Compression Test results...kinda wierd...opinions? | FerrariChat
Discussion in '348/355' started by ThomasK, Feb 19, 2017.
  1. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    i tested my recently acquired 99 355 gtb 6spd this weekend. i am about to pull the engine for a major and seeing if i should dig into the heads. 18.5k miles, car probably sat a lot.
    Parameters of test:
    4500ft elevation
    cold engine (been sitting for a few weeks without being ran)
    5 compression pulses
    full throttle during tests
    basuc autozone tester i use on all my cars
    1: 160
    2: 160
    3: 171
    4: 160
    5: 186
    6: 180
    7: 185
    8: 177
    obviously bank 1-4 looks lower than 5-8. im thinking i do the 30k service in order to gain confidence in driving it and just put miles on it with some intake cleaner, fuel injector cleaner, etc and then test the compression the same way in a few thousand miles...thoughts?
    no leak down yet.
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,698
    South East
    Jimmie
    Did you buy it to drive or strip down ?
    Service and/or Italian tune-up plus drive some then maybe next winter see what the test looks like if you must and even then probably not get into a rebuild until it obviously needs it
  3. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    i bought it to drive, but its due for a major. so i guess the answer is BOTH! once it gets a once over to fix a few oil leaks and get some new belts/tensioners, etc im going to drive the piss out of it. daily driver.
  4. tres55
    tres55 F1 Rookie
    3,572
    Canada
    Get her up to temperature and give her the beans. Then redo the test. :)
    Might just have some build up.
  5. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Those numbers are probably okay. I don't think cleaners will affect the compression.
    I would warm the engine up first. Then let it cool enough to work on it. Pull all the plugs out. Crank the engine for 7 seconds, for the test. Clean the plugs with a propane torch since you have them out.
    Fantastic car. Congrats.
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The lower numbers on bank 1 is likely because the timing is off.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    Wonder how the numbers would be it tested in reverse order?
  8. WATSON
    23,866
    WI
    Beat me to it. That's exactly what was wrong with mine.
    They reset the timing during the engine out and that fixed it completely.
  9. johnk...
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    Be careful guys. You are starting to sound like there is no point in doing a compression test because if it's off it's because the timing is off. So far the engine detectives have determined that bad compression = bad timing, carbon build up on valves, rust on valves, stuck rings,... Have I missed any. I guess a leak down could help thin that herd, unless the timing is off enough that the valves got bent a little. Doesn't take much.
    All I'm trying to say is that bad compression = problem. From there it's speculation as to why w/o proper diagnostics. If you want to gamble on a guess, that's your prerogative.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, of coarse it's speculation given the data that has been provided to us :)
    99.9% of posts on this forum are via speculation ;)
    He did a compression test and provided the values. The cylinders of each bank are close to each other, relatively, with bank 1 being lower in value. That's the data that caused me to "speculate" my response :)
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    Just by reading the cold compression numbers alone, and seeing that all cylinders on the same side are close to each other but uniformly different from the other bank, I would also conclude (speculatively, I am not there doing the test) that there is a slight difference in cam timing from one bank (bank1) to the other.
    I certainly would not tear the motor down reading these numbers. I suggest doing a leak down test while the engine is out and repeating the compression test AFTER verifying the cam timing.
    $50 says bank 1 cam timing is 3 degrees out on one of the two cams.
  12. johnk...
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    As I recall, several times such numbers have been posted where bank 1 is consistently lower than bank two on a cold compression test, but other wise acceptability uniform. Is my memory failing or is there something too this? Dave, wasn't the case, more or less, with your 955 project car?
    1 = 177
    2 = 170
    3 = 156
    4 = 135
    5 = 238
    6 = 212
    7 = 210
    8 = 210
    Was that a cam timing issue? I don't recall what you found re timing.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #13 Dave rocks, Feb 20, 2017
    Yes - those are the values for my 95 project car. The timing was NOT consistent from side to side (but not too far off) - see values. And, the leak rate was greater on bank 1 (which to your point, has nothing to do with timing). But, my bank 1 compression results are not as close (cylinder to cylinder) as the OP
  14. Rifledriver
    37,278
    Unlike car A there is no consistency in this compression test.
    I or those directly under me have done compression tests on hundreds of 355s and I concur it is most likely a cam timing issue.
    As far as those concerned about it being cold, how many here have done back to back tests on 355s with good motors cold and hot? Have a look at the ring gap specs sometime. Cold or hot if the compression is no good the motor is junk.
  15. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    thanks for the replys guys.
    here is bank 1-4 earlier that day using 8 pulses
    1:166
    2:165
    3:166
    4:166
    so it was even more uniformly low. #3 went to 171 later that day with only 5 pulses...wierd. may have been a loose fitting on my gauge, so i agree this test is used as one piece of the puzzle and a guideline.
    based off these results i will probably not dive into the heads, but rather when doing the belts get the timing bang on. need to read about how to do it properly...i assume the workshop manual has it in there, i have a PDF copy.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Brian - thank you for confirming this. This was my thoughts, although I've only done the cold vs hot (warm) experiment once.
    What about WOT or closed? I did this again, one time, and did not see a difference, but as a SOP, I now do WOT.
  17. Rifledriver
    37,278
    Some types of cars it makes a difference. Most it does not.
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    When you pull the motor, before taking stuff apart, check your current timing. You could then correct and check again before even installing new belts.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Much appreciated.
  20. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    will do!
  21. johnk...
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    Well, the leak down would (should) shed light on whether its timing related. I would certainly do that before taking the engine apart. Please post results when you have them.
    Also, I do agree with Dave that you might consider checking timing before taking the old belts off.
    I was using Dave's data as an example of my observation that the lower compression numbers seem to commonly occur on the 1-4 bank, as I recall.
    I also recall that the 1-4 header tends to fail first. And it has been said by one of the pros here that 1-4 tends to run hotter.
    Why is it always (or commonly) the 1-4 bank?
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    John, if you recall, my situation one bank had wet heads and the other dry (combustion chamber). I think the wetness of the one bank allowed for less carbon than the other but I'm not 100% certain I'm remembering that correctly.
    Given the OP's bank 1 numbers today, it all seems very obvious to me.
  23. Rifledriver
    37,278
    #2 runs the hottest followed by #7. Every motor ever designed has hotter and cooler cylinders.
    I do not believe a 355 motor should ever be removed without a leak down first. Compression tests are fine and a good diagnostic tool but will never replace a leak down test. A leak down test shows much more about basic condition. When embarking on a major service I find no value in knowing about the status of cam timing. I want to know if there is enough motor left to justify tuning.
  24. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #24 eulk328, Feb 20, 2017
    These are some temperature measurements I made about 7 years ago. Car was idling at operating temperature. Temperature numbers are roughly where the measurement was made on each header. I don't recall if I used infrared or if it was a contact pyrometer. Not very scientific and a number of variables involved (location on pipe, could have some cylinders running lean etc.).
    I'm thinking (hoping?) cylinders #1 and #2 are much hotter due to the proximity of heat reflecting material.
    NOTE: photos of headers were taken during installation after ceramic coating and not during temperature tests.
  25. Rifledriver
    37,278
    #25 Rifledriver, Feb 20, 2017
    Temperatures at idle mean nothing and a sample of one car means very little more. Ask anyone who has been working on 355 since 1995 which tubes burn out first and which valve guides go bad first. I knew a lot of guys in the earlier days who never even tested any other cylinders.
