Console in 512M and 92TR | FerrariChat
Discussion in 'Boxers/TR/M' started by RHR Ferrari, Oct 8, 2007.
  1. RHR Ferrari
    RHR Ferrari Rookie
    Oct 7, 2007
    7
    My two machines have the covering on the consoles which has gone gooey and sticky. Anyone have any advice on this
    thanks
  2. Dry Heat
    Dry Heat Rookie
    Sep 13, 2006
    46
    sonoran desert , az
    Brian
    No advise, but I have noticed the same thing.
  3. Dry Heat
    Dry Heat Rookie
    Sep 13, 2006
    46
    sonoran desert , az
    Brian
    No advice, but I noticed the same thing on the LBC (little black car).
  4. Bullfighter
    Bullfighter Two Time F1 World Champ Lifetime Rossa Owner
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    This is a common problem on the 348 and 355, and may be the same issue on yours - do a search in the 348/355 forum on "sticky" and you'll have a lot of reading.
    One bit of advice is to never clean it with anything other than a damp (with plain water) cloth.
  5. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I'm trying a new CF guy, if he turns out to be reliable I can make some CF ones, in a few months
  6. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    I took mine out, including the door handles and the instrument cluster housing, cleaned them up and then had a friend of mine in the paint and body business paint them in a high impact flat black. They look good and wear very well. Much better than the original nasty covering that Ferrari applied.
