Confirm carb/airbox nut size? 8MM wrench? | FerrariChat
Discussion in '308/328' started by AZDoug, Dec 15, 2009.
  1. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Don't have my car real handy to look, are the 16 nuts that hold the airbox and air horns to the carbs serviced with an 8MM wrench?
    Thanks,
    Doug
  2. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    8mm is correct
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,461
    Canada
    Newman
    I use a 1/4 drive socket on a wobble extension rather than a wrench. 5/16 or 8mm.
  4. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    Yes, a wrench would be quite ponderous on the nuts and quite difficult on the 4 forward nuts.
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I use a ratchet type box wrench and it works great.
  6. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    I am going to order a couple nut drivers and modify one so it can be used with the deck lid/hood on the car, which is why I asked.
    I never did get anything that fit really well, as the reliefs in the airhorns were too small to let a 1/4" extension really fit for a true vertical drive, so everything was always done at an angle, though it looks like an integrated U-joint/socket in 8MM would fit in from an angle nicely, ordering one of those also.
    The outer forwards were always a challenge with the hood on the car, it can be done, but is a PITA, and yes, I have always used an open end wrench on those, with the hood on.
    Thanks,
    Doug
  7. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    I can get the whole rear bank and the 4 rear nuts of the front bank with my Craftsman nut driver with a 1/4" 8mm socket. For the front of the front bank I use a 1/4" ratchet with the extension and the socket. It just clears the air horns. Removal takes only a few minutes. This can all be done with the hood on my '77 GTB.
