Console screw stripped threads | FerrariChat
Discussion in '360/430' started by colorfull, Dec 14, 2022.
  1. colorfull
    colorfull Formula 3
    2,390
    Franklin Park, New Jersey
    John Napoli
    Good day all,
    So I'm trying to get to the SRS ECU in front of the shifter, in removing the console, the last screw (of course!) Threads are stripped and the head is recessed, it just spins.
    I tried getting a screwdriver behind the carpet and putting back pressure on it which I was able to do but it didn't help the screw move at all.
    Any suggestions before I drill it out?
    Thank you!
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,161
    Central NJ
    Dominick
    Use a clip remover behind the screw and put pressure on it as you screw it out
    That is for threads that are stripped
    For head stripped.. carefully tap in a Philips screw driver or the next size hex
    Use a cheap screwdriver or hex driver so that it gives to screws
  3. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    Stripped threads not head, thank you, will try that
    With the raised washer which comes up around the screw head, can't really seem to get behind the screw head
  4. 24000rpm
    24000rpm F1 Rookie
    I removed it by using vise grips, but i am not sure if you can grip the head of the screw though. I think maybe I was just lucky.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,161
    Central NJ
    Dominick
    Try a very thin screwdriver or two small screwdrivers (may need a helper )
  6. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    Thank you all
    Since the washers are basically a well that the screw drops into and it's screwed down quite flush, I'm not having any luck with leverage
    Am going to give it a solid attempt with these, nothing I haven't been able to grab with these, one of my favorite tools, if that doesn't work, I guess it's the dental chair!
    Stanley FMHT0-75409 curved Locking Mole plier, Black https://a.co/d/gFzaOHV
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,788
    Your best bet is to gently hammer in a Torx bit. The Ferrari body fastenings are like cheese and will readily deform to accept the torx bit.
    colorfull likes this.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,016
    Isle of man- uk
    Try filling the head with epoxy resin like Araldite and set the allen key into it overnight.
    Flea7 and Marcoboxer like this.
  9. AandSC
    AandSC Formula 3
    1,002
    Jax, FL
    Allen
    Time to break out the drill. I keep an assortment of all the different fasteners and typically replace any that show any type of wear, because I’m OCD and can’t help myself.
  10. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    511
    New Jersey
    Use a Dremel tool, with a flat cut off round blade and make a straight line across the top of the screw to use with a flat head screw driver.
  11. LorenzoR
    LorenzoR F1 Rookie
    I don't believe it's the head of the screw stripped, it's the threads of the screw stripped not allowing it to back out
    AandSC likes this.
  12. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    Thanks all
    Right, Lorenzo, the head in this instance is good. Allen wrench turns the screw fine, but when it turns, it doesn't back out, just spins
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,788
    Ah, missed that part! flash32 trim remover advice is good - that's what I do.
  14. LorenzoR
    LorenzoR F1 Rookie
    I say get the washer from behind the head of the screw out of there. Bend it break it whatever you gotta do to get the washer out. Then get a pair of wire cutters behind the head of the screw and place a small block of wood midway of cutter for leverage. Press down on the handle of cutter for pressure and try to unscrew it
  15. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    The washer goes down, so not easy to do that
    I was able to get behind the head and apply pressure, I think at this point there are no longer any threads to catch
  16. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,987
    Melbourne Florida
    KGC
    Maybe cut a small slit in the carpet to the screw hole. That should allow you to get the carpet out of the way. Maybe that would allow enough room for you to get leverage behind the screw head with the carpet thickness gone (?)
  17. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    Was hoping to not have to damage anything, but definitely have to consider it, thank you
  18. AandSC
    AandSC Formula 3
    1,002
    Jax, FL
    Allen
    Drill the head off, takes 4.6 minutes, remove the cover, and then you have access to everything.
    We are all watching and here for moral support. Work takes a backseat to watching for the results of this evolution. :D
    colorfull and LorenzoR like this.
  19. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    Thank you Allen, appreciate all the attention from everyone to such a relatively small problem of mine.
    I will post the outcome!
  20. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    913
    S La
    The blind nut in the panel may be spinning and not the screw. Very common especially on the underside screw/nut assemblies that hold on the under panel. I have had to drill out a couple of those and instal new captive blind nuts. The tool I used is "Wetols" rivet nut tool(Amazon). Seems like M6 is the nut/screw size. You might as well pull away the carpet to see what you are dealing with. Or, clamp the spinning screw/washer/rivnut with a vise grip and drill it out. Then pull back the carpet and install the new captive rivet nut.
  21. colorfull
    colorfull Formula 3
    2,390
    John Napoli
    Thank you, good point, I was wondering if it was screwed into an insert, threaded panel or other.
    Will see if I can figure out how the carpet is attached
  22. colorfull
    colorfull Formula 3
    2,390
    John Napoli
  23. ItalGerBrit
    Mar 15, 2016
    913
    S La
    Yep. That is a "rivet nut". Or a "blind rivet nut". My guess is that the screw is rusted and seized and the rivet nut "barrel" is spinning in the panel.
  24. RedNeck
    RedNeck F1 World Champ
    12,561
    The CSA
    Me
  25. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    I'm hoping for 3 pages on how to get a screw out. But seriously drill it out end of story
