compression and leakdown numbers | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by davis, Apr 27, 2005.
  1. davis
    davis Rookie
    Apr 1, 2005
    10
    Gentlemen (and Ladies),
    Please excuse the cross-posting across vintage and technical forums.
    I just received the following compression and leakdown data for a type 209 engine (e.g., 1960s 330 GT). Any opinions and rationale for their interpretation would be greatly appreciated. I know that there have been a few other posts like this, but as every set of numbers is a bit different, I'd like to hear people's reactions to these particular results. Thank you in advance.
    cylinder 1: compression = 155; leakdown = 8% [apparent source, crankcase]
    cylinder 2: compression = 165; leakdown = 10% [apparent source, crankcase & minor exhaust valve leak]
    cylinder 3: compression = 155; leakdown = 13% [apparent source, crankcase & exhaust valve]
    cylinder 4: compression = 140; leakdown = 24% [apparent source, crankcase & minor exhaust valve leak]
    cylinder 5: compression = 160; leakdown = 18% [apparent source, crankcase & exhaust valve]
    cylinder 6: compression = 155; leakdown = 20% [apparent source, crankcase]
    cylinder 7: compression = 158; leakdown = 20% [apparent source, crankcase]
    cylinder 8: compression = 155; leakdown = 12% [apparent source, crankcase & minor exhaust valve leak]
    cylinder 9: compression = 145; leakdown = 18% [apparent source, crankcase]
    cylinder 10: compression = 140; leakdown = 4% [apparent source, crankcase]
    cylinder 11: compression = 155; leakdown = 24% [apparent source, crankcase]
    cylinder 12: compression = 150; leakdown = 20% [apparent source, crankcase]
