which cylinder. Maybe you remember Fbb
  5. fatbillybob
    Aug 10, 2002
    29,184
    socal
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I new you would.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    It is either 2 or 7 that fail. Good advice to spank it hard for a few hundred miles and if it does not improve then it's time for valve guides.
  8. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    My 348 with 11,400 miles had 190 on all 8 and 5% leak down with the exception of #5 which was at 8%. 240 seems quite high, maybe its a 355 and that's how they are?
  9. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Your numbers make little sense. 240 PSI is extremely high especially at a 15% leak rate. Something is wrong with these values.
    If your number 2 is 70% leak, you have a valve with a piece missing.
    INTMD8, WATSON, Pangea and 1 other person like this.
  10. fatbillybob
    Aug 10, 2002
    29,184
    socal
    well calcs show range of 182-217 psi.....11% harbor freight gauge error?
  11. Buzzl
    #11 Buzzl, Oct 28, 2018
    I kinda wondered that myself as far as the high numbers. Going to try and get a visual from the intake side with a camera and see what we can find. Would you run the top end cleaner through before pulling the engine?
    If there is visible damage of course no need to run cleaner.
  12. yelcab
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    If your gauge is accurate, and they never are absolutely accurate, 240 psi means you have a lot carbon build up inside the chamber. If a valve is missing a piece, and it normally is the exhaust valve that is missing the piece, your leak down would be 100%.
  13. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    762
    Vermont
    john truskowski
    I would definitely run the top engine cleaner through it first. I have used it on vehicles that were heavily carbon caked and it works really well. Cars that are run on short drives or just started and shut off can build up carbon. It needs to be driven to full temp and spirited, that helps keep things clean. And using good quality fuels help too.
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #14 Ferrarium, Oct 28, 2018
    I will go on a limb and say the process was done wrong or equipment was not used correctly. There is a whole slew of things that can be done improperly that give wacky numbers. I would suggest a second opinion as it were.
    Definitely you run the top end cleaner through before pulling the engine, try seafoam SS14 and the one you pour into the fuel I forget exactly. You can find it. Used it in cars before as well as most people i know. Be advised it pisses neighbors off.
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    Run the BG pressure pot through the motor then take it on a long hard ride with their addatives
  16. Buzzl
    What method would you use to clean any carbon buildup?
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    I use this system by BG
  18. Buzzl
    Car has new injectors, problem is possible carbon buildup on valves, and valve seats.
  19. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    Just use the same system in this configuration. Carbon buildup is no new issue and something thats become part of regular maintenance with direct injection
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,798
    Lake Villa IL
    I would think overall high cranking compression -could- mean advanced intake cams
  21. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,739
    Motors with more than 10% leakdown are at the point where a rebuild is desirable.
    11:1 Motors rarely have more than 170-180 PSI on a compression gauge.
    Then you are looking at a weak 7 cylinder engine.
    brian.s, Pangea and getragV8 like this.
