Computer Help Again | FerrariChat
Computer Help Again
Discussion in 'Technology' started by SefacHotRodder, Aug 24, 2007.
  1. SefacHotRodder
    SefacHotRodder F1 World Champ
    Dec 20, 2003
    11,158
    NJ
    Chris
    Does anyone know why i wouldn't be able to sync my ipod from an external hard drive. I just bought an external hard drive and want to put my music on it and then sync it onto the ipod from there but as soon as i plug in the ipod and the external drive into my computer, both aren't recognised. The computer only recognises one or the other.
    This sucks
    I'll paypal someone $20 if they can fix this because i bought this hard drive specifically for this. I have another and just assumed it didn't work because it wasn't a mainstream brand one
  2. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    Could be a resources sharing issue or a power issue. How many USB ports do you have? Are you trying to chain these together? Using a powered hub?
  3. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    4 ports on the laptop. 2 in use right now (would be 3 with ipod). Mouse is one and one of my externals is the other one. I made sure that there were no drive letter problems (having 2 of the same drive letters if you know what i mean). The external hard drive isn't powered off the laptop and neither is the ipod. The computer will detect the ipod OR external then as soon as the other is plugged in they both dissapear from My Computer. I'm also not using my ipod as a disk drive
  4. lateralus
    lateralus Karting
    Sep 6, 2005
    182
    Northern California
    Jon
    Does the external hard drive have its own power supply? If it's relying on the USB to supply power, then I agree with Mike, it sounds like a power issue.
  5. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Yes, it has its own power supply
  6. 4REphotographer
    4REphotographer F1 Veteran
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    im not sure if this is an answer you are looking for but when i ran my music from my external i had to keep library files on my computer and just move the actual music, maybe this will help maybe not
    i believe this is the right article
    http://docs.info.apple.com/article.html?artnum=305451
  7. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Thanks. But i don't have all my music in there. In fact, almost none of it is in there. Its scattered over my laptop right now which is why i bought the external. I wanted 1 hard drive (partition) dedicated to just mp3s and then sync from there
  8. 4REphotographer
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    do you have all your music in the itunes folder on the external?
  9. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    No. Its all in random folders on the hard drive in my laptop
  10. SRT Mike
    Oct 31, 2003
    23,343
    Taxachusetts
    Is one of them maybe USB 2.0 and the other USB 1.0? I dont know how that works - I know USB 2.0 ports are backwards compatible to 1.0, but I dont know what would happen if you put a 1.0 and 2.0 device on the same bus. If the 2.0 device did not support 1.0 (as I imagine a hard drive would not) then I would guess they would just both not work, even though they work seperately. Other than that, if it's not a power problem and if it's not a driver problem (since they work individually) it would have to be a resource sharing issue.
    Check to see if the laptop is USB 1.0 or 2.0, and also the USB version of the HDD and MP3 player and let us know
  11. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Hard drive is USB2. iPod could be USB1. I'll try to find out. Why would it matter if the hard drive is plugged in and working as any other normal hard drive and then i plug the ipod in and they both dissapear? I'm pretty sure my mouse is USB1 and my printer is definatley USB1 (99% sure) so why does it happen just for the ipod?
  12. 4REphotographer
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    if they both work just not together then i dont think the problem would be the usb ver, im curious as to how you have itunes set-up as you need to have all your music in one folder
  13. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Something you can try is to delete your Temp Folder and reboot the computer before trying again.
    Delete your Temp Folder by doing this:
    In Windows Explorer go to a folder called:
    - C:\Documents and Settings\User\Local Settings\Temp
    Note: you may have more than one user defined on your PC. If so, the "\User\" part of the path name could be your specific User Name. Verify that the "My Documents" folder under the "User" folder is the same set of files you see in Windows Explorer when you click on "My Documents" at the root level.
    Select all the files and folders under the "Temp" folder and click control-A (this does a select all).
    Make sure you are only selecting the files and folders BELOW the Temp folder!
    Hit the Delete button (this deletes all the files but they are still in your recycle bin).
    Now reboot and try connecting the HDD and iPod.
    Test your other software products. If all okay, clear out your Recycle Bin.
    You shouldn't need anything in your Temp Directory.
    These steps will free up a lot of space and, for some reason, it appears iTunes and the iPod connection can get confused if certain remnants are left in the Temp Directory. You'll see some references to it if you Google search the topic.
    Hope this helps.
  14. 4REphotographer
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    this is why i love my macs
  15. SRT Mike
    Oct 31, 2003
    23,343
    Taxachusetts
    Does the USB 2.0 bus run at 2.0 and 1.0 simultaneously? If not, then plugging in his USB 1.0 device may cause the whole shebang to run on USB1.0 and the HDD may support 2.0 only.
    As for why it would work with the mouse, are you sure that's 1.0?
    If I were having this problem, I would first try it on another computer. If it works there, then its definitely an issue on your laptop only. I would then re-install the drivers. I would also try swapping around whats plugged into what USB port. Maybe you have a bad port? Move the devices around and see if the problem moves with the HDD and MP3 player, or if the problem stays with a certain port. That would help narrow it down also to a device issue vs. a laptop issue.
  16. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,476
    KL, Malaysia
    MC Cool Breeze
    maybe the laptop doesn't generate enough power supply for all?
  17. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    I can't delete all of them, some are in use but i'll try it with the ones i deleted
  18. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    toggie, it worked. I actually switched the ipod wires too since the one i was using was some generic one. I also cleared the temp folder and restarted and it works! Thank you. Whats your paypal address?
  19. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Dammit. I just moved all 50gigs of music to my external and plugged my ipod in and its not recognising it. Bah. Its still recognising the external though and i'm playing music off it. Wtf
  20. ferraridude615
    ferraridude615 F1 Veteran
    May 4, 2006
    5,836
    Texas
  21. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Actually its working again, lol. Thanks for the link though
    btw, for those wondering how i don't keep stuff in my itunes folder i just download/rip cd's in to a folder then drag that folder into itunes and itunes plays it from there. I've made it so that the music isn't copied into my itunes folder
  22. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    No need for payment. If you just have to pay somebody, then donate the money to the Salvation Army.
    Glad it worked. (And in typical Windows / Microsoft fashion, no one knows exactly why. LOL).
  23. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Thanks again man :)
