Compression test results after rebuild | FerrariChat
Discussion in 'Maserati' started by hiltsuk, May 23, 2016.
  1. hiltsuk
    hiltsuk Karting
    Dec 31, 2014
    171
    London
    Hi
    My 4.7 ghibli engine was completely stripped, cleaned and rebuilt last year. I've now completed the running in and covered 1000 miles. We ran a compression test and 4 cylinders were around 150-160 and 4 were around 120. Not a great result and the question I have is will this get better as the engine is run in more or is it more likely that the rebuild was done badly. I haven't done a leak test but I assume this will tell me more about the issue ?
    Many thanks for any advice
  2. JulianMerak
    JulianMerak Formula 3
    Hi,
    Are they all low on one head and high on the other? Could be cam timing is out. I have a similar result, all around 155 one side and 140 on the other
    Julian
  3. hiltsuk
    hiltsuk Karting
    Dec 31, 2014
    171
    London
    Hi Julian
    *Herr are the results
    1 – 123
    2 – 130
    3 – 140
    4 – 125
    5 – 150
    6 – 155
    7 – 125
    8 – 160
  4. staatsof
    95,972
    Fuggetaboutitland
    Bob
    Up next a leakdown test.
  5. JulianMerak
    Hi,
    I'm not the expert but I read on line that ideally the top and bottom values should be within 10% ideally and within 15% max. So yours look a bit off at the moment. Hopefully the others here can help a bit more than me
    Julian
  6. thecarnut
    thecarnut F1 Rookie
    3,230
    Atlanta
    The Car Nut
    Try doing a wet compression test by squirting some oil down the cylinder just before testing each cylinder. Some increase in the numbers is to be expected. A very large increase would indicate faulty rings. A small increase would point to the valves. Perhaps the valve clearances are too tight.
    Ivan
  7. hiltsuk
    hiltsuk Karting
    Dec 31, 2014
    171
    London
    Thanks will do this next
