Compression Test and Leakdown Numbers | FerrariChat
Discussion in '348/355' started by Parikh1234, Jul 18, 2007.
  1. Parikh1234
    Parikh1234 F1 Rookie
    4,726
    Little Ferry, NJ USA
    Shivam Parikh
    Here is what came back today from the car I am looking to purchase:
    Here are the compression and leak down numbers:
    Comp:
    1- 221
    2-225
    3-227
    4-220
    5-223
    6-225
    7-227
    8-228
    Cyl. leak:
    1-4
    2-6
    3-4
    4-7
    5-6
    6-4
    7-6
    8-5
    The compression values are p.s.i. and the leak values are percentage.
    These are good numbers, the test was done with the engine warm. We
    consider on a 355 compression numbers in the 220 to 230 range to be good
    and 10% or less cylinder leakage to be acceptable. The engine has a
    decent idle but it could be a little smoother, the spark plugs are clean
    with no sign of oil burning. The valley for the spark plugs did have
    some 'rust' residue and some of the spark plugs have corrosion on the
    steel body above the seal indicating that some water has been in the
    valley at some time in the past. This is not uncommon on 355's, the
    gasket for the plug cover as well as the plug wire rubber seal are intact.
    What do you guys think?
  2. FullChat
    FullChat Formula Junior
    Jan 1, 2007
    339
    San Antonio, Texas
    Those are the kind of compression and leakdown numbers that I'm looking for.
  3. f355spider
    f355spider F1 World Champ
    18,053
    Excellent numbers. I would have them just replace the plugs, install new cam cover gaskets and the foam seal and call it good. If the idle is still a bit lumpy it might need a new set of plug wires (not uncommon). New sets are available from www.kingsborne.com for less than $250 and they use the exact same Beru connectors and wire as the factory sets.
  4. Parikh1234
    4,726
    Shivam Parikh
    thanks alot guys. Its nice to know that the numbers came back good. I am flying down on Monday to finalize things and hang out with the tech while he does the rest of the PPI. Hopefully if there is enough time and anyone is in the texas area we can meet up for a quick dinner. I need to be back at the airport at 6 PM
  5. FullChat
    Jan 1, 2007
    339
    San Antonio, Texas
    Where in Texas? I'm in San Antonio.
  6. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Does the idle stumble when the radiator fans come on?? I am working on a fix for this..... :)
  7. Parikh1234
    4,726
    Shivam Parikh
    dallas.
    nice. Ill let you know on monday when I see the car:)
  8. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Geez!! I wish those were the numbers on the two 355 GTB that I wanted to buy.
  9. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Oz, what's causing this? Is there a voltage drop?
  10. f355spider
    18,053
    My thought as well....perhaps an alternator issue if there is a voltage drop.
  11. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    see below ;)
    I will publish my findings after I have the fix in the car and functioning properly ;)
    ......some pertinent componenets should be arriving today..... :)
  12. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Thanks Oz....you're the man..lol
  13. Nick@Autobahn
    Nick@Autobahn Karting
    May 29, 2007
    124
    Huntington Beach, CA
    Nick
    Glad to see everything is going smoothly with the PPI, Shivam!
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I have solved the infamous 355 idle stumbling!!!!! I will posting my full report this evening on a new thread with pics/diagrams of the solution!!! :D
    BTW should I post it in the Tech Q&A or in this 348/355 section??
  15. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    I would say to do it in this section, because it'd be difficult to ever find again in the general tech section. At least in here, all the stuff is about 355/348...
    IMO
