CONFUSED. F1 HIDRAULIC SYSTEM. 360 cs | FerrariChat
Discussion in 'Technical Q&A' started by precision360cs, Aug 15, 2012.
  1. precision360cs
    precision360cs Karting
    Jul 31, 2012
    141
    COCONUT CREEK FL
    adrian Farinato
    i recently have a ev line fail .it fail after i was driving for about 2 to 3 hours on aparade ,stop and go ,stop and go.
    i reserch about it ,and i found out that ricambi used to sell a heat shield for the pump motor .Mi question is? what overheat in the system?,is the fluid ,thas why my line fail? or is the motor and have notting to do w/my failing line...thanks .
  2. rustybits
    rustybits F1 Rookie Professional Ferrari Technician
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    No, the line has failed. They are resistant to heat, heat isn't the issue. The solution ricambi offers is for PUMP overheating causing electrical failure, not the lines. You have two choices. Your choices are:
    1. Go buy genuine and have your pants pulled down, no lube, take a run-up (you get the idea)
    2. Take it off and have a hydraulic specialist make you one at a fraction of the cost.
  3. precision360cs
    Jul 31, 2012
    141
    COCONUT CREEK FL
    adrian Farinato
    my local hidraulic place make new line for me allready.but i don't want other line to fail again .And in the worst case if is the fluid overheating i can install a small cooler near the pump.
  4. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,453
    Winston Salem, NC
    A pump "cooler" would have no effect on the lines themselves.
  5. precision360cs
    Jul 31, 2012
    141
    COCONUT CREEK FL
    adrian Farinato
    now i see it clear .the line just fail , notting to do w/tempeture. thanks .
    no need to install cooler......
