News
Compression & Leakdown Tests
Discussion in 'United Kingdom' started by gts328uk, Jun 3, 2007.
  1. gts328uk
    gts328uk Karting
    Nov 26, 2003
    122
    Yorkshire, UK
    Mark
    Help Guys
    Looking at a 355 on Monday and if decide to buy this will be subject to an inspection, compression and leakdown tests. What are the new figures for a 1996 355 for compression and leakdown?
    Mark
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    10,639
    South East
    Jimmie
    I'm not sure there is a 'new' figure but look in the main 355 section - the main thing is a tight spread as the results are hugely affected by both the operator and the conditions
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,147
    Hopefully whoever does the test/PPI for you will be able to advise. As usual the test should be done on a warm engine.
    ISTR seeing results from 355s posted hereabouts nearing 200psi - certainly up at 190 psi for a healthy engine. I think you'd walk away from anything less than about 170.
    As Greyboxer said, the "spread" is as important as the absolute numbers. 10% seems to be the accepted comfort zone/maximum. 5% would be better.
    I.
