Compression test results what do they mean | FerrariChat
Discussion in 'Technical Q&A' started by BOBAER, Jun 8, 2006.
  1. BOBAER
    BOBAER Formula Junior
    Jun 6, 2006
    261
    Jersey
    Jon
    I just had a compression leakdown test on a 95 f355 and would like to know if someone can interpret them as I am no mechanic. Are the results within range of where they should be, and if not, what does that mean.
    1 13%
    2 6%
    3 10%
    4 7%
    5 10%
    6 3%
    7 7%
    8 3%.
    Any input is helpful. Thanks
  2. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    A lower number is better for leakdown. 3% is great/13% marginal. Did he give you compression numbers for each cylinder also?
  3. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    No, those are the only #'s I have. When you say marginal, should something be done about it?
  4. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    Is this a car you are considering purchasing or one you already have? Compression numbers are important to determine true engine condition. My '85 308 with 26K miles was less than 4% leak down on all 8 cylinders and compression was 180-190 on all 8. From what I have read, anything less than 20% leakdown is acceptable. Actually, I should retract my statement that 13% is marginal, it's probably OK. Get the compression numbers though!
    See here:
    http://ca.autos.yahoo.com/maintain/answer.php?cylinder_head_answer5.html
    http://www.2carpros.com/topics/compress.htm
  5. Llenroc
    Llenroc F1 Veteran
    5,561
    Colorado
    Vern
    with no. 1 being what it is as compared to the others I wonder if the valve seat had a small amount of crud/carbon on it to cause it to leak a little. The rest look good and no. 1 isn't that bad. As was said above the compression nos. are a must to look at along with the leak down nos. Regards, Vern
  6. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Lots of guys say compression tests are a waste of money. The leakdown is much more important. If there's "no" leakage than the compression will be fine. If it's leaking then you know there's an issue. Your numbers are probably fine as far as it goes. Lots of cars "pass" a compression test yet have major issues anyway.
    What prompted you to test the car in the first place?
    Ken
  7. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    Actually, I have already purchased the car and found the test within the service records and needed an interpretation of what they meant.
    If in fact 13% is high, what can be done to fix it if anything, and what can be the long term problems that may occur..
  8. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,467
    VIR Raceway
    Peter Krause
    13% is NOT high for a high performance street car, even a Ferrari. As a matter of fact, your numbers look darn good for an eleven year-old car.
    You're in good shape. Driver it and enjoy it.
    -Peter (not concerned until 20% or more, then it depends on where it comes from...)
  9. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    Thanks a lot Peter, that makes me feel better, I am enjoying the car.
  10. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,825
    wisconsin/chicago
    bo
    I love reading threads on leakdowns. I could swear that about a year ago folks on this board were advising others that a leakdown of >8% meant your engine was near death...:)
    Today, 13% is good :).
    I searched this extensively a couple of years ago...
    Seems that in the porsche community 2-3% leakdowns are considered good.
    In the Ferrari community, 5-8% or less is good.
    In the Volvo community...12% or less...
    Talk to a oldschool american iron mechanic...20% or less is good.
    Talk to a ferrari dealer, and, if you are buying, less than 13% is good. If you are selling, over 6% requires head work :).
    Pick your resource :).
  11. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    So basicaly, there is no true answer to the question. However, what would be the symptons in day to day driving to let you know that you had a compression problem.
    Also, I asked this before, what does one have to do if anything to improve the compression.
  12. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    13% is high. Its most likely top end related and cosidering 355s have valve guide issues I would think that it probably has loose guides which over time effects valve seats and how they seal, not to mention oil consumption of some sort. A compression test is a waste of time becasue there are so many factors that effect it and the most important observation of a compression test is how much of the final reading was achieved in the first compression stroke. The majority of the final reading should be in the first pump to indicate a good cylinder rather than the end reading being 150psi for example. I would repeat the leak down test again in a few weeks to see if the results are the same and then keep it in the back of my mind that when its time for an engine out service I should yank the heads and do the top end while im there. If thirteen percent is acceptable then you have an engine that is just acceptable rather than great.
  13. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    Newman I understand what your saying, but does it affect performance, ,is it something that would be noticable.
  14. Llenroc
    Llenroc F1 Veteran
    5,561
    Colorado
    Vern
    Read what bpu699 is saying there are a million opinions on this subject your numbers are not bad. Go out and run the car hard for awhile bring it back to the garage and do a leakdown and compression test yourself. There is nothing you can do to make 13% into 3% short of pulling the motor pulling the heads and doing a valve job. Only one cyclinder is that high and that isn't that bad. Drive it, have fun, keep an eye on it, watch your oil level. At this point whatever you do don't lose sleep over it. When they are at 20% in all cylinders then worry about it if you keep an eye on it you will know long before it gets to be a serious problem. Regards, Vern
  15. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    Your right, since there is no difinitive answer to this question, the best you can do is keep an eye on it and enjoy the car.
  16. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    I would drive the car and deal with it in the future when some other major repair like the engine out service is taking place. Performance loss wont be noticed unless measured on a dyno before and after the repair. Oil consumption might be the only symptom you see, that is if you drive it regularly and change the oil twice a year. Im afraid to do a leak down test on my boxer because the results will eat at me if they arent what I want to see and then Ill get myself up to my eyeballs in valves and cams when I could just drive it and be happy. Drive it, enjoy it and if it puffs blue smoke on start up you know why.
  17. BOBAER
    Jun 6, 2006
    261
    Jersey
    Jon
    Thanks, I really think there is no problem with the car as it runs great, shift really nice and sounds like a dream.
    After all, thats why I bought it.
  18. ParadiseRoad
    ParadiseRoad Formula Junior
    Mar 26, 2006
    538
    Colorado
    Just for general reference...you have to be careful when comparing leakdown results done with different leakdown testers. The leakdown gages have a flow restrictor orifice in them, and different brand gages may have different size restrictor orifices in them causing different readings between two different brand gages on the same cylinder. The gages work as follows: the source air pressure is adjusted using the gage regulator to apply 100 psi to the restrictor orifice. Air flows through the restrictor orifice and pressurizes to 100 psi the chamber that is connected to the cylinder pressure reading gage, and through a quick coupler and hose, to the cylinder to be tested. Once connected to the cylinder to be tested, the leakdown gage shows the pressure that results from the 100 psi flowing to it through the restrictor orifice, and whatever pressure is leaking away from it due to leakage sources at the cylinder. A larger restrictor orifice will result in a lower leakage reading on a given cylinder when compared to the reading resulting from the use of a smaller restrictor orifice.
  19. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    The problem with all of these opinions, is that they are like butt holes and we all seem to have one. There is only one source of a true opinion, IMHO, and that is regarding aircraft, aircraft engine manufactures, and the FAA, as well as other aviation related government regulations worldwide. There are no laws or regulations regarding any other internal combustion engine in any other product anywhere in the world that I am aware of. Simply put, aircraft that don't run well are deadly and dangerous, hence annual and hourly inspections that include a "leakdown" test. They do NOT do compression tests on airplanes, they do leakage tests.
    Aircraft engines are totally comparable to any other engine. They have piston rings and valve seats. There is no differentiation between aircraft engine manuafctures, or size. Some have huge cylinders, some small, etc., but the specifications are identical. Read advertisements for aircraft for sale, and ALWAYS cylinder leakdown numbers are included.
    Generally speaking, 10% would be time for overhaul. 13% could get you grounded by the right mechanic. 2 or 3% isnt any problem, neither is 5%. But as leakage increases, the volume of hot flame going past the area leaking, creates a cascade effect. I personally would want another test done on a hot motor after a hard run, and not only confirm the numbers, but know "where" its leaking. If its mainly the rings, I would watch it. If its a valve, its going to burn much hotter and could eventually melt under the right conditions.
