Consequences of not waiting for the "OK" to start on F430 ? | FerrariChat
Discussion in '360/430' started by ohared, Mar 29, 2013.
  1. ohared
    ohared Formula Junior Silver Subscribed
    Apr 14, 2009
    344
    I had my 08 F430 F1 out today for the first time in 2013. I got a "Slow Down" come up shortly after taking off from the gas station. The car was running really rough, it nearly stalled from the first junction. A mile or 2 down the road the amber "Slow Down" light would come on from time to time. The car would not rev over 4k rpm even at full throttle.
    I pulled over stopped the car and fault cleared on restart. It has been fine for the rest of the day.
    Looking back at the sequence of events I think I started the car without waiting for the "OK".
    I have read some threads on F-Chat about starting without the "OK".
    Is that the likely cause ?
  2. steelej
    steelej Formula Junior
    Jan 15, 2007
    433
    If you don't wait you don't give the car enough time to complete it's self checks. For the sake of 10 seconds it's definitely worth the wait.
    John,
  3. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,285
    It explodes and transforms into a Fiat 500C.
  4. Stevely
    Stevely Formula Junior
    Jul 21, 2011
    634
    LA, CA
    It shuts down two cylinders and turns into a 360.
    Hahaha I kid.
  5. sc170
    sc170 Karting
    Oct 5, 2012
    109
    California
    Did you get a CEL??
    My wife did the same thing the first time she fired up the CS. I was told the problems is that the start button controls a "cam line" that fires up everything in sequence. If you hit the start button too soon or don't hold the start button long enough, not everything turns on. You are then basically driving the car with half the engine on.
  6. jpk
    jpk Formula Junior
    Oct 29, 2012
    803
    Los Angeles, CA / Henderson, NV
    Ouch, I own both a 360 and a 500C.
    Please no jokes about the Cavalino Rampante putting its hooves down and turning into a Mustang, that would make three strikes on me.
  7. ohared
    Apr 14, 2009
    344
    NO CEL.
    Come to think of it, I think I had 2 attempts on the start button.
  8. JS NZ
    JS NZ Formula Junior
    Sep 24, 2010
    305
    Auckland, NZ
    I would also check fuel cap plus unlikey for a number but could have been a little water in the fuel
  9. plastique999
    plastique999 F1 Veteran Owner Silver Subscribed
    Nov 9, 2008
    8,841
    SoCal
    Edward
    Sounds like possibly O2 sensor?
  10. Mo T
    Mo T Formula Junior
    Nov 26, 2011
    478
    Saudi Arabia
    Mohammed
    I keep the car sitting for about 10 seconds even after the Ok sign appears before hitting the start button (especially if it has been sitting for a couple of days) as I found the car idles much better when the various systems are given a good amount of time to launch and get ready to fire up.
  11. DanS*
    DanS* Karting
    May 29, 2012
    218
    Manhattan Beach, CA
    Dan
    Not waiting long enough (few seconds after OK) or having to hit the start button a second time seems to result in half the engine running. It's pretty obvious when it happens and simple to remedy. Shut off and go through the start properly. I don't think any harm is done (though one shouldn't drive that way).
  12. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I start mine all the time without waiting. Never an issue. It is a stick however.
    Dave
  13. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Waiting longer gives time to energize the ECU / fuel pump properly perhaps ?
  14. Tio
    Tio Formula Junior
    Mar 26, 2011
    391
    London
    Harry
    Might be worthwhile to do an ecu reset just for the sake of having peace of mind.
    Its only a 20 minute procedure and it will surely benefit the car and clear and roughness.
  15. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    Nothing to do with having a stick.
    Couple of times with my manual I forgot to wait and got the misfire issue. First time freaked me out and I spent 5 mins trying to nurse the car home. Finally stopped, turned off, did proper restart and all is fine. From then on, easy to recognise the cause. Simply turn off and restart properly.
  16. timba
    timba Formula Junior
    Aug 20, 2012
    258
    Nor Cal
    Tim
    My experience is that this can also occur if you double press the Start button. In all my other cars you don't need to continue to hold the start button, you just press it once and it keeps cranking until the car starts. I spaced out and did this in the Ferrari once, and as I was letting off the button I remembered and pressed it again. The car started, but in limp mode. Shutting it down and restarting cured the problem.
    Probably meant CAN, not cam
    CAN bus - Wikipedia, the free encyclopedia
  17. i.gonz
    i.gonz Rookie
    Jan 14, 2013
    17
    The horror !
  18. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Check fuel filler cap is on tight enough - if its not the system thinks there's a air leak in the fuel tank and goes into Slow Down.
  19. MD326
    MD326 Karting
    May 6, 2007
    192
    MD & FL
    WJP
    That's scary! Can running on half a bank damage the engine? Just curious. If the 430 fires wrong at start up I turn her of immediately. It sounds so bad.
