Compression test and leak down test | Page 2 | FerrariChat
Discussion in '348/355' started by drbob101, Jan 17, 2014.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The valve is 26.7mm or 1.05" That would equal 86.54 pounds on the valve at 100 PSI, 34.6 at 40PSI. Give that, 100 PSI can overcome the spring, 40 cannot. Regardless, Brian says it don't mean sh*t :D
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    So what material are stock 355 valve seats make of that they rust?
    Personally I think that is leak down tests performed at different pressures show substantially different results the test isn't reliable for defining the condition of the engine.
  3. Rifledriver
    37,335
    And that I can't argue with.
    Ferrari calls it cast iron. But there is cast iron and there is cast iron.
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I really doubt it's cast iron since that won't harden well.
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,966
    Atlanta
    John!
    Yeah I sort of wonder what type of steel Romeo and Juliet (the robot which installs valve seats at the factory) installs. I started using Tucker valve seats not long ago and they are just obsessively knowledgable regarding the subject. If you ever want to ask about rust and valve seats then I'm sure they're not a bad party to ask.
  6. Rifledriver
    37,335
    I agree. The translations in the manuals can be pretty misleading. They have often used ESL students to do the translations so not only is the grasp of the language iffy there is no technical expertise.
    Once in a while I'll read the Italian version and understand it better.
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    All steel that can be hardened, including 440 stainless will rust. But, most have higher chromimum content and if oiled, won't rust like plain carbon steels.
  8. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    I do that often (read the Italian version) to really understand what they are saying :)
    Thanks for posting your experiences with leak down/compression tests.
  9. fatbillybob
    Aug 10, 2002
    29,377
    socal
    The math is correct but the application of it is not. If there is a bleed off of air as in a non-seating valve the 881 force of the air pressure leaks out the hole and you don’t have enough force to close the valve to stop the bleeding. If you could fire the 100psi in fast enough to offset the bleed to overcome the valve spring that would be a different story. That all sounds sort of difficult to wrap one’s head around until you think about what happens at a tire store when the tire monkey have a difficult bead to seat on say a race tire they overcome pressure with delivery volume of air to seat the bead. We are not doing any of that with a 100psi FAA leakdown test.
    [ame=http://www.youtube.com/watch?v=PONJgC3EZDA]Quad tire bead seating with maximum ease - YouTube[/ame]
    This also explains why Brian finds no difference in the 2 tests in his experience. Someone here also got me fired up about the low pressure test. I also did both tests for about a year. Then abandoned the low pressure test and just went with the FAA test with a certified FAA tester since my low pressure tester was HF junk. I just found it did not matter and figured the FAA guys and the pro auto race teams were smarter than me so I just copy them.
  10. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    When you consider that actual max cylinder pressures under load can run above 50 bar...... :)
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Note that as Brian pointed out, I was doing this in a hurry and ignored the actual valve diameter which greatly reduces the force. And I do agree that the force will be less in a non sealed system (high leak rate)
  12. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    What I have described and posted videos of is a real world. Actual experience involving a 355 ppi , done at a Ferrari dealer by an accredited Ferrari mechanic
    This leak down again was done three times over a three week period
    Again the summation:
    When done at 30-40 psi on a cylinder showing on compression test a distinctly lower value than the other cylinders - a 20% leakage
    One week latter when done at a Porsche dealer at 100psi. The same cylinder showed les than 5% leakage
    Test redone at Ferrari dealer and shown in above videos. Suspect compression and 20% leakage
    Recommendation to me as a buyer to not buy the car which I had a deposit on
    This is not theoretical debate, this actually occurred regarding a 355 purchase.
  13. Rifledriver
    37,335
    #38 Rifledriver, Jan 19, 2014
    I was factory trained too and was shop foreman at what was then the largest dealer in existence.
    So what? Don't be too impressed by any of that.
    Ever consider the fact that one or both leak testers was defective? And there are a whole shopping cart full of variables beyond that.
    Additionally I can pretty much make the tester say anything I want it to say depending on my motive.
    Also In case you didn't catch it a low pressure test will often fail a motor with slightly stick rings, rings that work perfectly in the real world.
    Want a good motor to fail a test...no problem I can do that for you if that is your motive.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    So what's the point of the test then? And, it's difficuit to get accurate information since so many disagree. Who is to say you are right, or Tony at Algar is right? I ask that with no motivation - just making a point. No disrepect or judgement to you at all.
    As a side note, when I started as an engineer, I worked with a couple of fantastic guys, my best friends to this day. The one would always make 3 calls to different people when it came to technical issues and then he would make his decision based on merging the pieces togther or dismissing the obvious poor advice. I've learn to follow the same process, and it is frustrating but usually works.
  15. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Brian, I respect anything you have to offer and and personally appreciate your willingness to have even banter with the lay people here.
    I am a dentist. I don't do this for a living and what I think or know on this matter is only what I have learned as a result of my experience.
    What I am though or was in this example is a buyer who was supposedly prudent in having a ppi done as suggested on this site and others, who walked away from a.car being sold because of conditions described above with tests as described
    If a prospective buyer of a 355 reads this site as I did, they will be told to get a ppi done and pay attention to the cc and leak down results because the big RED FLAG with these cars is the potential for serious, undiagnosed engine issues. There are probably a hundred threads with just this caveat and warning. Threads that I read and acted accordingly on.
    Now I found a 355, right car, right price, did the PPI at Ferrari dealer with no stake in the sale. They didn't have another 355 for me , they weren't involved in any potential repairs on this car, in fact all of the prior servicing on this car for 5 years and 20000 dollars had been done there. The car fails exactly the test with exactly the symptoms that all the people post on here and elsewhere warn about. I didn't buy the car and the seller didn't get the sale
    You tell me please Brian. Should I have bought that car as it was? Would you have advised me differently? I think someone that who come on here looking to buy and those who own looking to sell will probably face this scenario sometime. What would you do or suggest a buyer do given these circumstances?
    The cc showed low compression. A 100psi leak down passed a 40psi leak down done twice was at 20%
  16. Rifledriver
    37,335
    I am not going to tell anyone on the internet to buy or not but any given car. Personally I consider the internet part of the problem and not part of the solution. I would consider it a victory if people ignored everything they read here, me included. The signal to noise ration is clear off the charts.
    This case is an example of that. We are creating yet another falsehood and people will come to my shop expecting me to perform based on what they read here at which point they will be shown the door.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    This might be the single best post I've ever read on this site...
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I guess you should have bought the car but still unsure. That post is what I always liked and appreciated from Brian, Dave and others. They did not always agree but they also did not bull**** you. Not to put words in Brian's mouth but I think he once said the 355 was a more troublesome model than most others. He will correct me if I'm wrong.
  19. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Ok then. We'll just leave it at that.
    I started the thread to answer a couple questions I had on the logistics of how to do a cc and ld test. I am clear on how to do them and will do them with both a 100 and 40 psi on the leak down and post the results and hopefully that will help others that come here
    As far as the car I tested and didn't buy, the facts and the videos are what they are and that is not any internet noise. Whoever reads this and looks at it can take what they will from that experience and maybe it will be of value to them in their purchase or ownership.
  20. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Bob, thank you for starting this thread and keeping it informative for all. I look forward to reading about your future test results.
  21. Rifledriver
    37,335
    Nope.
    Most just want their version of reality to be validated. I have no need to do that.
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I look forword to the results as well. Another question does anyone have compression and leak down test results for any of their daily drivers just curious?
  23. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Grant
    82000km compression 195 to 215 cold
  24. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Ferrari Parts : TDC-KIT-01 Top-Dead-Center Tool Kit : Ricambi America
    Just saw this on Ricambi site. When my leak down was down . TDC was found using a screwdriver. How important is it to be this precise in finding TDC? Does it feel like a notch or does it slide off the cam lobe easily?
    So if you aren't at precisely TDC then the valves aren't completely shut and the leakdown will be erroneous.
  25. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    If you are using a screw driver and observing it going up and down visually without the aid of a dial indicator, you are just guessing. It could be 3-5 degrees off. It would not be accurate enough for valve timing, but OK for the purpose of testing leakdown.
