Compression Readings on 355 | FerrariChat
Discussion in '348/355' started by 355Blue, Jul 19, 2010.
  1. 355Blue
    355Blue Rookie
    Apr 8, 2010
    29
    Hello All,
    What is the meaning of these readings? good? bad? why?
    Cylinder 1: 180 psi
    2 : 175 psi
    3: 175 psi
    4: 180 psi
    5: 180 psi
    6: 175 psi
    7: 175 psi
    8: 175 psi
    Thanks,
    355Blue
  2. Rifledriver
    37,100
    Should all be in excess of 200. 210 or so really.
  3. plugzit
    plugzit F1 Veteran
    7,776
    Redondo Beach, CA
    Bruce Bogart
    Looks more like they were done with the engine cold?
  4. Rifledriver
    37,100
    Even cold we never get comp readings like that. We do leak down tests cold with the engine out all the time. 1% or less leakage stone cold is the norm. Mahle rings have an end gap of .1mm.
    On a 355 with a good motor compression just does not vary hot to cold.
  5. troppoveloce
    troppoveloce Formula Junior
    Jan 25, 2006
    268
    New Hampshire
    Tom
    The results are so consistent though...... doesn't that point (maybe) to a gauge that's reading too low?
    Wouldn't a failed compression test usually result in a few good cylinders and a few bad? Not all of them in an equally mediocre state?
  6. troppoveloce
    Jan 25, 2006
    268
    New Hampshire
    Tom
    And now I'm curious......
    I'm about to get the compression test results on a 348.
    Should they be all in that 200+ range as well? What would be good?
  7. Rifledriver
    37,100
    #7 Rifledriver, Jul 19, 2010
    I cannot control how the test was done.
    I cannot evaluate the condition of the test equipment.
    I can only comment on data presented.
    It highlights that a test done by someone without the knowledge or ability to do so is a waste of time. I might as well be taking my own blood pressure.
    This same conversation has taken place hundreds of times in the 355 forum alone and the answers are always the same.
  8. SKUSA
    SKUSA Formula Junior
    Dec 6, 2009
    476
    Norcal
    Hopefully it is less than 175 :)
