Compression numbers in the 140-150 range | FerrariChat
Discussion in '348/355' started by dantm, Feb 20, 2013.
  1. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    Looking at a 95 which came back with this comp value -- seems low to me...leakdown would be next but would this imply valve guide issues?
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Low compression. Several possibilities.
  3. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    What are some of the issues? My understanding was valves/guides -- are there others? If making an offer knowing that this issue may need to be addressed, what would be a good (low risk?) amount to take off the seller ask?
  4. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    #4 FerrariDeeJay, Feb 20, 2013
    Could be cylinder liner damage, piston wear, rings. You probably won't really know unless you take the heads off and see what's going on in there. That will not be part of a basic PPI. To rebuild a 355 engine could cost you $20-$25k.
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,918
    Richmond
    Pete
    If all cylinders showed that I would suspect either valve timing or the gauge itself being off. I would do a leakdown and see how much the cylinders are leaking and where the leakage is coming from if there's a decent amount. That should tell you where the issue is.
  6. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    How about a car with these results:
    Cylinder 1: Compression 119 Psi - Leak Down 2%
    Cylinder 2: Compression 122 Psi - Leak Down 3%
    Cylinder 3: Compression 125 Psi - Leak Down 1%
    Cylinder 4: Compression 119 Psi - Leak Down 2%
    Cylinder 5: Compression 125 Psi - Leak Down 3%
    Cylinder 6: Compression 127 Psi - Leak Down 3%
    Cylinder 7: Compression 120 Psi - Leak Down 4%
    Cylinder 8: Compression 123 Psi - Leak Down 1%
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,669
    San Carlos, CA
    Mitchell Le
    that is very odd to have low compression and OK leak down.
    Valve timing being off is a very good possibility
    Not opening up the throttle during compression test is a rookie mistake but it happens
    A bad gauge is also a possibility.
    Doing the test at very high altitude is a remote possibility.
  8. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    To me it sounds like a possibility that this car has been sitting for some time and the rings are a bit stuck. An Italian tuneup may be in order. I small amount of oil dropped into a cyl is a quick way to see if it is rings or valves. If it is rings, the compression will come up. If it is valves, then you should see no change. I do agree that the throttle could have been left closed during the test.
  9. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    If valve timing is the culprit would the engine out service and timing solve the problem?
  10. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    The figures are a part of a diagnosis. Without knowing the mileage and circumstances (e.g. pressure for leakage, altitude etcc) it becomes a still speculative analysis. On the plus side, it seems to indicate good news, very consistent numbers in both columns, in fact I find the leakdown almost too good! But not having ALL data and history is an issue.
  11. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    cold engine + altitude + throttle + warm engine + guage = ?
    What does the tech say?
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It does seem inconsistent. Typically low compression means there's leakage going somewhere. Brian does have a point that the numbers are pretty uniform overall.
    I would recommend more testing before doing anything else.
  13. Rifledriver
    37,288
    You almost never see a motor with a compression problem that manifests itself equally across the board. Even cam timing issues are almost never done equally bad bank to bank.
    My money is on it having a good motor and a questionable method or equipment during the compression test.
  14. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    That is what I thought. Very suspicious all those low numbers being consistent. Engine cold maybe or monkey on the guage.
  15. Craig Reed
    Craig Reed Karting
    Oct 13, 2012
    150
    Columbus, Ohio
    Craig Reed
    I concur. Try again with a different gauge. If you don't have the right adaptor it won't seal properly. I have had to modify the adaptor on 355s because they are so narrow where the plug gasket meets the head.
    I had a car from dealer with similar numbers, it was diagnosed with bad guides. After modifying the adaptor the numbers were normal. 190/200
  16. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Compression numbers can vary by having the throttle(s) closed or open. If those leakdown numbers are correct and the gauge not faulty, I would bet the low compression numbers are the result of doing the test with the throttle(s) closed.
