Compression Numbers | FerrariChat
Compression Numbers
Discussion in '348/355' started by xplosive1, Jul 15, 2010.
  1. xplosive1
    xplosive1 Rookie
    May 15, 2008
    22
    Compression test results: How do these numbers look??
    Cyl 1: 210
    Cyl 2: 205
    Cyl 3: 205
    Cyl 4: 210
    Cyl 5: 225
    Cyl 6: 225
    Cyl 7: 210
    Cyl 8: 210
    The test was done on a cold motor. Did not have Wide Open Throttle (forgot), did not put oil in the cylinders.
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Not too shabby if I do say so myself. :D:D
  3. Night life
    Night life F1 Veteran
    7,288
    The city that rhymes with fun in Canada
    Roberto
    Yup pretty good all within 15lbs of each other, not bad at all.
  4. xplosive1
    xplosive1 Rookie
    May 15, 2008
    22
    Thanks guys, good to know.
    Would a leak down test still be necessary?
  5. Night life
    7,288
    Roberto
    Never hurts, sometimes it will find other hidden problems.
  6. xplosive1
    xplosive1 Rookie
    May 15, 2008
    22
    Just to be sure, I think it should be done.
    Does anyone know how any tricks or tips to get TDC with the motor in the car, and limited room in the garage? So rolling it in 6th gear is probably not an option.
  7. geeza
    geeza Rookie
    Jul 16, 2010
    4
    Rolling in sixth is the easiest way for sure, you could try removing the clutch inspection cover [2 10mls under bell housing] and turning the flywheel with a screwdriver in neutal should work.
  8. SKUSA
    SKUSA Formula Junior
    Dec 6, 2009
    476
    Norcal
    What year and mileage are these numbers from? They look great!
  9. xplosive1
    xplosive1 Rookie
    May 15, 2008
    22
    1997 with 31,000 kms
  10. xplosive1
    xplosive1 Rookie
    May 15, 2008
    22
    Hmmm That is interesting, never thought of that before
  11. xplosive1
    xplosive1 Rookie
    May 15, 2008
    22
    Just an update, Rolling in 6th worked to get TDC, it wasn't too difficult.
    The leak down numbers were all 7 - 8%. Again, this was done on a cold motor like the compression test.
    From what I have read, these numbers seem to be okay but not great? Is there anything else that should be looked at before pulling the motor for the major service?
