Computer help? | FerrariChat
Computer help?
Discussion in 'Technology' started by Zupra, Dec 16, 2005.
  1. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,661
    St Louis
    Chesney
    I got computer problems again..... I bought a new computer(All the parts for one) and once i pit everything together i turned it on and everything turned on, all the fans, the videocard fan and all that..
    But then about a second later... it all turns off, do you know whats wrong?
  2. blackwood
    blackwood Formula 3
    Dec 15, 2005
    1,822
    Redondo Beach, CA
    Marc
    Could be a lot of things.
    First thing I'd try is swapping out the power supply...
  3. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,661
    St Louis
    Chesney
    It's brand new though, 520W... and the fans turned on on that too.
  4. blackwood
    blackwood Formula 3
    Dec 15, 2005
    1,822
    Redondo Beach, CA
    Marc
    How far does it get before it shuts off?
    Does it POST?
  5. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,661
    St Louis
    Chesney
    This is my dads laptop........ no it turns on for about half a second (not the computer screen or the bios but tjust the fans) and turns off
  6. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    it does sound like a power supply problem.
    520 is a good-sized jobbie, i doubt you're overloading it, but try unplugging things to see if that changes the behavior.
    will the PS stay powered with nothing connected to it?
    doody.
  7. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    It's either power supply or the thermal grease between the heat sink and the cpu that isn't sufficient, thus over cooking the cpu and causing it to shut off.
  8. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,661
    St Louis
    Chesney
    But how could that be? I just bought all this a few days ago.
  9. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,661
    St Louis
    Chesney
    Will clearing the cmos work?
  10. CornellCars
    CornellCars Formula 3
    Mar 24, 2005
    1,102
    South Florida
    Jason
    Last computer I bought took 3 tries to get a working hard drive...qc doesn't seem to be as high a priority in the computer industry lately...
  11. Schatten
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Jason is correct. "New parts" and "just installed" are two misunderstandings in the computer industry. Neither will equate to proper working order. There is a % of failure rate. It used to be 15-20% failure rate on most products. Now, it is somewhere around 2%.
    So... did you use the thermal grease correctly? What else do you have hooked up to the system? How many hard drives, cards, etc? Can you just use the BASE stuff? vid card, memory, no hard drive and see what it does? Swap memory around.
  12. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,415
    SFPD
    Dirty Harry
    Be sure power switch (110/230) is set correctly.
    When you assembled this, were you careful to wear cotton, touch power supply occasionally & so forth to avoid static electricity?
  13. Schatten
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    clearing ESCD (which is the part of the cmos that you actually clear when you do it) will not. That would be to resolve other issues. This is a power supply or heat problem related to your cpu and the way you set it up.
  14. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,661
    St Louis
    Chesney
    Schatten you did it again, I just bought a new 600W PSU at compusa and it fixed the problem!
    But.... there is another problem now.... the screen wont work. When I turn it on the OSD blue screen thing comes up, but no bios or boot thing.....
    It works with my dads laptop, but not with my computer.
