Connecting a Battery Charger | FerrariChat
Discussion in '456/550/575' started by Rareusgold, Apr 22, 2014.
  1. Rareusgold
    Rareusgold Karting
    Sep 9, 2005
    162
    Florida
    Rich
    How do you guys connect a batter charger on a 550? How do you get the wire under the hood without cutting the wire when the hood is closed or messing up your paint when the wire comes out the hood?
    On my 328 I am able to snake the charger up from below. Is that possible on a 550?
    Thank you
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    If you're talking about a regular house power cord its no problem, just don't close the hood all the way.
    The hood open warning on the dash will remind you to unplug it.
  3. AKINSB
    AKINSB Formula Junior
    Feb 15, 2013
    502
    Santa Barbara
    Alex K
    My technician attached the trickle charge wire and quick disconnect plug to the fuse panel in the car interior for my 1995 456 GT. Has worked flawlessly for 1.5 years. I never forget to disconnect the quick disconnect plug since the wire is draped over the seat and out the door sill. Clearly visible before I drive away.
    Passenger door closes without a problem and wire does not get crimped and paint does not get chipped. Body of charger sits just outside the door on the concrete floor. The unit does get slightly warm. When unclipped at the plug I have a 4" wire and plug/ wire hanging from below the dash. I just tuck it into the edge of the carpeting.
    Best
    AK
  4. 308 GTB
    308 GTB F1 World Champ Rossa Subscribed
    Feb 7, 2002
    11,722
    New Jersey
    Barry Wolinsky
    [ame=http://www.youtube.com/watch?v=AnH7NyqhVfs]Normal Sinus Rhythm[/ame]
  5. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
    It depends which charger you have but you could get one of waterproof motorcycle type sockets and run it from the battery between the hood and the seal into the gutter with the wipers - in this way you can close the car completely when charging and it is ok to leave open to the elements when driving
