Cone of Silence | FerrariChat
Cone of Silence
Discussion in 'Technology' started by muk_yan_jong, Jan 8, 2015.
  1. muk_yan_jong
    muk_yan_jong Formula Junior
    Oct 11, 2008
    569
    Brian McK
    What???
    OK. Girlfriend has slightly degraded hearing. I don't. More the opposite. I just can't take loud TV/Movies/noise. Unless it smells like CAM2 and has carbs...
    For both general watching and movies, I want to set up a set of speakers closer to and aimed right at her instead of blasting the whole living room. Hopefully with their own volume control allowing me to keep the overall TV volume reasonable.
    Does anything like this exist without being earphones? Am I explaining it correctly?
  2. enzo thecat
    enzo thecat F1 Veteran
    5,823
    Midwest
    Enzo Thecat
    I have no ideas or suggestions. But this made me LMAO!
  3. TheBigEasy
    TheBigEasy F1 World Champ
    Jun 21, 2005
    18,634
    California
    Ethan Hunt
    New girlfriend. ;)
  4. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    What about those headphones you see on late night TV commercials that give you bionic hearing and let your partner sleep while you watch TV on the lowest volume? 😃
  5. EnzymaticRacer
    EnzymaticRacer F1 Veteran
    Feb 27, 2005
    5,367
    Silly posts aside...
    Honestly not sure that there's a *good* solution for this... just an idea...
    If you have an audio/video receiver that has 2 *zones* (the second zone would normally be situated in a separate area, like a different room, or outside) that supports outputting the same audio to zone 1 and zone 2 simultaneously...
    you could *potentially* using directional speakers to create individual zones in the same room with their own volume controls. Using a large amount of sound dampening materials in the room could reduce the incidence of crosstalk and such, but you'll never get rid of audio sourced from her side completely.
    However, there are going to be significant drawbacks to this type of setup... not the least of which being that the seating positions are going to have to be quite separated from each other... might make doing "stuff" with the girlfriend difficult.
    The other issue is that, in general, speakers designed for home theater use are generally designed to broadcast the side in a wide area, in order to get maximum coverage. In this type of setup, you would be trying to do the exact opposite.
  6. muk_yan_jong
    Oct 11, 2008
    569
    Brian McK
    Pending career change/relo might make that happen, but while I'm here she's a good one.
  7. tvu
    tvu Formula 3
    1,361
    Southern California
    Trieu
    About 15 years ago, I was in the lobby of a internet streaming music company - and they had this setup. I don't know what it's called, but I'll just describe it. Above each of the lobby chairs, it looked like a typical lamp, but upon closer look - inside was a speaker pointing up, and the lamp was shape like a parabola(small umbrella). So of course - the speaker is the focus of the parabola, thereby enabling a sound cone directly down toward the listener seated. It was pretty neat because as a bystander 1 or 2 feet away, you could barely hear the music until you step into the "sound cone". With that solution, you are pretty fixed. You need to be right under the cone.
  8. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    #8 Schatten, Jan 15, 2015
    I first thought, but then... I do get into modes, especially Sunday evenings, where my mind needs to shut down and I cannot take TV/movies/radio. Just need silence.
  9. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,409
    SFPD
    Dirty Harry
    It's terrifying to watch a TV show without captions and only understand one word.
    Get your GF to an Audiologist, have her hearing tested (it's free) & get her a hearing aid or two. Pay by cash or CC & be done with it, PDQ.
    If you wish to go the Insurance route, which I did, a cautionary tale;
    I got the ball rolling 54 weeks ago & between Doc, their Administrator, Audiologist and Insurance Company, I am still waiting to be fitted, let alone find out what HA I'll be using, if they get their act together. Insurance finally approved Hearing Test after 11 Months. I did "approved" test & most importantly, co-pay Christmas Eve, after 4 appt. cancellations - not by me. Employer has switched to an even crappier "provider."
