Computer Help Please (random shutdowns) | FerrariChat
Discussion in 'Technology' started by SefacHotRodder, Jun 26, 2004.
  1. SefacHotRodder
    SefacHotRodder F1 World Champ
    Dec 20, 2003
    11,156
    NJ
    Chris
    My computer has been randomly shutting down. It started yesterday when i put my ipod in and it shutdown, then had to run the scandisk thing that checks for irregularities in the disk then is fine. It has since happened about 5 more times. Mostly when i put my ipod in but also happened when i re-plugged my printer in (i had to unplug it to move it). This hasn;t happened before.
    Anyone have any ideas?
    btw, i'm virus scanning it now and there appears to be no virus like this on the symantec site. I've also S&D my computer and add awared it. Nothing.
    Help Appreciated
    Chris
  2. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    Is the plug all the way in...?
    i'm seriously not trying to be sarcastic...
    i'm having the same problem, except, i don't have an iPod and i'm not plugging or unplugging my printer... i think it might be a hardware issue like the motherboard or whatever... i don't know a whole lot about this sorta stuff...
  3. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
    dude. No. just...no
    :p
    yes its plugged in all the way
  4. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,332
    SFPD
    Dirty Harry
    What Operating System are you running?
  5. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
  6. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I suggest you uninstall everything related to your ipod. Check for spyware, like you say you are. Do not try and and connect the ipod - Then see if you still have the crashes. Let us know.......
  7. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
    damn. i really don't want to uninstall itunes. i'll check out the ipod message board.
  8. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Sorry, I know that sucks, but I'm just trying to help. Check the message boards and confirm that people are having trouble with Itunes. Esp. if you have musicmatch on your system. Once you determine the problem I'm sure we can get Itunes to work with your sys.
    Good luck & check all resources.......
  9. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
  10. vraa
    vraa F1 Rookie
    4,528
    Texas
    Mr. A
    FireWire or USB?
  11. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
    firewire. it seems letsjet was right anyway. itunes doesn't even work. it says i need to re-install it for the ipod to work. i've almost reached the end of my rope on this computer.
  12. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Hey Chris,
    We've all been there before with one program or another. ITunes loads a lot of files in the background. It will also change a lot of settings. Are you saying you unistalled it? You have to be very specific if you want our suggestions to work.
    If you uninstalled it and you are not getting the shutdowns that's a good start. Keep posting here and I will try and help you, but I would also post on an ipod site as they have more experience with this.
    - Eric
  13. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
    ok, re-installed itunes (i just re-installed it, not completley uninstalled it). Fixed that.....then it shut down again
    went into some config stuff and changed it so that when there is a system faliure it won't shut down, dunno if that will help or not..
    then i looked in system log and all the times that i has done this a program (different ones, trillian, office, itunes, cd ripping program etc) it says they have "faulted". there is tons of other stuff too.
    LetsJet, is there any info you specifically want that could help you (and me)?
  14. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Chris,
    Read your post and tell me if you understand it. I'm not trying to be rude but I can't understand everything you have done. In computers, the slightest little thing could make the difference....
    I'm going to make some assumptions in my answer. First, you said you re-installed ITunes. You never gave me an answer that you uninstalled it. Did you? And when you did, did the system crash or did it solve the problem. If it did solve the problem there are a couple of things to consider.
    When you uninstall ITunes I've read that not all the files are removed. So, if you re-install the problem is likely to occur again. You must go to a site that can tell you what files / registery edits and deletes might be required to do a complete uninstall. Also, you need to make sure all programs, including anti-virus, etc. programs are not running when you reinstall. Do not even consider re-installing until you determine this is the problem. It sounds like your so concerned about using ITunes that your rushing this. Give up on ITunes for the moment.
    Did you ever have Musicmatch on your system?
  15. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
    sorry, i was going to type this but the internet reset:
    just had the blue screen of death:
    __________________________
    DRIVER_IRQL_NOT_LESS_OR_EQUAL
    Stop: 0x0000001 (0x00000020, 0x0000002, 0x000000, 0xF30B90FF)
    BlackDrv.sys - Address F30B90FF base at F30AD000, Datestamp 40C09513
    btw, itunes is working fine now.
  16. imperial83
    imperial83 F1 Rookie
    2,893
    You have some kind of a virus, worm or malicious file on your computer that is doing this. If you have an ativirus software, update your virus defenitions and run a virus check. Unplug yourself from the internt while you are running the virus check.
    If you do not have a antivirus software you need one now.
  17. SefacHotRodder
    Dec 20, 2003
    11,156
    NJ
    Chris
