Compression numbers | FerrariChat
Compression numbers
Discussion in '308/328' started by absostone, May 17, 2016.
  1. absostone
    absostone F1 World Champ
    10,061
    Anyone know compression test numbers for a 75 308? I don't know where to find the info. Thx
    Btw the engine is out of the car and obviously cold. Probably do a wet test also
  2. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    I seem to recall that 175 is excellent for an engine that hasn't been rebuilt, and anything over 145 acceptable. Our mutual friend clocked mine at 155 during PPI and said that was good for a car that hadn't been running much with the previous owner; "probably" would increase a bit with more driving, he said.
  3. absostone
    10,061
    Thank you sir. I'll wait and see if I get more answers and take a average number
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Too many variables to be looking for a particular #. More important is consistency between cylinders. It is very improbable that they will decline or increase (carbon) at the same rate. So if you have high variation you likely have a problem.
  5. absostone
    10,061
    Yes thx scowman Exactly my thought. was in the process and my solenoid broke so I'm sol tonight. Was just curious if there was a average comp number. Thx
  6. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    I posted these compression numbers about 2.5 years ago for my Euro 84 QV:
    Compression results, on a cold engine that hasn't been run for 2 months:
    Cylinder: PSI
    1: 142
    2: 150
    3: 145
    4: 150
    5: 155
    6: 152
    7: 155
    8: 160
    I was pretty happy about those numbers. #1 seemed low, but it was the first cylinder tested, so I suspect the ring sealing wasn't great after not being turned over for 2 months! I should have re-tested it after finishing the others, but didn't think of it until all the new plugs were in. Also of note, Calgary is about 4,000 ft above sea level, so atmospheric pressure is 10% lower than sea level, and compression numbers here tend to run 10% below what would be achieved at sea level as well.
  7. absostone
    10,061
    Gordon would a qv have different values than a two valve carb 308? I didn't get to do all my cyclenders cause my solenoid broke.
  8. ClydeM
    ClydeM F1 World Champ
    11,938
    Wayne, NJ
    Clyde E. McMurdy
    My shop mentioned the vacuum on the brakes was weak and perhaps the engine needed to be rebuilt. She is an '83QV & has 97K on the odo
    I did the test after she was sitting a week & cold with a Sears gauge with maybe 5 cranks on a reading. I can only get the adapter finger tight, so she may have been leaking some.
    1-137 5-138
    2-139 6-146
    3-135 7-136
    4-136 8-138
    a bit low, but consistent. So if the gauge was off on the readings, I was consistent :)
    Maybe another day I'll take her for a run & re-run the compression readings on the rear bank. The front is no fun.
  9. absostone
    10,061
    To me the numbers are ok. They are similar to what I had before the new valves. but I haven't checked it since. There are guys that claim 190. Not sure about that
  10. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I prefer the leak down test. It takes about the same amount of time and tells you much more about the health of your engine or where the trouble lies.
  11. Rifledriver
    37,121
    One does not replace the other. Both are important and tell overlapping but somewhat different information.
  12. Albert-LP
    Albert-LP F1 Veteran
    8,177
    around Modena, Italy
    Alberto Mantovani
    #12 Albert-LP, Dec 13, 2016
    175 PSI = 12 bar (excellent just rebuilt car or like new: almost impossible to find)
    160 PSI = 11 bar (excellent conditions: hard to find)
    145 PSI = 10 bar (an average good car)
    130 PSI = 9 bar (can still work, but not for too many miles)
    115 PSI = 8 bar (very old engine, rebuild soon please)
    please pay attention: the value reported is for each cylinder, not "the average". Seven cylinder with 11 bar and two with 9 bar is not good: the engine won't turn smooth.
    My blu sera drysump has:
    10,5
    10,5
    10,5
    10,8
    9,8
    9,8
    9,2
    9,5
    It doesn't turn smooth due to the 9,XX bar cylinders and it's on rebuilding at Toni shop.
    Difference from top to lowest should be no more than 0,5-0,7 bar (7,5-10 PSI). More or less, of course, but I have 1,6 bar (23 PSI) from top to lowest: it cannot turn smooth, of course.
    My compression ratio clearly shows a badly rebuilt engine, done by the previous owner not too many miles ago.
    ciao
    Edit:
    ClydeM engine:
    1-137 5-138
    2-139 6-146
    3-135 7-136
    4-136 8-138
    this one is very old and cannot develop the official declared power (my one has much more than this), but it turns smooth much more than mine
    SO: OVER 150 PSI AN WITHOUT BIG DIFFERENCES FROM EACH OTHER IS WHAT YOU SHOULD HAVE TO HAVE A GOOD ENGINE
