Compression numbers | Page 2 | FerrariChat
Compression numbers
Discussion in '348/355' started by F355GTB6Speed, Nov 22, 2014.
  1. F355GTB6Speed
    F355GTB6Speed Karting
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    #26 F355GTB6Speed, Nov 22, 2014
    I saw the car and it was in a overall very nice shape. Unfortunately there was same bubbling (rust I guess) in the c pillars but I've seen that in many f355, so I negotiated a $1.5k the price and decided to move on!
    Today was pouring rain here so I could not drive the car right away so after negotiating price next thing was the PPI.
    The car dealer didn't want me to be there during the inspection. He came back 3-4 times and almost pushed me to go inside, or go for lunch with him or that I shouldn't be there because I slow down the tech working on the car. I do all the work in my cars by myself so I said NO WAY I'm paying him to do the inspection for me and I want to see what he is doing.
    It's funny that during the compression test the car dealer said "why don't you help us crank up the car?", I was happy to be in the cockpit of my new supercar so I was like sure yes I'll do it! Then I realized they were resetting the gauge by the time I was out, so I couldn't verify the numbers! I said "I'm sorry guys but I need to be able to see the gauge myself. "
    The numbers I saw from the left front side were going for 148, 155, 150, 150 then on the left side was 125, 60, 160, 150
    We tested the cylinder that had 60 multiple times! It was always 60 and then most they managed to get it to was 90. Leak down test at 70 psi (is this low?) was good in all the cylinders showing in the good numbers green scale (the numbers were 3.5% or maybe it was 35/1000).
    Sent from my iPhone using Tapatalk[​IMG][​IMG][​IMG]
    The dealer said, most people they don't even do a PPI since the car is running ok, he said the car is strong and I'm sure someone will buy it! Indeed it felt fast, problem is fast in comparison to what? My daily driver or fast in comparison to a well tuned 355?
    There was also a cel popping for malfunction in the shocks.
  2. surfwolf
    surfwolf Formula 3
    1,698
    Bethany, OR
    Michael Wolfe
    F355GTB6Speed,
    I think with all of the info from the compression numbers & PPI that it is best to walk away from this F-car. While it is disappointing to NOT purchase the car after the search/anticipation and build up, there will be many more chances to purchase another one (or two or three!). Getting the right well cared for & maintained Ferrari will make all the difference in your ownership experience. I purchased a 1995 348 Spider Rosso Corsa & Tan 11k miles over 2 years ago & I could not be happier and "Franchesca" now has over 15k on the odometer. Now I am looking to add another to my stable, a 12 cylinder (575 or 599). Good luck in your search!
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    I bet it wont pass a CA smog test. May be best to walk away and learn from this one.
    60 is a very dead hole. I bet the HC is off the charts
    Wonder why a pro dont have a remote starter. More things make you say Hmmmmmmmmmmmmmm :)
  4. gmbjr
    gmbjr Karting
    Dec 18, 2013
    67
    Austin, TX
    What shop is performing the PPI. Are they also the ones selling the car?
  5. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    #30 F355GTB6Speed, Nov 22, 2014
    That is correct they were the same people which were selling the car and that's why I wanted to be present during the test. I understand that it's always better to have a 3rd party do the inspectio, I just felt that if I'm there I can supervise them and drive the car too.
    Still I think it's really weird that the car was idling and Revving ok and seem to have some okay power.
    Based on discussion that I had the only way to have good leak down numbers and bad compression in to have bent rods. What are the chances really to have bent rods in this car in two cylinders? But the numbers were very repeatable so something is up and most probably they new about it.
  6. gmbjr
    gmbjr Karting
    Dec 18, 2013
    67
    Austin, TX
    I'm here in Austin (west side), the weather will be beautiful tomorrow. I plan to drive my 98 GTS like I stole it as soon as the roads are dry. Would love see yours if you're getting it. 2222 to Lime Creek to 1431. let me know.
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Negotiate a price based on the PPI, buy the car, sort it and live happily ever after :)
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Those numbers are a classic problem with the 355. Valve guide issue causing the bad leakdown compression numbers. Do a search here you will see hundreds of threads
    I am doing one right now, numbers not as bad but while engine is out in were doing it.
    It idles great pulls hard and smooth but is down on power and HC emission is high
    Cost will be 7-10 K, Very textbook repair for the 355
    So you know where your at
  9. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    Thank you for your response! How would you explain though the good leak down numbers? Or let's not say good, let's say the consistent leak down numbers?
    Just to know I'm not arguing - just trying to learn a thing or two here!
    Btw I thought that only the 95-96 had this issue with the valve guides, no?
  10. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,495
    Tucson, Arizona, USA
    Robb
    Nothing wrong with being there. But I think its best to keep the PPI at a separate facility - or bring in an outside mechanic to the dealer's location.
    Keeps it with your "expert" and you paying him/her directly for results going to you without conflicts of interest creeping up.
    If a dealer can't go with that, then you question "what are they not telling me.?"
    Robb
  11. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    Well said... I was just trying to cut corners and bit me in the ass as always...
  12. Robb
    Robb Moderator
    Feb 28, 2004
    14,495
    Robb
    My '95 had the issue early on and had the guides replaced. I think it is reported mostly in 95 and 96 but the consensus that I have read also show issues with later years.
    Maybe Rifledriver can chime in or Dave Helms...
    Robb
  13. Big Lebowski
    Big Lebowski Formula Junior
    Jan 24, 2013
    337
    Peach state
    Brownie
    Dave Helms quit posting Fchat after getting his GCK savaged by certain posters on this board a year or so ago. Really a shame.
  14. td80
    td80 Karting
    Nov 5, 2005
    161
    Irvine, CA
    Dave M.
    To me it is crazy not to have an independent specialist evaluate the car. In this locale I would suggest Norwood (no affiliation).
    If it is guides, it is going to be expensive. If it is something worse... you could be sticking some really big money into the car.
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    You guys are making way to much of this.
    F355GTB6speed,
    You asked above, how do you explain the leak down numbers? Please see my post 24 https://www.ferrarichat.com/forum/143543988-post24.html
    As I said in that post, with compression number as you have noted, the only explanation is that they are bogus. A 3.5% leak down is basically a perfect engine. You don't need a qualified independent shop owner to tell you that. And if the compression number are actually what you most recently posted there are some serious problems here, either with the car or the shop doing the PPI does not knowing what it is doing. You have two choices: 1) Walk away. 2) Insist a qualified independent shop perform a compression and leak down. There is a 3rd choice, buy the car and hope. But if the car needs a top end rebuild you are talking more like $15k to $20k depending on who does the work and what parts are used (Ferrari or after market). Also, as Tim said, a cylinder at 60psi is pretty much just going a long for the ride. Probably would not even fire consistently at low rpm, if at all.
    By the way, I presume this is the car? www.texastoys.com 1997 Ferrari
    This creates another inconsistency because my understanding is that Lambo of Dallas is a pretty reputable firm. The selling dealer shows one page of the major service document from Lambo of D on his web site which states that a compression and leak down were done at the time of the major, about 2k miles ago, 4/2013. I would definitely ask to see what the numbers from Lambo of Dallas were.
  16. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I paid for a ppi at a Ferrari dealer and walked from the car because of similar issues.
    Here are the videos of the compression test and leak down being done by a master Ferrari tech.
    http://youtu.be/o27ma0LejZU
    http://youtu.be/73zHI27T_38
    The leak down on the bad cylinder should show the leakage as well.
  17. Big Lebowski
    Jan 24, 2013
    337
    Peach state
    Brownie
    A top end rebuild does not cost $15-20k unless you replace all 40 valves. It generally costs more like the $7-10k Tim quoted. If a shop tells you to replace every single valve when you have your guides replaced, you are most likely getting ripped off.
  18. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Considering the dealer's attitude it seems that they'd rather sell to the uninformed. Same MO as many others who flip "high-line" cars.
    "The dealer said, most people they don't even do a PPI since the car is running ok, he said the car is strong and I'm sure someone will buy it!"
  19. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    Did u rock the car to make sure cyl was at tdc?
    35% is prob more than just guides
    Sounds like tdc was missed
  20. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    I was encouraged by the dealer to call Lamborghiny of Dallas. They told me that they didn't write down the numbers but that they were good. Yes the car is the one that you mention.
    3) the owner doesn't feel that the car is bad and is not willing to further negotiate the price. Either I get is for as much I would be getting or walk away.
  21. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    #46 F355GTB6Speed, Nov 23, 2014
    What is that? Just to know I took the car for a short ride, revved it to the moon and back at least 4-5 times and the we repeated the test on hot engine.
    THE INJECTORS WERE NOT DISCONNECTED AT THE TIME OF COMPRESSION TEST, do you think that was creating an issue? Still can't explain why one cylinder was consistently lower.
  22. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
    That was clearly stated to me a bit differently " it's a good car and it has power, somebody will get it w/o PPI and will be happy" "maybe we didn't do the test right, I think it's a good car"
  23. F355GTB6Speed
    May 22, 2014
    118
    Carlsbad, CA
    Christos
  24. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    A good leakdown number for this car is under 10% meaning nothing in the green area on the guage or just touching it. These motors have a less leakdown by design dont go by what the guage says is "normal" or "low"
  25. Oengus
    Oengus F1 World Champ
    sounds good
